Local Time 13:45 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX/RPI/DOS - repeating groundtrack orbit
cdeagle
Posted: 12:50am 06 Aug 2017
This post describes a MMBASIC computer program called repeat3.bas that can be used for the preliminary design of repeating groundtrack orbits. These types of orbits are useful for remote sensing and other special applications since they overfly the same points on the Earth’s surface every repeat cycle. Repeating ground track orbits are usually specified by an integer number of days N and integer number of orbits K in the repeat cycle.
This program calculates the mean semimajor axis required for a repeating ground track orbit using an algorithm devised by Carl Wagner. This iterative numerical method is described in “A Prograde Geosat Exact Repeat Mission?”, The Journal of the Astronautical Sciences, Vol. 39, No. 3, July-September 1991, pp. 313-326.
Here's a typical user interaction with the software and the displayed results.
program repeat3
repeating ground track - Wagner's method
please input the mean orbital eccentricity (non-dimensional)
(0 <= eccentricity < 1)
? 0
please input the mean orbital inclination (degrees)
(0 <= inclination < 180)
? 108
please input the number of orbits in the repeat cycle
? 271
please input the number of nodal days in the repeat cycle
? 19
program repeat3.bas
mean semimajor axis 7192.2303 kilometers
mean eccentricity 0.0000000000
mean inclination 108.0000 degrees
orbits to repeat 271
solar days to repeat 19.0548
Keplerian period 101.1708 minutes
nodal period 101.2507 minutes
length of nodal day 1444.1545 minutes
fundamental interval 25.2399 degrees
Here's the MMBASIC source code
' program repeat3.bas August 3, 2017
' determine mean semimajor axis required
' for a repeating ground track orbit
' Wagner's algorithm
' MMX/RasPi/DOS versions of MMBASIC
option default float
option base 1
' astrodynamic and utility constants
const pi2 = 2.0 * pi
' conversion factor - degrees to radians
const dtr = pi / 180.0
' conversion factor - radians to degrees
const rtd = 180.0 / pi
' Earth gravitational constant (km**3/sec**2)
const xmu = 398600.4415
' equatorial radius of the Earth (kilometers)
const req = 6378.14
' first zonal coefficient (non-dimensional)
const xj2 = 1.08262668355e-3
' Earth rotation rate (radians/second)
const omega = 7.29211564186e-05
print " "
print "program repeat3"
print " "
print "repeating ground track - Wagner's method"
print "----------------------------------------"
' request mean orbital elements
do
print " "
print "please input the mean orbital eccentricity (non-dimensional)"
print "(0 <= eccentricity < 1)"
input ecc
if (ecc >= 0.0 and ecc < 1.0) then exit do
loop
do
print " "
print "please input the mean orbital inclination (degrees)"
print "(0 <= inclination < 180)"
input xdata
if (xdata >= 0.0 and xdata < 180.0) then exit do
loop
xinc = dtr * xdata
do
print " "
print "please input the number of orbits in the repeat cycle"
input xnorbits
if (xnorbits > 0) then exit do
loop
do
print " "
print "please input the number of nodal days in the repeat cycle"
input xndays
if (xndays > 0) then exit do
loop
c20 = -xj2
' calculate initial guess for semimajor axis (kilometers)
a0 = xmu^(1.0 / 3.0) * ((xnorbits / xndays) * omega)^(-2.0 / 3.0)
aold = a0 * (1.0 - c20 * (req / a0)^2 * (4.0 * cos(xinc)^2 - (xnorbits / xndays) * cos(xinc) - 1.0))
do
slr = aold * (1.0 - ecc * ecc)
tmp1 = xmu^(1.0 / 3.0) * (xnorbits * omega / xndays)^(-2.0 / 3.0)
tmp2 = (1.0 - 1.5 * c20 * (req / slr)^2 * (1.0 - 1.5 * sin(xinc)^2))^(2.0 / 3.0)
tmp3 = (1.0 + c20 * (req / slr)^2 * (1.5 * (xnorbits / xndays) * cos(xinc) - 0.75 * (5.0 * cos(xinc)^2 - 1.0)))^(2.0 / 3.0)
anew = tmp1 * tmp2 * tmp3
if (abs(anew - aold) < 1.0e-6) then
' converged to within tolerance
exit do
else
' continue iteration
aold = anew
end if
loop
sma = anew
' Keplerian period (seconds)
tkepler = pi2 * sma * sqr(sma / xmu)
' keplerian mean motion (rad/sec)
xmm = sqr(xmu / (sma * sma * sma))
' orbital semiparameter (km)
slr = sma * (1.0 - ecc * ecc)
b = sqr(1.0 - ecc * ecc)
c = req / slr
d = c * c
e = sin(xinc) * sin(xinc)
' perturbed mean motion (rad/sec)
pmm = xmm * (1.0 + 1.5 * xj2 * d * b * (1.0 - 1.5 * e))
' argument of perigee perturbation (rad/sec)
apdot = 1.5 * xj2 * pmm * d * (2.0 - 2.5 * e)
' raan perturbation (rad/sec)
raandot = -1.5 * xj2 * pmm * d * cos(xinc)
' nodal period - time between nodal crossings
tnode = pi2 / (apdot + pmm)
' delta longitude per nodal period (radians)
dlong = tnode * (omega - raandot)
' length of nodal day (seconds)
tnday = pi2 / (omega - raandot)
' number of solar days to repeat
xnsdays = tnode * xnorbits / 86400.0
' print results
print " "
print "program repeat3.bas"
print " "
print " "
print "mean semimajor axis ", str$(sma, 0, 4) + " kilometers"
print " "
print "mean eccentricity ", str$(ecc, 0, 10)
print " "
print "mean inclination ", str$(rtd * xinc, 0, 4) + " degrees"
print " "
print " "
print "orbits to repeat ", str$(xnorbits)
print " "
print "solar days to repeat ", str$(xnsdays)
print " "
print " "
print "Keplerian period ", str$(tkepler / 60.0, 0, 4) + " minutes"
print " "
print "nodal period ", str$(tnode / 60.0, 0, 4) + " minutes"
print " "
print " "
print "length of nodal day ", str$(tnday / 60.0, 0, 4) + " minutes"
print " "
print "fundamental interval ", str$(dlong * rtd, 0, 4) + " degrees"
print " "
end
Here's a PDF document that describes the computer programs that comprise the repeating groundtrack series.
2017-08-06_104742_repeat.zip
cdeagle
Posted: 10:52am 21 Aug 2017
' repeat1.bas August 7, 2017
' time to repeat ground track
' Kozai analytic orbit propagation
' MMBASIC for MMX, RasPi and DOS
Program example.
program repeat1 - time to repeat ground track - analytic solution
please input the semimajor axis (kilometers)
(semimajor axis > 0)
? 8000
please input the orbital eccentricity (non-dimensional)
? 0.025
please input the orbital inclination (degrees)
(0 <= inclination <= 180)
? 28.5
please input the argument of perigee (degrees)
(0 <= argument of perigee <= 360)
? 120
please input the closure tolerance (degrees)
(a value between 0.1 and 0.5 degrees is recommended)
? 0.1
mean semimajor axis 8000.000000 kilometers
mean eccentricity (nd) 0.02500000
mean inclination 28.500000 degrees
mean argument of perigee 120.000000 degrees
number of orbits to repeat 2027
number of solar days to repeat 166.705086
Keplerian period 118.684693 minutes
nodal period 118.428872 minutes
length of nodal day 1420.446851 minutes
fundamental interval 30.014776 degrees
closure tolerance 0.100000 degrees
actual closure 0.049141 degrees
MMBASIC source code listing.
option base 1
dim ioev%(6), oev1(7), oev2(7), rs(3), vs(3)
' global constants and variables
dim mm, pmm, apdot, raandot, sinc, cinc, slr
' zonal gravity constant (nd)
const xj2 = 0.00108263
' Earth equatorial radius (kilometers)
const req = 6378.14
' Earth gravitational constant (km^3/sec^2)
' Earth inertial rotation rate (rad/sec)
const omega = 7.2921151467e-5
print " "
print "program repeat1 - time to repeat ground track - analytic solution"
' request mean classical orbital elements
ioev%(1) = 1
ioev%(2) = 1
ioev%(3) = 1
ioev%(4) = 1
ioev%(5) = 0
ioev%(6) = 0
getoe(ioev%(), oev1())
do
print " "
print "please input the closure tolerance (degrees)"
print "(a value between 0.1 and 0.5 degrees is recommended)"
input tol
if (tol > 0.0) then exit do
loop
' set true anomaly to ascending node
oev1(6) = -oev1(4)
' calculate initial mean anomaly (radians)
a = sqr(1.0 - oev1(2) * oev1(2)) * sin(oev1(6))
b = cos(oev1(6)) + oev1(2)
eanom = atan3(a, b)
oev1(6) = modulo(eanom - oev1(2) * sin(eanom))
' compute Kozai mean motion and perturbations
t = 0.0
kozai1(1, t, oev1(), oev2(), rs(), vs())
tkepler = pi2 / mm
' nodal period => time between nodal crossings
' initialize
xlong = 0.0
norbits = 0
' increment nodal crossing and look for closure
do
' increment current longitude
xlong = xlong + dlong
' modulo longitude
if (xlong >= pi2) then xlong = xlong - pi2
' increment number of orbits
norbits = norbits + 1
' check for ground track closure
if ((abs(xlong - pi2) <= dtr * tol) or (abs(xlong) <= dtr * tol)) then exit do
loop
' number of days to repeat ground track
ndays = tnode * norbits / 86400.0
' actual closure delta longitude (radians)
delta = abs(xlong - pi2)
if (abs(xlong) < delta) then delta = abs(xlong)
' print results
print " "
print " "
print "mean semimajor axis ", str$(oev1(1), 0, 6) + " kilometers"
print " "
print "mean eccentricity (nd) ", str$(oev1(2), 0, 8)
print " "
print "mean inclination ", str$(rtd * oev1(3), 0, 6) + " degrees"
print " "
print "mean argument of perigee ", str$(rtd * oev1(4), 0, 6) + " degrees"
print " "
print "number of orbits to repeat ", norbits
print " "
print "number of solar days to repeat ", str$(ndays, 0, 6)
print " "
print "Keplerian period ", str$(tkepler / 60.0, 0, 6) + " minutes"
print " "
print "nodal period ", str$(tnode / 60.0, 0, 6) + " minutes"
print " "
print "length of nodal day ", str$(tnday / 60.0, 0, 6) + " minutes"
print " "
print "fundamental interval ", str$(dlong * rtd, 0, 6) + " degrees"
print " "
print "closure tolerance ", str$(tol, 0, 6) + " degrees"
print " "
print "actual closure ", str$(delta * rtd, 0, 6) + " degrees"
print " "
end
sub kozai1(iniz%, t, oev1(), oev2(), r(), v())
' analytic orbit propagation
' Kozai's method - ECI version
' input
' iniz = initialization flag (1 = initialize, 0 = bypass)
' t = elapsed simulation time (seconds)
' initial orbital elements
' oev1(1) = semimajor axis (kilometers)
' oev1(2) = orbital eccentricity (non-dimensional)
' (0 <= eccentricity < 1)
' oev1(3) = orbital inclination (radians)
' (0 <= oev1(3) <= pi)
' oev1(4) = argument of perigee (radians)
' (0 <= oev1(4) <= 2 pi)
' oev1(5) = right ascension of ascending node (radians)
' (0 <= oev1(5) <= 2 pi)
' oev1(6) = mean anomaly (radians)
' (0 <= oev1(6) <= 2 pi)
' output
' final orbital elements and state vector at time = t
' oev2(1) = semimajor axis (kilometers)
' oev2(2) = orbital eccentricity (non-dimensional)
' oev2(3) = orbital inclination (radians)
' (0 <= oev2(3) <= pi)
' oev2(4) = updated argument of perigee (radians)
' (0 <= oev2(4) <= 2 pi)
' oev2(5) = updated right ascension of ascending node (radians)
' (0 <= oev2(5) <= 2 pi)
' oev2(6) = updated mean anomaly (radians)
' (0 <= oev2(6) <= 2 pi)
' oev2(7) = updated true anomaly (radians)
' r = eci position vector (kilometers)
' v = eci velocity vector (kilometers/second)
local b, c, d, e, c1, c2, c3, rmag
local argperi, raani, manomi
' set final orbital elements equal to initial
for i% =1 to 6
oev2(i%) = oev1(i%)
next i%
if (iniz% = 1) then
sinc = sin(oev1(3))
cinc = cos(oev1(3))
mm = sqr(xmu / (oev1(1) * oev1(1) * oev1(1)))
slr = oev1(1) * (1.0 - oev1(2) * oev1(2))
b = sqr(1.0 - oev1(2) * oev1(2))
c = req / slr
d = c * c
e = sinc * sinc
pmm = mm * (1.0 + 1.5 * xj2 * d * b * (1.0 - 1.5 * e))
' raan perturbation
raandot = -1.5 * xj2 * pmm * d * cinc
end if
' set initial values of argument of perigee,
' raan and mean anomaly
argperi = oev1(4)
raani = oev1(5)
manomi = oev1(6)
' propagate orbit
argper = modulo(argperi + apdot * t)
raan = modulo(raani + raandot * t)
manom = modulo(manomi + pmm * t)
oev2(4) = argper
oev2(5) = raan
oev2(6) = manom
' solve Kepler's equation using Danby's method
ecc = oev1(2)
kepler1(manom, ecc, ea, tanom)
oev2(7) = tanom
' position magnitude
rmag = slr / (1.0 + ecc * cos(tanom))
sargper = sin(argper)
cargper = cos(argper)
' argument of latitude
arglat = modulo(argper + tanom)
sarglat = sin(arglat)
carglat = cos(arglat)
sraan = sin(raan)
craan = cos(raan)
' eci position vector
r(1) = rmag * (craan * carglat - cinc * sarglat * sraan)
r(2) = rmag * (sraan * carglat + cinc * sarglat * craan)
r(3) = rmag * sinc * sarglat
' eci velocity vector
c1 = sqr(xmu / slr)
c2 = ecc * cargper + carglat
c3 = ecc * sargper + sarglat
v(1) = -c1 * (craan * c3 + sraan * cinc * c2)
v(2) = -c1 * (sraan * c3 - craan * cinc * c2)
v(3) = c1 * c2 * sinc
end sub
sub kepler1 (manom, ecc, eanom, tanom, niter%)
' solve Kepler's equation for circular,
' elliptic and hyperbolic orbits
' Danby's method
' input
' manom = mean anomaly (radians)
' ecc = orbital eccentricity (non-dimensional)
' output
' eanom = eccentric anomaly (radians)
' tanom = true anomaly (radians)
' niter% = number of algorithm iterations
local ktol, xma, s, c, f, fp, fpp, fppp
local delta, deltastar, deltak, sta, cta
' define convergence criterion
ktol = 1.0e-10
xma = manom - pi2 * fix(manom / pi2)
' initial guess
if (ecc = 0.0) then
' circular orbit
tanom = xma
eanom = xma
return
elseif (ecc < 1.0) then
' elliptic orbit
eanom = xma + 0.85 * sgn(sin(xma)) * ecc
else
' hyperbolic orbit
eanom = log(2.0 * xma / ecc + 1.8)
end if
' perform iterations
niter% = 0
do
if (ecc < 1.0) then
' elliptic orbit
s = ecc * sin(eanom)
c = ecc * cos(eanom)
f = eanom - s - xma
fp = 1.0 - c
fpp = s
fppp = c
else
' hyperbolic orbit
s = ecc * sinh(eanom)
c = ecc * cosh(eanom)
f = s - eanom - xma
fp = c - 1.0
fpp = s
fppp = c
end if
niter% = niter% + 1
' check for convergence
if (abs(f) <= ktol or niter% > 20) then exit do
' update eccentric anomaly
delta = -f / fp
deltastar = -f / (fp + 0.5 * delta * fpp)
deltak = -f / (fp + 0.5 * deltastar * fpp + deltastar * deltastar * fppp / 6.0)
eanom = eanom + deltak
loop
if (niter% > 20) then
print " "
print "more than 20 iterations in kepler1"
stop
end if
' compute true anomaly
if (ecc < 1.0) then
' elliptic orbit
sta = sqr(1.0 - ecc * ecc) * sin(eanom)
cta = cos(eanom) - ecc
else
' hyperbolic orbit
sta = sqr(ecc * ecc - 1.0) * sinh(eanom)
cta = ecc - cosh(eanom)
end if
tanom = atan3(sta, cta)
end sub
sub getoe(ioev%(), oev())
' interactive request of classical orbital elements
' input
' ioev%(1) = request semimajor axis (1 = yes, 0 = no)
' ioev%(2) = request orbital eccentricity (1 = yes, 0 = no)
' ioev%(3) = request orbital inclination (1 = yes, 0 = no)
' ioev%(4) = request argument of perigee (1 = yes, 0 = no)
' ioev%(5) = request right ascension of the ascending node (1 = yes, 0 = no)
' ioev%(6) = request true anomaly (1 = yes, 0 = no)
' output
' oev(1) = semimajor axis (kilometers)
' oev(2) = orbital eccentricity
' oev(3) = orbital inclination (radians)
' oev(4) = argument of perigee (radians)
' oev(5) = right ascension of the ascending node (radians)
' oev(6) = true anomaly (radians)
local sma, ecc, orbinc, argper, raan, tanom
' initialize all orbital elements
for i% = 1 to 6
oev(i%) = 0.0
next i%
if (ioev%(1) = 1) then
' semimajor axis (kilometers)
' (semimajor axis > req)
do
print " "
print "please input the semimajor axis (kilometers)"
print "(semimajor axis > 0)"
input sma
if (sma > 0.0) then exit do
loop
oev(1) = sma
end if
if (ioev%(2) = 1) then
' orbital eccentricity (non-dimensional)
do
print " "
print "please input the orbital eccentricity (non-dimensional)"
input ecc
loop
oev(2) = ecc
end if
if (ioev%(3) = 1) then
' orbital inclination (degrees)
' (0 <= inclination <= 180)
do
print " "
print "please input the orbital inclination (degrees)"
print "(0 <= inclination <= 180)"
input orbinc
if (orbinc >= 0.0 and orbinc <= 180.0) then exit do
loop
oev(3) = dtr * orbinc
end if
if (ioev%(4) = 1) then
' argument of perigee (degrees)
' (0 <= argument of perigee <= 360)
if (ecc > 0.0) then
do
print " "
print "please input the argument of perigee (degrees)"
print "(0 <= argument of perigee <= 360)"
input argper
if (argper >= 0.0 and argper <= 360.0) then exit do
loop
else
argper = 0.0
end if
oev(4) = dtr * argper
end if
if (ioev%(5) = 1) then
' raan (degrees)
' (0 <= raan <= 360)
do
print " "
print "please input the right ascension of the ascending node (degrees"
print "(0 <= raan <= 360)"
input raan
if (raan >= 0.0 and raan <= 360.0) then exit do
loop
oev(5) = dtr * raan
end if
if (ioev%(6) = 1) then
' true anomaly (degrees)
' (0 <= true anomaly <= 360)
do
print " "
print "please input the true anomaly (degrees)"
print "(0 <= true anomaly <= 360)"
input tanom
if (tanom >= 0.0 and tanom <= 360.0) then exit do
loop
oev(6) = dtr * tanom
end if
end sub
function atan3(a, b) as float
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' atan3 = angle (0 =< atan3 <= 2 * pi; radians)
local c
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
function modulo(x) as float
' modulo 2 pi function
local a
a = x - pi2 * fix(x / pi2)
if (a < 0.0) then
a = a + pi2
end if
modulo = a
end function
cdeagle
Posted: 02:42am 18 Sep 2017
Updated links to the software on my Google Drive. Thanks to chronic for noticing that they were broken.
MMBASIC software
Octave software
Posted: 06:46am 18 Sep 2017
Hi David,
Off Topic (sorry!)
I meant to contact you last week to check everything is ok with you out there! I really hope you weren't too affected with things, and that you were indeed able to stay safe.
Great to see more mind-blowing stuff from you . . .
WW
