Forum Index : Microcontroller and PC projects : CMM IR problem
| antf70 Newbie Joined: 13/07/2016 Location: AustraliaPosts: 20 |
Hi All, Is there a problem with IR interrupts when CHAINing programs on CMM firmware v4.5? |
I have not tested this but there could easily be an issue. Looking at the source the CHAIN command disables interrupts on I/O pins but not the IR interrupt. So you should specifically use IR CLOSE before invoking CHAIN. Geoff Geoff Graham - http://geoffg.net |
