Local Time 19:44 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Low-Cost Small-Scale Wind Power Generator
DaveP68
Posted: 03:43am 25 May 2018
Found this document published in 2009 by David Michael Whaley which was his PhD Thesis submitted to The University of Adelaide.
Low-Cost Small-Scale Wind Power Generation
Contains lots of detailed information relating to the use of F&P stators as the PMA on small scale Wind Turbines. Bit of a marathon to get through, but worth the effort.
