Local Time 05:37 25 Oct 2026 Privacy Policy
Forum Index : Windmills : guy cables
imsmooth
Posted: 03:50am 18 Jun 2008
I have found steel cables and synthetic cables. The latter is described as being lighter, stronger and safer (no recoil if broken) than steel cable. Has anyone tried these or have any thoughts on using systhetic rope instead of steel cables?
Gill
Posted: 04:21am 18 Jun 2008
Yes I've read all the wonderfull properties of the synthetic cables when I was playing with antennas. If you have shares in an armoured car business and can afford to deliver the $$$$$$$$s then great. But why do you feel a windmill needs non conducting/parasitic resonant guy wires????
Cheers Gill _Cairns, FNQ
GWatPE
Posted: 07:04am 18 Jun 2008
I see no point with synthetic guying cables either. I can see problems down the track with UV exposure etc. You would have to use spectra, or kevlar with nylon sheath. I see other problems with terminations. Corrosion resistance would be a plus if the tower was in an ocean spray zone. .. Gordon.
become more energy aware
