Local Time 11:29 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 100 pin MMX and Rictech SD card board
cdeagle
Posted: 04:00am 02 Aug 2017
I'm trying to hook up and configure the Rictech SD card board to a 100 pin MMX. I've tried several pin combinations guided by some of the Micromite schematics without any success.
Any help is appreciated. Thanks, David
cdeagle
Posted: 08:59am 02 Aug 2017
From what I've read in Geoff's MMX user manual, the SD card uses the SPI2 interface. I've tried the following configuration but still get "SD card not found" error.
SD Card MMX pin
CS 81
MOSI 72
CLK 10
MISO 66
CD 59
WP no connection
I'm configuring the card with (similar to the SnadPIC)
OPTION SDCARD 81, 59
cdeagle
Posted: 09:07am 02 Aug 2017
I've also tried OPTION SDCARD 4, 2 using the hookup shown in the schematic for Peter's 100 pin MMX navigation board.
Posted: 11:28am 02 Aug 2017
Correct wiring for the 100-pin is as follows
MOSI - pin 66 (Master out- Slave in so SPI2OUT)
MISO - pin 72 (Master In - Slave out so SPI2IN)
CLK - pin 10
CS anything
CD anything
cdeagle
Posted: 11:53am 02 Aug 2017
Thanks Peter.
It appears I need to swap pins 66 and 72.
Posted: 03:38pm 02 Aug 2017
On the E100, CON10 uses the following configuration:
WP is pin 17
CS is pin 52
CD is pin 53
Therefore, you need to use the following command to configure an external SD card on CON10:
OPTION SDCARD CS_pin, CD_pin, WP_pin
OPTION SDCARD 52,53,17
The SD card on CON10 has different control pins to the #1 card, so that you could use two different SD cards at the same time. I think this is how Geoff described it.
Apologies for the confusion - this obviously needs to be documented somewhere.
Perhaps if Geoff sees this thread, he could add it to the MMBASIC Advanced Manual?
EDIT: WHOOPS! I see you are talking about the 100-pin MMX, not the E100 - sorry. You can ignore all the above in your case, but I still think that the 2nd SD card on the E100 board is not documented - not that I could find anyway, so this probably still needs to happen.Edited by Grogster 2017-08-04
Posted: 07:49pm 02 Aug 2017
Hello David, it probably won't help much but I have a MMX100 (nav version) and my SDCard works fine with
OPTION SDCARD 4,2
...but I think you have already tried this - have you traced the connections on the board? Maybe you are unlucky and have a faultEdited by CaptainBoing 2017-08-04
cdeagle
Posted: 12:20am 03 Aug 2017
Thanks everybody.
I will check the traces on the Rictech board.
There are several passive components on this board. An LED with (I assume) current-limiting resistor, a second resistor and a 100 nF capacitor.
