Local Time 20:11 24 Oct 2026 Privacy Policy
Forum Index : Windmills : Low Wind F&P
ryanm
Posted: 02:54am 27 Apr 2018
I'm in a fairly average area for wind, but I'm going off-grid and I'd like to utilise what little I can to help out my battery bank.
There's lots of info on the site with RPM/power graphs, but I haven't seen much on windspeed/power graphs so I though I'd float this out there and see how I go. From your experiences do you think I could achieve around 50W from an extruded aluminium blade F&P in 5m/s winds?
fillm
Posted: 03:05pm 27 Apr 2018
Rynam,
As I have the extruded blades and know them well the 5 M/S is getting to the area where you would be easily seeing 100 to 200W dependant on the blade size chosen and off course how you rewire the stators . In a dual I have always gone with 42Pole / 80 series but the newer 36 poles and blacks are also good.
It comes down to what you get your hands on .
I have a whole new range of Dual F&P's I have been slowly designing over that last 6 or so months, and also the solution to easier use of The LG motors as duals as well that fit my F&P Dual mounting system. I will put some pics and info up in the coming month, time permitting.
Madness
Posted: 09:22pm 27 Apr 2018
What sort power output is reasonable to expect from the LG motors. I have one from a 10KG front loader that I am planning to use for hydro.
DaveP68
Posted: 10:50pm 27 Apr 2018
Personally I haven't tested an LG stator.
Here is an extract from "EcoInnovation Smart Drive Applications for DIY projects" document.
"The history of the Smart Drive
The Smart Drive was designed over 25 years ago and was the 1st direct drive motor for mass produced washing machines. It was also injection moulded from plastic, never before done on a motor this large subject to high torque reversals.
Since its inception it has undergone four design changes for higher voltage applications, but remains little changed in appearance. It is still in manufacture today and installed on many leading brand washing machines such as:
Fisher & Paykel
Whirlpool
Maytag
Haier
Other companies such as LG have also copied this design, but as they run with large clearances and do not use laminated steel rotors or high strength ferrites these units have a much lower power density and efficiency. In other words they are inferior products".
I'll go with what Michael has stated here, as he's done extensive testing on mostly F&P stators and know his stuff.
If anyone can publish some data comparing the performance of an LG stator against an F&P, I would be very interested to see the results.
ryanm
Posted: 03:18am 28 Apr 2018
Thanks Phill,
Sent an email to the address on your site probably a few months ago, but I think it must have went to spam. I think I'll have my hands full for a while once Madness gets these inverter boards sent out. I'll definitely get in touch at some point later about getting some blades or a full mill though.
