Local Time 08:39 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Noob warning. need help macbook
BobDevries
Posted: 09:08pm 02 Jul 2017
I have just assembled a Micromoite Backpack V2 from SC.
I'm using the Terminal app on my Macbook Air.
My problem is that the function keys (F1....F9) do not respond correctly, but still perform what OSX has set them to.
So, pressing F2 does not save what I've typed in EDIT mode.
Is there a work-around for thiss?
Regards, Bob Devries
Dalby, QLD, Australia
Bob Devries
Phil23
Posted: 09:59pm 02 Jul 2017
Don't know if Mac's are at all like windows Laptops, but on some of my Toshiba's F1 to F9 default to other tasks like volume, mute, brightness etc.
This is indicated by an icon on the F-keys.
To access the F1-F9 etc I just hold down the Fn key, (left of the space bar on most laptops), then on this one for example F2 is F2 instead of "Change Power Setting".
Check if the Mac has a similar key.
Phil.
Posted: 10:09pm 02 Jul 2017
Check the micromite manual under "using the full screen editor"
You can also use control keys instead of the functions keys listed above. These control keystrokes are:
LEFT Ctrl-S RIGHT Ctrl-D UP Ctrl-E DOWN Ctrl-X
HOME Ctrl-U END Ctrl-K PageUp Ctrl-P PageDn Ctrl-L
DEL Ctrl-] INSERT Ctrl-N F1 Ctrl-Q F2 Ctrl-W
F3 Ctrl-R ShiftF3 Ctrl-G F4 Ctrl-T F5 Ctrl-Y
There are control key alternatives available for when the F keys don't work.
JimEdited by TassyJim 2017-07-04
BobDevries
Posted: 10:31pm 02 Jul 2017
Thanks Jim,
Clearly a case of RTFM :)
Works a charm.
Bob Devries
ajkw
Posted: 12:52am 03 Jul 2017
Bob,
I am away and don't have a device to test but I recall the following as working
In Terminal
From the App menu follow
TERMINAL, PREFERENCES, PROFILES, KEYBOARD
Change to a Profile that has
F1 \033OP ( not F1 \033[11~ )
F2 \033OQ ( not F2 \033[12~ )
etc
If there isn't a profile with these then edit one.
Hope this helps.
Anthony
Edit
Actually It might be the default action is \033OP and I changed them to \033[11~ , \033[12~ etc
I definitely got it to work with the F keys
Have a play.
Apologies for the edits. just trying to make it rightEdited by ajkw 2017-07-04
Quazee137
Posted: 11:21pm 04 Jul 2017
I made this little helper.
2017-07-05_091651_Edit_Keys.pdf
Sits up against my monitor.
I was alway forgetting to use the Blue FN very distracting.
