Local Time 06:22 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Blink GUI Led.
Phil23
Posted: 02:10pm 08 Jun 2017
Might be one for Geoff,
Blinking GUI Leds in different colours - That parts easy.
But returning to a constant "Non-Illuminated colour seems difficult.
It appears the colour cannot be issued while the led is illuminated & knowing when it's not is unknown.
[Code]
GUI LED L_Led1,"",30,449,30,RGB(Yellow)
CtrlVal(L_Led1)=500
Pause 1000
FCOLOUR RGB(Red),Led1
CtrlVal(L_Led1)=500
Pause 1000
CtrlVal(L_Led1)=500
FCOLOUR RGB(Yellow),Led1 'Doesn't work untested
[/code]
Thinking out loud a bit here....
Phil.
Posted: 04:38pm 08 Jun 2017
You could do it via a sub that deleted the old reference, and created a new one, like:
SUB CHANGELED(REF,CAPTION$,X,Y,R,C)
GUI DELETE REF
GUI LED REF,CAPTION$,X,Y,R,RGB(C)
END SUB
Untested, but that SHOULD work.
I thought you could make a flashing LED a plain one again by just setting it's value to zero(off) or one(on), and any number GREATER then 1 would be the flash delay as you have in your example above.....
IE: Set the colour to what you want, then set that LED's CtrlVal to zero to turn it off, but show the dim background colour you wanted it to be.
Are you saying that does not work?
Posted: 02:31am 09 Jun 2017
I'm not sure what the problem is.
When the GUI LED goes off it is a dull version of its former colour, Do you want it to change to a dull version of a different colour?
Phil23
Posted: 11:45am 09 Jun 2017
  Geoffg said  When the GUI LED goes off it is a dull version of its former colour, Do you want it to change to a dull version of a different colour?
Sorry,
Wanted to test a little before replying.
Yes it's the dimmed colour I'm trying to maintain constant.
But when using a LED in the Flashing mode, the only way to do this is to code somehow to reset the FCOLOUR after the timeout has expired.
What I was wondering with this snippet,
[code]FCOLOUR RGB(Red),Led1
CtrlVal(L_Led1)=500
FCOLOUR RGB(Yellow),Led1[/code]
is whether it would flash red for the 500ms, the extinguish to yellow.
Tested it now; and it just displays a yellow led.(Maybe red for an undetectable moment).
Somewhere in code I could check the CtrlVal of the led & see if it's zero & do the Fcolour change based on that, but would be a lot of looping.
Mostly it got me thinking on the lines of "What if someone wants to do multi-colour flashing Leds, how do you best maintain a static inactive colour.
Nothing broken really, all works as expected.
Phil.
GoodToGo!
Posted: 10:27pm 11 Jun 2017
Hey Phil,
Would changing the GUI LED forecolour to RGB(black) better suit your application?
GTG!
Phil23
Posted: 01:04am 12 Jun 2017
  GoodToGo! said  Would changing the GUI LED forecolour to RGB(black) better suit your application?
Grey, Black either would look authentic.
It's more a case of when or how to chang it when using a CtrlVal that makes it flash.
Would seem impractical to be repeatedly testing if the CtrlVal has gone to zero before change the FCOLOUR value again.
Phil.
