Local Time 12:37 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Continuing Code on 2nd line.
KeepIS
Posted: 05:58pm 11 Aug 2017
Is there an editor line formatting character that MM.Basic will recognises and allow breaking a single line of code over two lines to make it readable in the inbuilt editor?
Mike.
Phil23
Posted: 06:11pm 11 Aug 2017
No.
Not sure what Geoff's stand on this is;
Could be very useful, but understand there may be reasons for it's non-existence.
Phil.
KeepIS
Posted: 06:16pm 11 Aug 2017
Thanks for the quick reply, saved me a lot of wasted time.
Mike.
Posted: 07:48pm 11 Aug 2017
No, there is not a line continuation character (it would be handy). The reason is that BASIC is line orientated and it is difficult for its syntax to manage a break in the middle.
BUT, the easy way to edit long lines is to just position the cursor near the end of the line and hit return so that the line is split. You can then edit both halves and when finished delete the line break so that the line reverts to a single long line.
The editor was originally designed to support automatic horizontal scrolling but the screen update was too slow so that feature never made it into production.
GeoffEdited by Geoffg 2017-08-13
KeepIS
Posted: 07:51pm 11 Aug 2017
Thanks Geoff, makes sense, and I already do that trick with the cursor.
Mike
