Forum Index : Windmills : VAWT Revisited
MacGyver![]() Guru Joined: 12/05/2009 Location: United StatesPosts: 1330 |
I know vertical axis wind turbines are not the hot topic on this form, but you have to admit one thing. They are fun to watch as they spin in the wind. To that end, I have built a new VAWT And I shot a video of it and posted it to my YouTube channel. That’s about as far as I got. I no longer have a computer, only an iPhone and I haven’t figured out yet how to post the video here on the forum, so those of you who have tucked away my YouTube video address in your files someplace, you can go there and watch my new VAWT perform. In a not shell, it is a Marconi-rigged sail stitched from Dacron and placed on a mast and boom with an outhaul. The counterweight provides momentum, which drives the mechanism through the LUFF point of its travels, About 90°. You may recognize the red sail from a previous video, which featured a Radio controled sailcar. Same sail. Future builds will feature TWO sails, shorter masts and a mechanism connected to the opposite side of the shaft, which is nothing more than a bicycle hub, which will drive in air compressor. My true passion is building small engines, which operate on compressed air, hence my windmills all pump air into a receiver. Nothing difficult is ever easy! Perhaps better stated in the words of Morgan Freeman, "Where there is no struggle, there is no progress!" Copeville, Texas |
If this works, I’ll drop back by and edit it into a hot link. https://www.youtube.com/user/TheBackshedMac AMAZING! It wirks. It’s the first video in the playlist. It’s a red sail whirling around. Nothing difficult is ever easy! Perhaps better stated in the words of Morgan Freeman, "Where there is no struggle, there is no progress!" Copeville, Texas |
Advantages to this design: Self starting Airfoil automatically adjusts for maximum lift Tremendous torque —— depending on the moment arm, which is the distance from the sail root to the pivot point. Easily constructed Some of us think they look cool . I am planning on manufacturing approximately 20 of these, with the exception that the new ones will have two sails each. Since I use a front bicycle hub for the bearing, I can put the windmill portion on the top and either a belt or chain gear reduction on the bottom and run it against a tiny air compressor. All 20 air compressers will feed my common receiver, which has a capacity of about half a good size swimming pool. Like I said, my true passion is designing and building small engines, which run on compressed air. I am currently working on a small generator, which produces approximately 15 V and 1 1/2 A, which can be used to recharge a car battery, should you so desire. Nothing difficult is ever easy! Perhaps better stated in the words of Morgan Freeman, "Where there is no struggle, there is no progress!" Copeville, Texas |
It is fun to watch. If you crafted a little boat to go under the sail, you will sell hundreds of them at flea markets. Glenn The best time to plant a tree was twenty years ago, the second best time is right now. JAQ |
That’s a good idea, but I don’t chase money. It’s chases me. I just do this stuff to entertain myself, but thank you for the suggestion. Nothing difficult is ever easy! Perhaps better stated in the words of Morgan Freeman, "Where there is no struggle, there is no progress!" Copeville, Texas |
| electrondady1 Senior Member Joined: 12/02/2009 Location: CanadaPosts: 208 |
first one like that Ive seen . congratulations. |
