Local Time 17:32 24 Oct 2026 Privacy Policy
Forum Index : PCB Manufacturing : 44-pin PIC32MX170F256D
SYM-1
Posted: 12:26am 14 Apr 2023
Has anyone created a part for the 44 pin micromite for AutoTRAX.  If not, is there a bit of a tutorial on creating new parts anywhere?
Persistence is the key
Posted: 04:13am 16 Apr 2023
Hi SYM-1,
Here is one I did a long time ago,
PIC32MX170F256D.part.zip
I never actually used the part and it is only in its most basic rudimentary design and has only pin numbers not pin names and I am unsure if it has a 3d Model associated with it (not needed its just eye-candy).
Hopefully the part is correct but I cant take responsibility for its accuracy.
I advise you to use the part and check dimensions and pin numbering carefully.
I `think' it is OK but not having used it in a design I need you to check it before you commit to copper.
Kind Regards,
