Forum Index : Microcontroller and PC projects : Micromite/Explore28 comms question
| BrianP Senior Member Joined: 30/03/2017 Location: AustraliaPosts: 292 |
Hi all The more I read the manual the more confused I get... (know the feeling?) (Brain now overloaded & shut down) Regarding using the default console/com1 port on an Explore-28: According to the manual, com1 is reserved for console & therefore is not available to MMbasic. BUT In Appendix A (Serial Comms) the examples given use com1 (just an example - can't use??). The relevance is that I want to use serial comms in both program/edit mode (basic not running) & also for 2-way data transfer (within MMbasic) over a single serial link. I gather then that this perhaps cannot be done? I was hoping that I could: 1. Within MMbasic send & receive data via Teraterm. 2. Ctrl-C interrupt the running program for editing / program upload use over the same serial link. Can this be made to work? Any suggestions / solutions very welcome. (I don't yet have my Explore-28 - 'tis paid for & coming... thanks Grogs ).Regards to all Brian P. |
| OA47 Guru Joined: 11/04/2012 Location: AustraliaPosts: 1056 |
Brian, the 28 pin chip has 3 serial ports: Console serial port. Pins 11 & 12 Com1 serial port. Pins 21 & 22 Com2 serial port. Pins 9 & 10 Graeme |
As OA47 says, the console is totally separate from COM1 or COM2. Using the USB connection, you can edit your programs, XMODEM or directly enter command at the console. The console pins are available on the pins of the E28, but it was envisaged that people would use the USB connection the most with this module, so that is the recommended console path for the E28. The USB console is totally separate from COM1 and COM2, which are separate pins again along the edge of the E28 module. You can, however, force-feed data into the console via the CONSOLE pins on the edge of the module, but those pins are designed more as a local monitor of the console so you can check something if you are fault-finding, and is not the recommended console path. Robert Rozee might chime in here, as it is really his design, I just helped him design the PCB, but he would be able to better clarify exactly what the CONSOLE pins are on the E28, but I think I understand it right in what I stated above. I hope to have more E28's by Monday, so your ones will be sent to you soon, with any luck. Smoke makes things work. When the smoke gets out, it stops! |
Thanks guys The issue is not the number of serial ports available - it's that we only have one external serial connection available. What I am trying to work out is how I might be able to do data transfer when the Mite is running & console / programming work when at the command prompt, both over this single serial connection. Looking for ideas / suggestions... ![]() B |
That's what I do with a number of my setups. In your program PRINT "stuff" will send "stuff" over the console INPUT and INKEY both work over the console If you use INPUT$(nbr, [#]fnbr), #0 refers to the console. I use the console over TCPIP type links and by using console instead of com ports, I can update my programs remotely. You have to make sure that your 'in program' data link doesn't send a break signal to the 'mite. Jim VK7JH MMedit |
i'm a little confused, there are 3 serial port connections available: the console, COM1, and COM2. on the E-28 the console is available over USB, while COM1 and COM2 are directly accessible. cheers, rob :-) |
Jim - I'll try that as soon as... Rob - we only have one serial line available so I can only connect one com port. There will no USB connection available, ie. no local connection, only remote. Or am I missing something? (quite likely...) B |
If you don't have USB available, the Explore28 is not the best choice. A standard micromite without the USB-TTL makes more sense. If you are connecting to an RS232 port, you will probably need a TTL-RS232 converter to make things easier. What sort of remote connection are you using? Jim VK7JH MMedit |
it sounds like a 28-pin SDIP MX170 would be preferable to an E-28 then, as you'd not be using the E-28's onboard USB (that draws around 10mA itself all the time). what is the problem with routing all the communications through the console? i presume you're attached to a PC at the other end that is running some sort of custom application? cheers, rob :-) |
@TassyJim I will be using the existing RS232 connection to an Internet connected Laptop using a USB converter & running Teraterm. This arrangement is already working on my developmental project for controlling the local hall door lock via keypad entry (colour Maximite), allowing remote control of the door lock & logging of use. The issue here is that there is no provision for program modification unless a local USB connection is made to the Maximite. Functionally,we need to maintain/update an array of current valid keypad entry codes which are likely to change at a moment's notice - this is currently working under program control. As is normal the development project hardware is a major dog's breakfast. The permanent plan is to use the E28 on an breakout motherboard with RTC & RS232-TTL converter, 4x3 keypad connection & 12v-5v power reg. I want to be able to use the one serial connection for both data/running program control use as well as make any program changes that might be needed down the track. The E28 is being used because of its small footprint taking up minimal space on the breakout board, & it has more than enough space for the data array. If com1 can be used for both console & data then that will fit the bill nicely. Cheers Brian P. |
Rob - no problem at all routing all comms through the console - I wasn't sure if this could in fact be made to work. If it does, NO PROBLEM! B |
1 more question - if using console with RS232 the comms will need to be inverted? (the book says INV only works with com1). Ta B |
It is not something that I have tried but from the manual (page 15/16): My preference is for a USB-TTL converter or a MAX232 chip if the serial line is long. Jim VK7JH MMedit |
Thanks Jim :) B |
