Local Time 17:46 24 Oct 2026 Privacy Policy
Forum Index : PCB Manufacturing : PCB assembly and manufacture suggestions
pcbrookie
Posted: 07:45pm 22 Oct 2018
I recently put a small pcb project together and have had a company create the PCB gerber files for me.
From here i don't know what step is next to get the PCB built. I'm an electrician and i would be ordering more and more over time. This is a hobby at the moment so i need a prototype to try out and see if its viable. Do you do this or know of anyone that does?
it involves a 3G/4g GSM module, a battery back up ( I hope can be in built) and a sensor to detect power. I dont really know how the process works.
Thanks! Phil
Chopperp
Posted: 07:03am 23 Oct 2018
Hi Phil, Welcome
Checkout this post. It may help. Others may chime in with better advice
Here
BrianEdited by Chopperp 2018-10-24
ChopperP
Posted: 12:03am 24 Oct 2018
Hi Phil,
I use Shenzhen2U.com
Its $9.90US for PCBs upto 10cm x 10cm and you get 10 panels of each.
Cheapa$$ postage to AUS is typically around $11US so it works out about $30Aus all up..
Expect about 1 month delivery though altough I have had 12 days and also about 6 weeks..
You can pay extra for expedited manufacture and delivery but that is up to you.
Kind Regards,
