Local Time 06:43 25 Oct 2026 Privacy Policy
Forum Index : Windmills : Shape of PVC blades?
mahela007
Posted: 09:16am 28 Jul 2008
Hi.. I made some PVC blades for my windmill. (Its still my first shot at making a working windmill.)
The blades seem to be fine when i look at them form the top. However when I look at them form the front.. that is from the side of the leading edge the last few centimeters of the blade seem to be tilted in the opposite direction to the rest of the blade. Is this ok? or should I try to bend it back? I hope the photographs will help you guys to see the problem.
http://www.flickr.com/photos/9937638@N02/
they are relatively high resolution so you can zoom in quite a bit
how come its not very windy where i live???
windlight
Posted: 07:20am 29 Jul 2008
I trialed PVC blades once, and found they bend conciderably and can hit the tower, others have had sucess. The tips will take on their own shape when flying, I would not attempt to shape them.
allan
CraziestOzzy
Posted: 10:03am 29 Jul 2008
I know very little about wind dynamics on a fan, but know that if you heat the pvc with a hot air gun (be careful!!!) you can bend it into any shape you want without weakening the relative strength of the pvc as opposed to cold bending it.
You can look into the pros and cons of an upwind or downwind blade/generator system if there is a reasonable chance the blades may flex too much and hit the tower.Some dimensions of your blade would help a guru on this matter advise you into the right direction...as that tip to me looks a bit narrow to what I have seen from others.
Cheers.Edited by CraziestOzzy 2008-07-30
WooferHound
Posted: 01:40pm 29 Jul 2008
When you mount the blades to the hub, just shim it up on one side so the whole blade twists to the correct angle
W o o f -={(
The wind in Alabama doesn't Blow , it Sucks . . .
Dodgeman
Posted: 02:00am 02 Aug 2008
I'm no expert here but what I have done on mine is cut them off at the point where the reversal occurs on the blade, so as to have your leading edge and your trailing edge fairly even/level at the tip of the blade, like was said, It appears the tips of your blades may be a bit too narrow, so shortening slightly them wont hurt you too much. (possibly to about an inch or so to the right from your "leading edge arrow" in pic #2.
I have also decided not to cut the smaller mounting area at the "hub end" of the blade, I have had them break off in high wind, which landed me a set of shorter blades after cutting them off.
I think the strength is comprimised when "notched" for mounting to the hub and with the extra forward facing part of blade near the center not cut away, I havent noticed much (if any) difference in how it spins.
You can see the pics of my little backyard built pvc bladed mills in this thread - not very clear pics of the blades but they may help http://www.thebackshed.com/Windmill/FORUM1/forum_posts.asp?T ID=1167&PN=1
If nothing else, I have learned that pvc blades are cheap and easily replaced, Also while building mine, I used a cheap hand plane to help create proper looking leading and trailing edges by shaving the edges down.
feix62k
Posted: 01:51am 24 Aug 2008
anbody got any links or pics of blades for the f and p windmill pvc or wood ,how do I get back to the fisher and pakel windmill design/plan site Ive lost the link thanks felix
dont the days seem lank and long when nothing gos right and everthing gos wrong
