Local Time 19:44 24 Oct 2026 Privacy Policy
Forum Index : Windmills : LG 36 pole 24v x 2? + setup
druist
Posted: 09:36pm 22 Jun 2018
have 3 x LG rotor stators and was going to build 1 savonius style vawt and a hawt. For the vawt i saw someone putting one drive stator on the top and one on the bottom, will this make a difference? Physics-wise i am told it wont. Anybody?
Also, is there a gain of buying expensive charge controllers and inverters or do the cheaper ones work ok,i have a 1600w that i suspect is chinese as it was £30
The charge controller = https://goo.gl/8V9FsC
2 x 110 lead acid type 12v batteries
Am doing this at my allotment to run pumps fans and lights and have 300w in solar panels which might be ok when its sunny in the uk, but most of the time it isnt.
Also, according to the forum my savonious would be ok for 24v on factory wiring as it would not be very windy, may look at gearing.
thanks GUYS.
