Local Time 05:03 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Xmodem Transfers.
Phil23
Posted: 12:52am 12 Jun 2017
So far all I've done with 5.4 is sucked a few files off the SD card from the command prompt.
Just wondering how it works in context with other running code.
The manual doesn't mention if it can be used within code or not.
For example;....
[Code]
SETTICK 5000, FiveSecInterupt, 1
Open "Com1:9600,,RecComs,10" as #1
Stuff
Other Stuff etc
IF SendFileFlag=1 Then
XMODEM SEND "DataLog.csv"
End If
More Stuff
Loop[/code]
So in the above, if we set that flag to trigger the transfer, interacting with a menu via teraterm for example, pause the code while the transfer takes place, or does it happen as a background process?
And if it was a largish file what would happen if either of the interrupts were triggered?
Or have I got it completely wrong & it's a command prompt only transfer.
Phil.
