Grogster Admin Group Joined: 31/12/2012 Location: New ZealandPosts: 10076
Posted: 03:40am 31 Aug 2017
Hi there.
Why won't this work:
[Code] Dim As Float x x=0.5 Do 'Servo 1,x Print x Pause 100 X=X+0.1 If X=2.5 Then Exit Do Loop Print "Done." [/Code]
I want it to exit the loop when X=2.5, but it does not - X just keeps getting bigger.
As you can see, I am playing with servo motors. I am just trying to slow-up the servo arm movement so the changes are more gradual rather then sudden. I have tried with and without the DIM statement, but X gets away up to 6.5 or more and just keeps going, and I have to CTRL-C stop it. I would have expected that once X was 2.5, the loop would end and 'Done.' would get printed to the console.
I've commented out the servo command, cos the servo did NOT like figures higher then 2.5.....Smoke makes things work. When the smoke gets out, it stops!
CaptainBoing Guru Joined: 07/09/2016 Location: United KingdomPosts: 2171
Posted: 03:53am 31 Aug 2017
I suspect rounding errors on anything like this - would it be possible to change it to work with integers and just divide down at the point of use?
maybe x gets to 2.500001 (or similar) and this causes your test to fail, so if you went up in wholes and tested for 25 it would avoid any maths errors.
That's what i would try first
my 2pEdited by CaptainBoing 2017-09-01
twofingers Guru Joined: 02/06/2014 Location: GermanyPosts: 1784
Posted: 04:44am 31 Aug 2017
I think, CaptainBoing is correct!
If X=>2.5 Then Exit Do
will do the job.
Even better:
Dim As Float x x=0.5 Do 'Servo 1,x Print x Pause 100 X=X+0.1 Loop While X<=2.5 Print "Done."
Regards Michael
JohnS Guru Joined: 18/11/2011 Location: United KingdomPosts: 4391
Posted: 05:02am 31 Aug 2017
Yes, it's that.
This is due to the way floating point works on all computers that use it (i.e. nearly all of them).
It's been covered before on here (and is on the net of course) if you want to read up more.
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12083
Posted: 05:42am 31 Aug 2017
Not good enough - still making an assumption
try:
ABS(X-2.5)<0.000001 'any small number that works
Posted: 06:23am 31 Aug 2017
anyway, I think this shows that integers are the first choice for exit conditions. Michael
Posted: 03:21am 01 Sep 2017
Awesome, thanks for the pointers.
Bloody floating point numbers come around to wreck my life again once more.....
This test code is working fine for slow movement of the servo arm:
[Code] TEST2: Dim As Float X Do Print "Start." X=0.5 Servo 1,x Pause 1000 'Allow servo to move Do Servo 1,x Print X Pause 1000 X=X+0.05 If X>=2.5 Then Exit Do Loop Print "Done." Pause 2000 Loop [/Code]
This does nothing useful at the moment - I am just playing with an idea.Smoke makes things work. When the smoke gets out, it stops!
MicroBlocks Guru Joined: 12/05/2012 Location: ThailandPosts: 2209
Posted: 05:17am 01 Sep 2017
I had a play with some servos before. The way i did it was to setup a timer tick that called a subroutine that did the same as your do while but then only one iteration for each timer tick. You can then remove the pause, this is good if you need a response foreground process, especially when you have a touchscreen or buttons. Moving the servos will then not interfere with other parts of the program as it runs in the background. I tried to find the code i used but as it was only a test i did not save it. Microblocks. Build with logic.
