flip Senior Member Joined: 18/07/2016 Location: AustraliaPosts: 137
Posted: 12:17am 19 Jun 2017
Hi all, Hoping someone can confirm what I'm doing is OK. I had something like the following in a program and it worked fine as a routine, but when I test a cut down version in command mode it always returns 0 for the x parameter(stored in variable a). the y parameter is correct.
Do a=Touch(x):b=Touch(y):If a>-1 And b>-1 Then print a,b ELSE b=b:EndIf:Loop
Same problem evident with 5.04.04 on a standard uMite and 5.03.o on a uMite+
eg. output like 0 162 0 163 ... Hope it's nothing like x being treated as a variable rather than a literal parameter?
PhilEdited by flip 2017-06-20
Posted: 12:22am 19 Jun 2017
...interestingly when i try
Do b=Touch(y):a=Touch(x):If a>-1 And b>-1 Then print a,b ELSE b=b:EndIf:Loop
then the y variable gets lost... e.g. 234 0 235 0 ...
Regards, Phil
matherp Guru Joined: 11/12/2012 Location: United KingdomPosts: 12083
Posted: 01:32am 19 Jun 2017
You are missing the colon after "DO"
