Local Time 02:57 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Soldermask offset....
Posted: 01:11pm 11 May 2017
Hi folks.
What do the rest of you guys use for your soldermask offset?
I am not going to tell you what I use, till I get some feedback on what others use, cos I want to know those figures without my ones being known - yet.
I am looking for the best offset, with the tightest soldermask-to-pad clearance, that still works reliably at manufacture without overlaying the soldermask onto the pad you need to solder to.
We could consider this a game of sorts - Who can guess what I use?
EDIT: Rob(ert Rozee) - You are not allowed to guess, as you already know because of our emails on this subject. Edited by Grogster 2017-05-12
Posted: 04:36pm 11 May 2017
Grogs,
When you say "soldermask offset" I assume you mean the clearance from a pad etc?
My boards are done with a 0.004" (roughly 0.1mm) clearance.
So a pad of say 0.1" diameter would have a solder mask diameter of 0.108" (giving 0.004" clearance all around)
Posted: 06:55pm 11 May 2017
Yes, I mean the clearance from the pad.
Posted: 07:24pm 11 May 2017
I actually shrink the soldermask so that the pad is slightly covered with soldermask.
Especially for QFN/SSOP's this gives some more soldermask between the pins which prevents bridging.
I shrink it between 0.05mm for qfn up to 0.1mm for the 1206 SMD parts.
Posted: 01:21am 12 May 2017
Okey dokey, thanks for that info.
My boards are setup for 0.1mm for SMD, and 0.3mm for pads. I will shrink the pad figure, as it has been wiping out some silkscreen I would like to get closer to the pads.
