Local Time 10:41 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Question about Errors and watchdog-T.
KeepIS
Posted: 12:37am 03 Aug 2017
I've got a test program with the watchdog enabled.
Now I know I should be catching errors in every procedure and function, but when hacking a program together to test, and wanting to break at the error line in the editor, is there any way to disable the watchdog timer on error. I'm still getting used to MMBasic and I'm not sure if you can set a global error handler or something like that to stop the watchdog timer continually restarting the program on error.
Hope that makes sense.
Posted: 01:19am 03 Aug 2017
Hiya.
Type WATCHDOG OFF at the command prompt, as soon as your error occurs.
I thought that the watchdog was disabled when you ran the editor?
...perhaps not.
Posted: 03:01am 03 Aug 2017
The watchdog timer keeps running even on an error which causes the program to exit to the command prompt (this is why it is so useful).
You don't need the watchdog timer when you are debugging so just comment it out or use something like this:
IF debug THEN wdTiner = 99999999 ELSE wdTimer = 200
WATCHDOG wdTimer
KeepIS
Posted: 11:53am 03 Aug 2017
Thanks, I just thought there may have been a way to have some type of hooked error interrupt.
With typing WATCHDOG OFF at the prompt, that doesn't work if the error is generated a few hundred ms after program restart. I have a keyboard and CTRL-C handler and can usually kill it with that anyway.
As you say, just have set to off in debug is simple. Edited by KeepIS 2017-08-04
