Local Time 18:13 24 Oct 2026 Privacy Policy
Forum Index : PCB Manufacturing : Headphone Jack Schematic Question
MM_Wombat
Posted: 01:37pm 06 Aug 2016
Hi all,
The datasheet for the Texas Instruments TPA6012A4 Audio amp shows a typical circuit for the device(Figure 21). The headphone socket in the circuit shows a 4 contact headphone socket, but all I can seem to find is 5 contact versions.
from datasheet
I assume typical 5 contact
Do I just tie pins 3 and 4 together.
This is to mute stereo speakers when headphones are inserted.
Regards MMWombat
Maximite, ColourMaximite, MM+
Posted: 01:43pm 06 Aug 2016
I would start with ignoring pin 4, leaving it open circuit.
That way it replicates the top schematic - only one channel used for mute detect.
MM_Wombat
Posted: 01:45pm 06 Aug 2016
Thanks Jim
Now All I have to do is add the part into dex
Regards MMWombat
Posted: 09:09pm 07 Aug 2016
Hi Wombat,
Is that a 3.5mm or 6.5mm Socket?
Kind Regards,
MM_Wombat
Posted: 10:16pm 07 Aug 2016
@ bigmik
That was a 3.5 mm version.
Was going to order some through ebay, then map those into dex, so I know the footprint fits.
For a shield I should probably go SMT, rather than through hole.
Once I get the schematic finished I might get you to check it for me, if that is ok, haven't built too many boards before.
Successfully added the Keystone 8650C Module into the dex library, so a headphone jack should be easy.
When ordering the caps, should I just get tantalums for everything?
Regards MMWombat
