Forum Index : PCB Manufacturing : Are there any packages that will import an eagle 5.9 board ?
| zeitfest Guru Joined: 31/07/2019 Location: AustraliaPosts: 702 |
Are there any PCB design packages that will import an eagle 5.9 board ? I used to use eagle 5.9 for boards (without eagle schematics) so ... AFAIK Fusion 360 will only use 6.0 files or later |
Zeitfest, If you can send me the file I can try in DEX for you DEX is supposed to be able to import Eagle files but I am not sure which version. Regards, Mick . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
Thanks Mick, I've asked DEX about it so will wait on events |
Zeitfest, No worries, it has an import of eagle in its menus, I have never imported an eagle project but I have imported an eagle library. If you need any assistance to check the process let me know. Regards, Mick (The big one) . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
I asked DEX and they say it requires the eagle XML files so that means eagle 6 and later. Curses ! |
Hi Zeitfest, Maybe someone on TBS has eagle v6 or later and can import it and save it as a newer version. I think I read that eagle was now defunct but I am not sure if it can still be downloaded anywhere, maybe try it. Regards, Mick . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
| PhenixRising Guru Joined: 07/11/2023 Location: United KingdomPosts: 2100 |
This just worked for me, Mick. I downloaded "Autodesk_EAGLE_9.6.2_English_Win_64bit.exe" It didn't run at first, just the splash screen and then it died. It's a known problem and the fix is to replace two DLLs. Imported and re-saved an old Eagle project and it loaded straight into DEX. |
Excellent Phoenix, I am glad it worked well for you. Regards, Mick . Mick's uMite Stuff can be found >>> HERE (Kindly hosted by Dontronics) <<< |
