Local Time 17:45 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : error : argument list
palcal
Posted: 05:19pm 12 Jun 2017
I am getting the above error and can't work out why.
I have a SUB and I get the error when the SUB is called.
GetCL
more lines of code here.
Sub GetCL
pin RelayPin = 0 'make sure RLY1 is off (for C1 only)
FCount = Pin OscPin ' get frequency
Freq1 = Fcount ' copy into Freq1
Pin RelayPin = 1 ' now turn on relay to add C2
Pause 1000 'pause to allow osc to settle
FCount = Pin OscPin ' get frequency again
Freq2 = Fcount 'copy into Freq2
Pin RelayPin = 0 'turn off relay again
'now find the values of C1 and L1, knowing C2, Freq1 & Freq2
F1 = Freq1
F2 = Freq2
F1sqrd = F1*F1 'then find their squares
F2sqrd = F2*F2
F1sqlessF2sq = ((F1sqrd - F2sqrd) '& their difference
C1val = C2val *(F2sqrd / F1sqlessF2sq) ' calculate the value of C1
L1val = 1.0/(FourPiSqrd * (F1sqrd) * C1val) ' calculate the value of L1
error:argument list
Paul.Edited by palcal 2017-06-14
Phil23
Posted: 06:18pm 12 Jun 2017
  palcal said   I am getting the above error and can't work out why.
Hi Paul,
I think you need some brackets around the PIN command & functions.
Just looked in a few of mine & all have brackets around the vairables.
Phil
[Code]GetCL
Sub GetCL
pin(RelayPin) = 0 'make sure RLY1 is off (for C1 only)
FCount = Pin(OscPin) ' get frequency
Pin(RelayPin)= 1 ' now turn on relay to add C2
FCount = Pin(OscPin) ' get frequency again
Pin(RelayPin) = 0 'turn off relay again
F1 = Freq1
F2 = Freq2
F2sqrd = F2*F2
[/code]
palcal
Posted: 07:09pm 12 Jun 2017
OK, yes of course, I'm converting the code from an Arduino sketch and it is a nightmare (for me).
Paul.
palcal
Posted: 07:16pm 12 Jun 2017
I put the brackets in as they should be, but still getting the error
Paul.
palcal
Posted: 07:21pm 12 Jun 2017
Found another error with the brackets in the last few lines, but still the error persists.
palcal
Posted: 10:35pm 12 Jun 2017
From reading the manual I think it has something to do with me using OPTION EXPLICIT which I haven't used before.
Paul.
Posted: 10:58pm 12 Jun 2017
can you post the full basic code please?
rob :-)Edited by robert.rozee 2017-06-14
palcal
Posted: 11:13am 13 Jun 2017
@ robert.rozee
This is the code so far, it is nowhere near completed. I have started to do a bit of work on the GUI but it needs a lot more. If I change the 'GetCL' defined SUB to a normal SUB with...GOSUB/LABEL/RETURN... it runs through OK or at least to a point where it returns a Divide by Zero error because I have no hardware connected.
'INDUCTANCE / CAPACITANCE METER.....Paul Cahill Jun 2017
'Ported from Arduino Sketch Silicon Chip June 2017
' The NUDGE calibration factor CF that calibrates against a known standard has been omitted. CF=1
Option autorun on
Option explicit
Option default float
'SetTick 300, Measure, 1
Const CLbarPin = 16 'digital IO pin 16 for C/L-bar sensing
Const RelayPin = 22 'digital IO pin 22 for driving RLY1
Const DecrPin = 4 'digital IO pin 4 for sensing DECR pos of S3
Const OscPin = 18 'digital IO pin 18 for input of oscillator signal
Const IncrPin = 21 'digital IO pin 21 for sensing INCR pos of S3
Const CalLkPin = 17 'digital IO pin 17 for sensing CAL link LK1
Dim C1val ' C1's calculated value after calibration (in F)
Const FourPiSqrd = 39.4784
Const uHmult = 1.0e6 ' multiplier for converting H into uHRed
Const mHmult = 1.0e3 ' multiplier for converting H into mH
Const pFmult = 1.0e12 ' multiplier for converting F into pF
Const nFmult = 1.0e9 ' multiplier for converting F into nF
Const uFmult = 1.0e6 ' multiplier for converting F into uF
Const C2val = 1.000e-9 ' nominal value of C2 (1nF = 1 x 10^-9F (change to actual value if known)
Dim c
Dim CXval ' calculated value for Cx (in F)
Dim L1val ' calculated value for L1 after calibration (H)
Dim LXval ' calculated value for Lx (in H)
Dim F1
Dim F2
Dim F3
Dim F1sqrd ' calc value for Freq1 squared (as a float)
Dim F2sqrd ' calc value for Freq2 squared (as a float)
Dim F3sqrd ' calc value for Freq3 squared (as a float)
Dim F1SqlessF2Sq
Dim CF ' calibration factor, set by nudging via S3
Dim Fcount ' raw frequency count figure (from GetFrequency function)
Dim Freq1 ' measured Freq1 in Hz (L1 & C1 only)
Dim Freq2 ' measured Freq2 in Hz (L1 & (C1 + C2))
Dim Freq3 ' measured Freq3 in Hz (C1+Cx/L1 or C1/L1+Lx)
Dim CXuF
Dim CDisp$
CF = 1 ' calibration factor (not used)
SetPin CLbarPin, DIN,pullup ' make pin 2 an input with pullup
SetPin RelayPin, DOUT ' but make pin3 an output
Pin(RelayPin) = 0 ' set relay "off"
SetPin DecrPin, DIN,pullup ' make pin 4 an input with pullup
SetPin OscPin, FIN ' make pin 15 a frequency input
SetPin IncrPin, DIN,pullup ' make pin 6 an input with pullup
SetPin CalLkPin, DIN,pullup ' and make pin 7 an input with pullup
CLS RGB(yellow)
Text (MM.HRes/2),(MM.VRes/2)-50, "Digital LC Meter", C, 1, 2, RGB(black),RGB(yellow)
Pause 2000
'CALIBRATION
If Pin(CLbarPin) = 1 Then
Text (MM.HRes/2),MM.VRes/2,"S1 set for C: OK", C, 1, 2, RGB(black),RGB(yellow)
Else
Text (MM.HRes/2),MM.VRes/2, "Fit shorting bar",C, 1, 2, RGB(black),RGB(yellow) 'S1 in 'L' position, need for shortin bar
Text (MM.HRes/2),(MM.VRes/2)+50, "Now Calibrating",C, 1, 2, RGB(black),RGB(yellow)
Pause 1000
GetCL , sub To find value of C1 And L1
CLS RGB(yellow)
Text MM.HRes/2,MM.VRes/2,"Calibration done",c, 1, 2, RGB(black),RGB(yellow)
Text (MM.HRes/2),(MM.VRes/2)+50 ,"Ready to measure",c, 1, 2, RGB(black),RGB(yellow)
Pause 3000
CLS RGB(yellow)
RBox 55,80,220,80,5,c,RGB(White)
Text MM.HRes/2,(MM.VRes/2)-10,"MEASURE",c,1,2,RGB(Black),RGB(white)
'Main Loop
CLS RGB(yellow)
FCount = Pin(OscPin) ' go get current osc frequency
Freq3 = Fcount ' and copy into Freq3
F3 = Freq3
F3sqrd = F3*F3 ' so it can be squared
If CLbarPin = 1 Then 'we're measuring a C
CapValString 'SUB CapValString
Text MM.VRes - 9,MM.HRes/2,Cdisp$, c, 1, 2, RGB(black) ' now display the cap value string
Else
IndValString ' SUB IndValString we're measuring L
Text MM.VRes - 9,MM.HRes/2, Ldisp$, c, 1, 2, RGB(black) ' show inductance value or over range msg
Text MM.VRes - 9,(MM.HRes/2)+50, "F3 =" + Str$(Freq3) + " Hz"
'end main loop
Sub CapValString
CXval = C1val * CF * ((F1sqrd/F3sqrd) - 1.0) ' value of test capacitor
Print C1val;CF;F1sqrd;F3sqrd
If CXval < 1.0e-9 Then ' if CXval < 1nF
CXpF = CXval * pFmult ' get equiv value in pF
Cdisp$ = " Cx = " +Str$(CXpF) + " pF" ' then assemble top line string
ElseIf ' value must be 1nF or more
CXval < 1.0e-6 Then ' but check if it's less than 1uF
CXnF = CXval * nFmult ' if so, get equiv value in nF
Cdisp$ = "Cx = " + Str$(CXnF) + " nF" ' then assemble top line string
EndIf ' value must be 1uF or more
CXuF = CXval * uFmult ' so get equiv value in uF
Cdisp$ = "Cx = " + Str$(CXuF) + " uF" ' then assemble top line string
Sub IndValString
LXval = L1val * CF * ((F1sqrd/F3sqrd)-1.0) ' work it out
If LXval < 1.0e-3 Then ' if LXval < 1mH
LXuH = LXval * uHmult ' convert to uH
Ldisp$ = " Lx = " + Str$(LXuH) + " uH" ' then assemble top line string
ElseIf LXval > 1 Then ' value must be 1mH or moreLXval < 1.5e-1 then
LXmH = LXval * mHmult ' convert to mH
Ldisp$ = " Lx = " + Str$(LXmH) + " mH" ' then assemble top line string
Else Ldisp$ = " Over Range!"
Sub GetCL
Pin(RelayPin) = 0 'make sure RLY1 is off (for C1 only)
Pin(RelayPin) = 1 ' now turn on relay to add C2
F1 = Freq1
F2 = Freq2
F2sqrd = F2*F2
F1sqlessF2sq = (F1sqrd - F2sqrd) '& their difference
L1val = 1.0/(FourPiSqrd * F1sqrd * C1val) ' calculate the value of L1
Paul.
PS I hope it is OK to post this code, or do I need permission from SC to do what I am doing.Edited by palcal 2017-06-14
Posted: 12:42pm 13 Jun 2017
You have an extra ENDIF on line 101 and line 116
line 64 you have a comma instead of quote mark.
JimEdited by TassyJim 2017-06-14
Posted: 12:59pm 13 Jun 2017
Program with the above errors fixed.
  Quote   '**************************************************************************************
OPTION AUTORUN ON
OPTION EXPLICIT
OPTION DEFAULT FLOAT
CONST CLbarPin = 16 'digital IO pin 16 for C/L-bar sensing
CONST RelayPin = 22 'digital IO pin 22 for driving RLY1
CONST DecrPin = 4 'digital IO pin 4 for sensing DECR pos of S3
CONST OscPin = 18 'digital IO pin 18 for input of oscillator signal
CONST IncrPin = 21 'digital IO pin 21 for sensing INCR pos of S3
CONST CalLkPin = 17 'digital IO pin 17 for sensing CAL link LK1
DIM C1val ' C1's calculated value after calibration (in F)
CONST FourPiSqrd = 39.4784
CONST uHmult = 1.0e6 ' multiplier for converting H into uHRed
CONST mHmult = 1.0e3 ' multiplier for converting H into mH
CONST pFmult = 1.0e12 ' multiplier for converting F into pF
CONST nFmult = 1.0e9 ' multiplier for converting F into nF
CONST uFmult = 1.0e6 ' multiplier for converting F into uF
CONST C2val = 1.000e-9 ' nominal value of C2 (1nF = 1 x 10^-9F (change to actual value if known)
DIM c
DIM CXval ' calculated value for Cx (in F)
DIM L1val ' calculated value for L1 after calibration (H)
DIM LXval ' calculated value for Lx (in H)
DIM F1
DIM F2
DIM F3
DIM F1sqrd ' calc value for Freq1 squared (as a float)
DIM F2sqrd ' calc value for Freq2 squared (as a float)
DIM F3sqrd ' calc value for Freq3 squared (as a float)
DIM F1SqlessF2Sq
DIM CF ' calibration factor, set by nudging via S3
DIM Fcount ' raw frequency count figure (from GetFrequency function)
DIM Freq1 ' measured Freq1 in Hz (L1 & C1 only)
DIM Freq2 ' measured Freq2 in Hz (L1 & (C1 + C2))
DIM Freq3 ' measured Freq3 in Hz (C1+Cx/L1 or C1/L1+Lx)
DIM CXuF
DIM CDisp$
CF =
SETPIN CLbarPin, DIN,PULLUP ' make pin 2 an input with pullup
SETPIN RelayPin, DOUT ' but make pin3 an output
PIN(RelayPin) = 0 ' set relay "off"
SETPIN DecrPin, DIN,PULLUP ' make pin 4 an input with pullup
SETPIN OscPin, FIN ' make pin 15 a frequency input
SETPIN IncrPin, DIN,PULLUP ' make pin 6 an input with pullup
SETPIN CalLkPin, DIN,PULLUP ' and make pin 7 an input with pullup
CLS RGB(YELLOW)
TEXT (MM.HRES/2),(MM.VRES/2)-50, "Digital LC Meter", C, 1, 2, RGB(BLACK),RGB(YELLOW)
PAUSE 2000
'CALIBRATION
IF PIN(CLbarPin) = 1 THEN
TEXT (MM.HRES/2),MM.VRES/2,"S1 set for C: OK", C, 1, 2, RGB(BLACK),RGB(YELLOW)
ELSE
TEXT (MM.HRES/2),MM.VRES/2, "Fit shorting bar",C, 1, 2, RGB(BLACK),RGB(YELLOW) 'S1 in 'L' position, need for shortin bar
TEXT (MM.HRES/2),(MM.VRES/2)+50, "Now Calibrating",C, 1, 2, RGB(BLACK),RGB(YELLOW)
ENDIF
PAUSE 1000
GetCL
' sub To find value of C1 And L1
CLS RGB(YELLOW)
TEXT MM.HRES/2,MM.VRES/2,"Calibration done",C, 1, 2, RGB(BLACK),RGB(YELLOW)
TEXT (MM.HRES/2),(MM.VRES/2)+50 ,"Ready to measure",C, 1, 2, RGB(BLACK),RGB(YELLOW)
PAUSE 3000
CLS RGB(YELLOW)
RBOX 55,80,220,80,5,c,RGB(WHITE)
TEXT MM.HRES/2,(MM.VRES/2)-10,"MEASURE",c,1,2,RGB(BLACK),RGB(WHITE)
'Main Loop
CLS RGB(YELLOW)
FCount =
PIN(OscPin) ' go get current osc frequency
F3 = Freq3
F3sqrd = F3*F3
IF CLbarPin = 1 THEN 'we're measuring a C
TEXT MM.VRES - 9,MM.HRES/2,Cdisp$, c, 1, 2, RGB(BLACK) ' now display the cap value string
ELSE
IndValString
TEXT MM.VRES - 9,MM.HRES/2, Ldisp$, c, 1, 2, RGB(BLACK) ' show inductance value or over range msg
TEXT MM.VRES - 9,(MM.HRES/2)+50, "F3 =" + STR$(Freq3) + " Hz"
ENDIF
'end main loop
SUB CapValString
PRINT C1val;CF;F1sqrd;F3sqrd
IF CXval < 1.0e-9 THEN ' if CXval < 1nF
Cdisp$ = " Cx = " +STR$(CXpF) + " pF" ' then assemble top line string
ELSEIF ' value must be 1nF or more
CXval < 1.0e-6 THEN ' but check if it's less than 1uF
Cdisp$ = "Cx = " + STR$(CXnF) + " nF" ' then assemble top line string
ENDIF
'EndIf ' value must be 1uF or more
Cdisp$ = "Cx = " + STR$(CXuF) + " uF" ' then assemble top line string
END SUB
SUB IndValString
1.0) ' work it out
IF LXval < 1.0e-3 THEN ' if LXval < 1mH
Ldisp$ = " Lx = " + STR$(LXuH) + " uH" ' then assemble top line string
ELSEIF LXval > 1 THEN ' value must be 1mH or moreLXval < 1.5e-1 then
Ldisp$ = " Lx = " + STR$(LXmH) + " mH" ' then assemble top line string
ELSE Ldisp$ = " Over Range!"
ENDIF
'EndIf
END SUB
SUB GetCL
PIN(RelayPin) = 0 'make sure RLY1 is off (for C1 only)
FCount = PIN(OscPin) ' get frequency
PIN(RelayPin) = 1 ' now turn on relay to add C2
PAUSE 1000 'pause to allow osc to settle
FCount = PIN(OscPin) ' get frequency again
PIN(RelayPin) = 0 'turn off relay again
F1 = Freq1
F2 = Freq2
F1sqrd = F1*F1
F2sqrd = F2*F2
'& their difference
END SUB
I had to change one of the pins to suit my hardware as pin 4 was used by my display and then it ran OK with a divide by zero error on line 134. This is expected when there is no oscillator running (or none attached as in my case).
I would put a test for zero frequency just in case.
palcal
Posted: 01:28pm 13 Jun 2017
Thanks for that Jim the comma in the sub certainly stood out in MMEdit, I was doing most of my debugging in TeraTerm, and it is the old story when editing anything, it is often hard to see your own mistakes.
Thanks again at least it is OK so far.
Paul.
Posted: 02:03pm 13 Jun 2017
Finding other peoples bugs is more fun than finding your own.
I also use other's code to test MMEdit.
In this case, I formatted your code and the two extra ENDIF's were obvious. This is not always the case.
I then produced a variable report and line 64 threw up a lot of errors about variables only used once, so I knew where to look.
Translating code from one language to another can be 'interesting' and sometimes harder than starting from scratch.
Once you have it working, I would consider using the touch screen instead of old fashioned switches.
palcal
Posted: 02:37pm 13 Jun 2017
@ Jim
I also thought of using the touch instead of a switch but the inductor connects to a different pin on the micro so I would then need 3 input terminals on the meter.
I really only want this to check SMD caps which for some unknown reason are usually never marked. If you can mark a resistor you can mark a cap. I had Uf on one of my multimeters but it died and as I have other multimeters decided to build this instead of buying a new meter.
Paul.Edited by palcal 2017-06-15
redrok
Posted: 10:18pm 19 Nov 2017
Hi palcal;
Would you mind posting a bit about how this works?
Are you using an external oscillator or something else?
redrok
panky
Posted: 05:00am 21 Nov 2017
@redrock
It was in a June 17 Silicon Chip article - basically you have an LC oscilator running which provides a frequency out. By paralleling a capacitor or inductor to be tested across the built in capacitor, inductor, you change the frequency. Thus by comparing the two frequencies and knowing the built in capacitor and inductor, you can calculate what value the L or C under test is. In the article they used an Arduino to carry out the calculations but Paul has done all the hard work and converted these to MMBasic. I just added a GUI interface for fun and interest.
@Paul
I have taken the liberty of adapting your program to use GUI commands.
As is, with a 300KHz square wave input into the Osc pin, it works on my 144 pin MZ board but I have not actually tested with the front end components.
For your info.
' INDUCTANCE / CAPACITANCE METER.....Paul Cahill Jun 2017
' Ported from Arduino Sketch Silicon Chip June 2017
' Initial language conversion by Paul (palcal)
' GUI adaption by Doug Pankhurst (panky)
' Current version tested on 144 pin Micromite Extreme 252MHz
' running MMBasic Extreme 5.04.05
' (not using any MMBasic Extreme explicit commands)
' - should be OK for 120MHz '470.
' Uses pin 81 as digital out to drive relay selecting L or C
' rather than DIN to read switch for L or C
' Uses pin 11 (Count1) as frequency input - tested
' without front end components - I just fed a 302KHz
' square wave in to test.
' a known standard has not been implimented yet so CF=1
' Declarations
OPTION AUTORUN ON
OPTION EXPLICIT
' modified pin numbers for MZ144
CONST CLbarPin = 81 'digital IO pin 81 for C/L-bar sensing
CONST RelayPin = 82 'digital IO pin 82 for driving RLY1
CONST DecrPin = 83 'digital IO pin 83 for sensing DECR pos of S3
CONST OscPin = 11 'digital IO pin 11 for input of oscillator signal
CONST IncrPin = 84 'digital IO pin 84 for sensing INCR pos of S3
CONST CalLkPin = 87 'digital IO pin 87 for sensing CAL link LK1
' constants for calculations
' (change to actual value if known)
' variables
DIM c
DIM F1 ' frequency 1
DIM F2 ' frequency 2
DIM F3 ' frequency 3
DIM F1SqlessF2Sq
DIM CXuF ' capacitor under test
DIM CDisp$
dim LXuH ' inductor under test
dim Ldisp$
dim Do_Measure_Flag ' start measurement cycle
'Program Entry Point
' Initialise any variables
CF = 1 ' calibration factor (not implimented yet)
CLS RGB(gray)
' Set up GUI Controls
dim Title_DB% = 10 ' title area
dim LCVal_DB% = 11 ' LC Display Box
dim Freq_DB% = 12 ' Frequency Display Box
dim CSel_RB% = 13 ' test capacitor radio button
dim LSel_RB% = 14 ' test inductor radio button
dim LC_Sel_Frame% = 15 ' group C or L select in frame
Dim LC_Cal_RB% = 17 ' calibrate radio button
dim Measure_B% = 18 ' initiate measure button
dim LC_Help_RB% = 19 ' switch to Help Screen
dim Msg1_DB% = 20 ' message 1 area
dim Msg2_DB% = 21 ' message 2 area
font 2,2
gui displaybox Title_DB%,40,20,400,40,rgb(black),rgb(yellow)
font 2,1
gui displaybox LCVal_DB%,100,80,300,30,rgb(black),rgb(green)
gui displaybox Freq_DB%,100,120,300,30,rgb(black),rgb(green)
gui displaybox Msg1_DB%,100,160,300,30,rgb(black),rgb(green)
gui displaybox Msg2_DB%,100,200,300,30,rgb(black),rgb(green)
font 2,1
gui frame LC_Sel_Frame%,"Select C or L",450,30,180,100,rgb(blue)
gui radio CSel_RB%,"Capacitor",480,60,15,rgb(blue)
gui radio LSel_RB%,"Inductor",480,100,15,rgb(blue)
ctrlval(CSel_RB%) = 1 ' capacitance selected to start
gui button Measure_B%,"Measure",200,250,90,40,rgb(black),rgb(red)
font 1,1
gui interrupt TouchDown,TouchUp
' Define and setup all I/O pins
SETPIN CLbarPin, Dout ' make pin 81 an output
pin(CLbarPin) = 1 ' default capacitor
SETPIN RelayPin, DOUT ' but make pin 82 an output
SETPIN DecrPin, DIN,PULLUP ' make pin 83 an input with pullup
SETPIN OscPin, FIN ' make pin 11 a frequency input - Count1
SETPIN IncrPin, DIN,PULLUP ' make pin 84 an input with pullup
SETPIN CalLkPin, DIN,PULLUP ' and make pin 87 an input with pullup
' Initialise display with startup splash screen
ctrlval(Title_DB%) = "Digital LC Meter"
' Carry out Calibration
LC_Calibrate ' subroutine to perform initial calibration
' - can also be called if re-cal needed
Do_Measure_Flag = 0 ' initial state after cal
' Main program loop
do
' main loop - until touch screen
' buttons initiate action
' - options will be
' select L or C.
' Touch "Measure" to initiate process
if Do_Measure_Flag = 1 then
GetCL
' set up for initial frequency calculation
FCount = PIN(OscPin) ' go get current osc frequency
F3 = Freq3
IF pin(CLbarPin) = 1 THEN 'we're measuring a capacitor
ctrlval(LCVal_DB%) = Cdisp$ ' now display the cap value string
ELSE
ctrlval(LCVal_DB%) = Ldisp$ ' show inductance value or over range msg
ENDIF
ctrlval(Freq_DB%) = "F3 =" + STR$(Freq3) + " Hz" ' base frequency
Do_Measure_Flag = 0
endif
loop
'end main loop
' Interrupt Handler for Touch
sub TouchDown
select case touch(ref)
case CSel_RB%
if ctrlval(CSel_RB%) then
pin(CLBarPin) = 1
endif
case LSel_RB%
if ctrlval(LSel_RB%) then
pin(CLBarPin) = 0
endif
case Measure_B%
Do_Measure_Flag = 1
end select
end sub
sub TouchUp ' not implimented yet
end sub
' Subroutines and Functions
' Calibrate subroutine
sub LC_Calibrate
ctrlval(Msg1_DB%) = "S1 set for C: OK"
ELSE
ctrlval(Msg1_DB%) = "S1 set for L: OK"
ctrlval(Msg2_DB%) = "Fit shorting bar"
ENDIF
pause 3000
ctrlval(Msg1_DB%) = "Now Calibrating"
PAUSE 3000
GetCL ' sub To find value of C1 And L1
ctrlval(Msg1_DB%) = "Calibration done"
ctrlval(Msg2_DB%) = "Ready to Measure"
end sub
SUB CapValString
local CXpF,CXnF,CXuF
' PRINT C1val;CF;F1sqrd;F3sqrd
ELSEIF CXval < 1.0e-6 THEN ' value must be 1nF or more
ENDIF
END SUB
SUB IndValString
local LXuH,LXmH
if f3sqrd = 0 then
print "Divide by zero error line 204"
LXval = L1val
else
endif
ENDIF
'EndIf
END SUB
SUB GetCL
PIN(RelayPin) = 0 ' make sure RLY1 is off (for C1 only)
PAUSE 1000 ' pause to allow osc to settle
Freq2 = Fcount ' copy into Freq2
PIN(RelayPin) = 0 ' turn off relay again
F1 = Freq1
F2 = Freq2
F2sqrd = F2*F2
If F1sqlessF2sq = 0 then
print "Divide by zero error line 236"
C1val = C2val
else
endif
If (FourPiSqrd * F1sqrd * C1val) = 0 then
print "Divide by zero error line 242"
else
endif
END SUB
Cheers,
Doug.
