Local Time 10:41 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DIR$ on 5.0404
MikeO
Posted: 07:54pm 06 Aug 2017
Hi can anyone confirm, it looks like the DIR parameter for the folder listing on DIR$ is broken on ver 5.0404.
If i run the following I get nothing when there are folders.
f$ = DIR$("*.*", DIR)
DO WHILE f$ <> ""
PRINT f$
f$ = DIR$()
LOOP
with Files command or with DIR$("*.*", FILE) in the above code it OK.
>Files
A:/
<DIR> 070817
<DIR> mike
100015 empty.txt
10 espnode.dat
4061 flowcode.txt
3 lingcode.txt
100015 logfile.txt
0 New Text Document.txt
12928 TEMP.BAS
0 TEST10.TXT
0 TEST11.TXT
0 TEST12.TXT
0 TEST3.TXT
0 TEST5.TXT
0 TEST7.TXT
0 TEST9.TXT
16 wifiname.dat
10 wifipass.dat
2 directories, 16 files
Running the Code
TEST12.TXT
TEST10.TXT
empty.txt
logfile.txt
TEST11.TXT
TEST7.TXT
TEST9.TXT
TEST5.TXT
TEST3.TXT
TEMP.BAS
lingcode.txt
flowcode.txt
wifiname.dat
wifipass.dat
espnode.dat
I need this function unfortunately
Edited by MikeO 2017-08-08
Codenquilts
Posted: 08:44pm 06 Aug 2017
Try using "*" not "*.*"
MikeO
Posted: 11:02pm 06 Aug 2017
YEP That fixed it, Thank you Mike
Codenquilts
MikeO
Posted: 12:46am 07 Aug 2017
Geoff, Peter, just a thought, if this is going to be a permanent change the documentation will need changing to reflect the new "wildcard" format.
Mike
Codenquilts
Posted: 04:49am 07 Aug 2017
This is not a "change" or a "new format". The command is doing what it should.
With *.* you are specifying two wildcards with a period in the middle. Your directory names did not have an embedded period so they did not match the search pattern.
I agree that DIR$("*.*", FILE) returning all files/directories is inconsistent and confusing. Perhaps the manual entry should go into more detail regarding wildcards.
GeoffEdited by Geoffg 2017-08-08
MikeO
Posted: 12:01pm 07 Aug 2017
Thanks for the clarification Geoff you are correct regarding a directory listing not normally having a period. I was caught a little as this was part of an old program and on previous versions of mmbasic had always worked.
Mike
Codenquilts
