Local Time 08:40 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ON ERROR GOTO nnn
Posted: 11:57pm 05 Jul 2017
  Geoffg said
<snip> there is no ON ERROR GOTO linenumber statement.
Hello Geoff
Are we ever likely to get it?
Currently MMBasic doesn't have error trapping only error mitigation.
The following code attempts determine which MM it is running on by executing commands that will cause errors on certain models (there are other ways to do this, it is just an illustration)
DIM INTEGER CPUfg
' check 44 pin
IF CPUfg=0 THEN
ON ERROR SKIP 3 ' was hoping to skip 3 statements if an error occurred
SETPIN 42, DIN
SETPIN 42 OFF
CPUfg=44
END IF
' check 28 pin
IF CPUfg=0 THEN
ON ERROR SKIP 3
SETPIN 26,DIN
SETPIN 26 OFF
CPUfg=28
END IF
PRINT CPUfg
Ideally, if the first SETPIN in each IF/ENDIF fails, it would effectively jump to the end of the conditional but this method always fails because the SKIP still executes the commands, but CPUfg=44 always executes so it reports 44 - even on a 28 pin chip.
At the least, if ON ERROR SKIP <n> jumped forwards the specified number of statements then we could assert some control on the flow.
ON ERROR GOTO still gives better control because you need to be aware of the number of statements - adding statements inside the SKIP would break things (potentially).
Lightrock
Posted: 12:21am 06 Jul 2017
The CFUNCTION CPUType in the official release documentation identifies six known Micromite types.
Posted: 01:57am 06 Jul 2017
Back in the 1980's when I use Atari Basic, that BASIC did have the TRAP command, and it was very useful indeed for handling errors within the running code.
You would set the trap before a certain section of code, such as TRAP 1050, which would then loop directly to line 1050 if there was any error encountered, and that routine could examine the error register, and decide what to do next.
We do have error trapping for the SD card on the MM, but general trapping would be nice to have. I expect that it is more difficult then you think to add to MMBASIC, or it probably would have made it in there by now.
Geoff?
Peter?
Posted: 02:04am 06 Jul 2017
the following should accomplish what you want:
On error skip
SetPin 42, DOUT
mm44flag = (MM.Errno=0)
rob :-)
Posted: 02:28am 06 Jul 2017
Lightrock, robert.rozee thanks for the input guys, the code was to illustrate the problem rather than a plea for help - those will come later nice to note MM.ErrNo gets set even if the line is skipped - that could go someway towards the desired TRAPping of errors.
Grogster, it sounds like TRAP did the same as ON ERROR GOTO. It would be nice to have more control over errors but I am thinking I need to remember these are micro-controllers and manage my expectations a bit - writing bug free code would be a plus
cheers
Posted: 06:35am 06 Jul 2017
Back in the days when we had ON ERROR RESUME NEXT and ON ERROR GOTO i always preferred the ON ERROR RESUME NEXT (ON ERROR SKIP in MMBasic).
The reason is that you have more control where to resume execution after the error is handled.
Especially when code is run within a DO/LOOP, SELECT CASE or IF statement.
