Local Time 13:44 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Useful, cheap LDO regulator....
Posted: 02:56pm 15 Sep 2017
Hello folks.
While wading through the Microchip MAPS(Microchip Advanced Parts Selector) for a few things, I came across these very interesting looking LDO regulators:
MCP1755 LDO Regulator with PwrGood and Shutdown pins
They have a wide Vin of 3.6v to 16v, 300mA output current, standard output voltages of 1.8V, 2.5V, 3.0V, 3.3V, and 5.0V, 68 microamp quiescent current, only needs 1uF caps, True Foldback Current Protection, Short-circuit protection, Over-temperature protection and has PowerGood and ShutDown pins on the 5-pin versions of the device.
The latter two are very useful to have in many situations, but mainly the ShutDown pin I expect, as this allows the Micromite to switch the regulator off and on at will. In my case, I have projects where I use RF modules that sometimes don't have enable or sleep lines, and a regulator like this can do that job for you, along with supplying the needed voltage to the module, and is neater then using the MOSFET+NPN+Pullup method I have been using up until now.
The PowerGood pin could be used to let the Micromite know something had gone wrong with a device being powered from that regulator, if it tried to suck too much current or something.
Only 66c each. If you buy 26 or more, they drop to only 56c each!
erbp
Posted: 03:30pm 15 Sep 2017
RS Components in Oz sell these at AU$1.00 for the 3.3v version (min qty 10) and AU$1.21 for the 5.0v version (min qty 6). They do free shipping (within Australia) on orders placed via the web.
I haven't used these devices but they do look interesting.
Phil.
Edit: To clarify - RS Components only stock the MCP1755S versions - these are the 3 pin versions that do NOT support the Power Good and Shutdown signals. Also the prices quoted above include GST, the prices on their website are ex GST.Edited by erbp 2017-09-17
Posted: 08:02pm 15 Sep 2017
things have come a long way since the 78xx series 68uA(!)Edited by CaptainBoing 2017-09-17
lew247
Posted: 05:21am 16 Sep 2017
Really nice
The only limitation is
[quote]300 mA Output Current for all output voltages[/quote]
Ideal for micromite but if you want to power other devices such as an Esp8266 no good you'd need another reg too
Posted: 07:55pm 17 Sep 2017
Agreed. I tend to fall back on the LM1117 series of regulators, which you can get in several preset voltages, and they can do 800mA or so, and they come in a nice TO-252 package which is small, but still able to pass reasonable current and uses the PCB as a heatsink.
Posted: 08:12pm 17 Sep 2017
If you want a means of switching power rails, look at the SY6280
It has adjustable current limiting and an enable pin.
Not a regulator and can switch 2.4 to 5.5 Volts.
Bought some to play with but still in the gunna-do pile.
Posted: 09:10pm 17 Sep 2017
  TassyJim said   ..... but still in the gunna-do pile.
I love that choice of wording
Posted: 03:26pm 20 Sep 2017
These seemed like a great deal till I went to buy them, and if you want less then a full reel(4000), it costs you US$10 re-reeling charge per part, so for two types of regulator, that adds US$20 to the cost which is substantial, really, and then freight on top of that.
Not quite so attractive anymore.
For the HC12 power switching I was planning to use them for, I think I will just reassign the pin I was going to use for the regulator shut-down line, to the SET line on the HC12, and software-sleep the module instead.
redrok
Posted: 01:49pm 23 Sep 2017
Hi Grogster;
  Grogster said   Hello folks.
Just a heads up on this regulator.
The spec calls for a minimum load current of 1mA for the voltage to stay within specification. So when running at 3.3V there should be a 3.3K resistor from VCC to GND.
This may be a problem if you want to run at extremely low power consumption.
Check "Note 2" in the speck sheet.
I see this in quite a few LDO regulators.
There are some that are specked to 0mA loads though.
redrokEdited by redrok 2017-09-24
