Local Time 02:55 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Managing Log Files.
Phil23
Posted: 12:54am 17 May 2017
Started writing this to manage log files.
(For/Next loop just for testing. Should be DO WHILE?).
Basically finding the next sequence number & renaming the current file to the next in line....
IE,
[Code] files
<DIR> GARMIN
45 FOX.TXT
13783 TEMPLOG.TXT
13 TEST.TXT
1368691 TESTLOG.TXT
33 TEST_001.LOG
33 TEST_002.LOG
33 TEST_003.LOG
1 directory, 7 files
[/code]
  Quote   for n=1 to 10
Filename$=
"Test_"+Str$(N,3,0,"0")+".log"
Open FileName$ for Input as #1
Print Filename$; " MM.Errno = "; MM.ERRNo
If MM.ERRNo=0 Then Close #1
If MM.ERRNo=6 Then
Name
"Test.log" as FileName$
Exit for
End If
Next n
Doesn't work as the NAME function is not implemented in MMbasic.
Does anyone have any alternate suggestions?
Phil
Posted: 01:38am 17 May 2017
Using the DIR$() function you could search through the list of files rather than opening and closing them. You could then just create the log file with the correct name in the first place.
You could also hang on for V5.4 (due in a few weeks). That has long file names so you could name the files with the full date and time. With a bit of luck it might even have a NAME command.
Posted: 02:34am 17 May 2017
I do my log files on a monthly basis, so as to not end up with too many log files.
I do mine like this:
SUB WRITE_SYSLOG(T1$)
Local TXT$,MREF$,FILE$
CHDIR "\SYSLOG\"
Do While FILE_OPEN_FLAG:Loop 'Wait till file handle closed if still open.
FILE_OPEN_FLAG=1 'File handle is now closed, so set flag again for this sub
MREF$=MTH$(val(mid$(date$,4,2)))+"_"+MID$(DATE$,7) 'Build a reference for current month
FILE$=MREF$+".LOG"
Open FILE$ for append as #4
TXT$="["+date$+", "+time$+"] - "+T1$
Print #4,TXT$
If DEBUG Then Print FILE$+" - "+TXT$
Close #4
FILE_OPEN_FLAG=0 'Indicate to system that file handle is closed.
END SUB
To log, I just issue the command: WRITE_SYSLOG ("Log this text."), for example.
If the file already exists, the data will be date-stamped and added to the end of the file. If the file does not exist, it will be automatically created.
[Quote=Geoff]You could also hang on for V5.4 (due in a few weeks). That has long file names[/Quote]
Owwwwwww!
Exciting.
What kind of long-filename support are we talking about here?
Phil23
Posted: 02:35am 17 May 2017
  Geoffg said   Using the DIR$() function you could search through the list of files rather than opening and closing them. You could then just create the log file with the correct name in the first place.
Current thoughs were a Static Logfile name that is archived periodically, maybe based on size, to the sequential names.
From the manual,
[Quote]The function will return the first entry found. To retrieve subsequent entries
use the function with no arguments. ie, DIR$( ). The return of an empty
string indicates that there are no more entries to retrieve.[/quote]
From the example given I see output of
[code]> print dir$("*.*",file)
TEST.TXT
> print dir$()
TESTLOG.TXT
> print dir$()
FOX.TXT
> print dir$()
TEST_001.LOG
> print dir$()
TEST_002.LOG
> print dir$()
TEST_003.LOG
> print dir$()
TEMPLOG.TXT
> print dir$()
[/code]
Does that imply that there is no sort applied, with files listed in the order of their directory entry creation?
Phil
