Local Time 07:04 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Starting to see the light !
Delawishious
Posted: 03:12pm 26 Oct 2008
Hi everyone! I am in the process of putting together a flat plate p.m.alternator using 100mn x 20mm x 5mm neo magnets! In relation to the measurements where does north and south need to be?
Still searching for that pearl in the sandy gusset of life.
GWatPE
Posted: 09:51pm 26 Oct 2008
I would expect that magnets of that size would be difficult to handle. I had trouble enough with the 25mm x 25mm x 12.5mm blocks I used.
Gordon.
PS edit:
These magnets appear to be large, long and thin. useful on a large dia machine. alternating N-S is a good start when making an alternator.Edited by GWatPE 2008-10-28
become more energy aware
KiwiJohn
Posted: 09:59pm 26 Oct 2008
Post a diagram and I am sure someone will show you which way they go around.
windlight
Posted: 11:35am 27 Oct 2008
The N&S is set when they are made, hopefully either side of the flat surfaces ie 100x20.
allan
