Forum Index : Windmills : Hub assmbly
| adam666 Newbie Joined: 01/02/2006 Location: New ZealandPosts: 14 |
Hi everyone, Im making a hub at the moment to fit 3 x ldpe blades approx 500mm long. Having cut the first 10mm thick plate into a circle (for welding to shaft), Im wondering whether there would be any probs if I DONT make the other 10mm plate round and just left it square...for obvious reasons :) the blade mounts are 4mm, which will have the 10mm plate as shown welded to it. ![]() ![]() and will bolt to the circular 10mm plate. any problems / suggestions? thanks Adam "to capitalize on windy wgtn" -excuse the pun :p |
Hi Adam. Nah there is no reason you couldn't leave it square. It would have no effect on balance, and little effect on wind resistance. And it would save you a lot of work cutting another circle. Its only cosmetic, so go for it. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
GREAT!! I had convinced myself it would be fine as it was still symmetrical, but just thought Id check :) cheers glenn should be flying pretty soon :) cheers Adam "to capitalize on windy wgtn" -excuse the pun :p |
While Im here :P can anyone please give me some advice with regard to constructing / mounting using the f+p bearing holder? ive got wat i think is a decent plan, using angle iron frame and securing to holder with screws but..... ecoinn sell these holders so Im hoping someone might have a pre-engineered design I could copy :D ideas invited !! thanks Adam ![]() ![]() and it has a excellent rubber seal for the front too! bonus :) Thanks Adam "to capitalize on windy wgtn" -excuse the pun :p |
Hi Adam. Have you seen the design I describe on the web site http://localhost/Windmill/fp2a.asp. Its a bit more involved, but you can make it in a afternoon and its proving to be reliable. Another option would be a short length of 100mm box section. Drill a few holes in the side of the steel box and screw in self tapping screws to secure the plastic bearing holder. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
Hmm, hadnt though about getting some 100mm box.... but yes, screwing to the centre section seems the way. yes, I have been using those instructions for everything else! :) they're excellent thanks! figured Id have a go using the std holder instead (dont have any 65mm box :p ) and tryin to re-use as many of the washing machine parts as possible :) cheers Adam "to capitalize on windy wgtn" -excuse the pun :p |
ended up using 4 bits of 40mm angle (2 bits shaved to 35mm) pics: http://www.oupower.com/index.php?dir=_Other_Peoples_Projects /adam666/WindPower/Fisher%20and%20paykel%20turbines cheers Adam "to capitalize on windy wgtn" -excuse the pun :p |
