Local Time 20:10 24 Oct 2026 Privacy Policy
Forum Index : Windmills : 36 pole delta wiring
bennyspoon
Posted: 07:11am 20 May 2018
Hi guys, I've read through the rewiring page and it appears that all of the wiring diagrams for the 36 pole stators are for star.
Has anyone done any diagrams for the various 36 pole stators in delta?
Am i correct in thinking that eg 2x6c i need to run another 3 wires and connect the 3 poles represented at the dot at the bottom to the 3 poles represented at the dot at the top, then combine these 3 wires with x,y,z?
Thanks,
Ben.Edited by bennyspoon 2018-05-21
DaveP68
Posted: 11:01am 21 May 2018
Hi Ben
Here is a photo of a 2x6c wired in delta connected to a capacitor doubler.
Hope this is of help as I don't have any drawings to post.
David
bennyspoon
Posted: 09:09am 24 May 2018
Thanks David,
that makes it a bit clearer.
