Local Time 18:39 24 Oct 2026 Privacy Policy
Forum Index : PCB Manufacturing : Small run pcb manufacturers
noneyabussiness
Posted: 01:08pm 08 Aug 2017
Hi All, long time reader, first time poster...
Just curious on small run (5 - 10) pcb manufacturering and if anyone has any suggestions for the better ones (cost, quality etc.) Google search gives heaps but i was hoping for a experienced push in the right direction.
Thanks in advance,
Glen
I think it works !!
Warpspeed
Posted: 01:40pm 08 Aug 2017
Its pretty competitive, and the Chinese can beat anyone on price.
It also depends what format your PCB design package outputs.
The industry standard these days are Gerber files in RS274X (or X2) format, but a lot of free software that has been around for a while, often outputs in other less common file formats that not all the PCB manufacturers can use or be bothered with.
So free PCB software may limit your choices of PCB manufacturer. Another consideration might be minimum track widths and clearances.
Anything that requires extra special care in manufacture beyond the normal production standard is going to cost you extra.
Cheers,  Tony.
Posted: 03:20am 09 Aug 2017
Welcome to the forums.
I have used PCB GoGo for ages now, and they are quick, easy and cheap as chips. Only five bucks for ten 100x100 double-sided boards from them now! Gotta be one of the cheapest you can find.
Warpspeed
Posted: 01:01pm 09 Aug 2017
If you enter ten 100 x 100 boards delivered to Australia using their quotation system it comes to $30 US which is about $40 Australian. Its a bit more than five dollars.
I use PCB Way https://www.pcbway.com/orderonline.aspx
Ten 100 x 100 boards delivered to Australia $28 Us or $38 Australian.
Both located in China, very cheap, very competitive, there are plenty of other alternatives, but the difference between them will be very slight.
Cheers,  Tony.
noneyabussiness
Posted: 01:44pm 09 Aug 2017
Awesome thankyou for your responses ...
I think it works !!
Warpspeed
Posted: 01:57pm 09 Aug 2017
The minimum order quantity is almost always five boards. The difference between ordering five or ten boards is very slight, because most of the cost is in setting up and delivery costs.
Once the fully automated robot production machinery is set up to go, it hardly makes any difference to the PCB manufacturer how many you order. The only extra cost is for the extra materials and chemicals, which is not much. So making only one board is just not practical.
If you place an order via the internet you should have the boards in your hand usually in about seven or eight days.
The only things that have caused me trouble in the past have been the type of files my original crappy PCB software generated, and method of payment. Things have improved greatly over the last few years in both these two areas. The Chinese are pretty smart at business, and are now much more flexible with what they can do.
Cheers,  Tony.
Alastair
Posted: 02:36pm 09 Aug 2017
I recently used Elecrow in China. Fully automated online. Board cost was A$5 for 5 boards 2 layer, 100x100mm max. Job done in 3 days. Freight is the catch. $25 for DHL 4-7 days, or $7 for registered airmail 7-25 days. I used airmail and they arrived in 10 days.
Board quality was good. I will use them again.
whole new world by comparison to the messy home make which I used to do years ago.
cheers
Cheers, Alastair
Posted: 03:45pm 09 Aug 2017
  Warpspeed said   If you enter ten 100 x 100 boards delivered to Australia using their quotation system it comes to $30 US which is about $40 Australian. Its a bit more than five dollars.
Well, if you include the shipping, yes.
I was only talking about the cost of the PCB's, not the freight.
Freight varies from place to place, but they are all quite expensive, so I never mention the freight cost - that is not what it actually costs to make the boards.
If you use airmail, it is $17 bringing the total to $22 to Australia, but for the extra I always use DHL, then the boards are here very quickly.
Warpspeed
Posted: 03:52pm 09 Aug 2017
My most recent purchase (last week) thirty boards 82 x 47 eight days delivery by DHL total cost $73 Australian. Excellent quality boards too.
Cheers,  Tony.
HankR
Posted: 08:47am 16 Oct 2017
I just tried Grog's GOGO outfit for a quote 75mm x 100mm going to US.
I saw DHL and Hong Kong Post as the options. Well, there was another "talk to us."
Is Hong Kong Post airmail?
Warpspeed
Posted: 10:37am 16 Oct 2017
Don't know about Hong Kong Post, but China Post is by container ship to Australia. Its just a cheap surface bulk mail service, delivered by your local postman.
Its usually about ten dollars cheaper than DHL, but can take take about four to six weeks instead of three to four days by DHL.
Cheers,  Tony.
