Local Time 17:59 24 Oct 2026 Privacy Policy
Forum Index : PCB Manufacturing : 2.4" ILI9341 Display part...
Zonker
Posted: 01:51pm 10 Aug 2017
I have some of these "raw" displays and wanted to have a go at getting
a PCB "engine" built around it... Just getting started...
2017-08-10_234810_2.4in_240x320_COLOR_LCD_DISPLAY_-_ILI9341_3.3v_18pin.zip
The part sits on the top layer and the flex interface connections are wrapped
to the back side... BTW: - this is a DEX part...
(part shown does not have the touch pad on it, but it is on the interface pads)
Edited by Zonker 2017-08-12
Posted: 04:37pm 16 Aug 2017
GDay Zonker,
I am interested in what you can make of that... The thing I do not like about the backpack ideas is the thickness of the plug-on PCB board.. If you come up with a micromite board with this interface included..
Quazee137
Posted: 06:01pm 26 Aug 2017
Zonker I was going to have a look but the file is bad.
upzipped I get another zip that also gives another zip
2.4in 240x320 COLOR LCD DISPLAY - ILI9341 3.3v 18pin.part
Looking forward to checking it out.
Quazee137
