Local Time 07:20 25 Oct 2026 Privacy Policy
Forum Index : Windmills : small commercial turbine design
Gavztheouch
Posted: 04:33pm 22 Dec 2008
Hi I've been searching the net for some plans for a windturbine. So far the best I can find in terms of power output is this turbine on instructables.com
http://www.instructables.com/id/DIY-1000-watt-wind-turbine/
How do small commercial turbines produce as much as 15Kw. Are there any plans or information avaliable on larger turbines?
Gavin
UK DIY Renewables forum currently seeking members and help for the Admin.My Link
wdyasq
Posted: 12:40am 23 Dec 2008
A good number of small commercial turbines have "fabricated" tables.
It seems the Tooth-Fairy and the Easter Bunny are both involved in the making of these tables when Santa is busy and the politicians are running for election.
Ron
Adventure is just bad planning." -- Roald Amundsen
Dinges
Posted: 08:52am 23 Dec 2008
What Ron said.
An interesting calculation one can make is to check whether the manufacturer's numbers yield efficiencies higher than the Betz efficiency (a theoretical maximum efficiency of 59.3% for windturbines; a hard upper limit, like the speed of light and Carnot efficiency). If someone is trying to sell a turbine with efficiency higher than 59.3%, they're either incompetent or conn men or both.
Larger DIY windturbine plans or information:
http://www.otherpower.com/otherpower_wind.shtml
http://www.scoraigwind.com/
http://www.anotherpower.com/gallery/zubbly?page=30
I consider the above links/people to be worthy of my trust, even though I may have a different opinion on details. There are more of course. For example, somewhere on this board there's a chainsaw wielding maniac whose opinion sometimes isn't far from the truth.
Good luck on your quest. And remember... if it sounds too good to be true it probably is. The renewable energy field (wind, solar) seems to have more than its fair share of misguided (overunity) people, or even outright conn men. There's a lot of detritus out there that one has to wade through to find the occasional gem. I think the above links contain gems.
Peter.
Edit: this says it best http://www.otherpower.com/bottom_line.shtmlEdited by Dinges 2008-12-24
Gavztheouch
Posted: 02:14pm 23 Dec 2008
Thanks for the links Peter, lots for me to read up on. I have been thinking of building something similer to this http://www.otherpower.com/otherpower_wind.shtml
I've started a trial run at carving a blade to see if im up to the task.
Robb
Posted: 04:09am 25 Dec 2008
The above said "chainsaw wielding maniac" may have some helpfull tips there too.
Making blades with a chainsaw
