Local Time 07:03 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Permanent Magnet Generators in Oz
E-W&F
Posted: 10:56pm 09 Oct 2008
Hi
Does any body know where to buy Ozie made
Permanent Magnet Generators for wind turbines in Australia @ 1to 1.5 Kva
I'v surched 4 states with no luck
G
windlight
Posted: 09:17am 11 Oct 2008
Not suprising, try looking for Permanent Magnet Motors, would need to be rated at your desired voltage in a reasonable speed range like 150-400 rpm.
Motor/generator same beast when you are talking permanate magnet, remember that terminal voltage (the voltage at the generator output unloaded) is linear. Meaning if the motor is rated at 100v @ 1000rpm then it will have a terminal voltage of 10v @ 100rpm.
Hope that helps.
allan
