Local Time 02:05 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : DDS Signal Generator Code
SteveA
Posted: 01:20am 27 Apr 2017
I'm trying to get Geoff's code running on a SC Micromite+ LCD Backpack, but I've hit a problem. The following line of code crashes the program:
SetPin Peek(byte Peek(word &H9D000090) + 23), INTL, MyInt
With the message
Error: Pin 3 is reserved at startup
I know the pin numbers are different, so I'll need to make changes, but I don't understand what the above code fragment does.
I can see it sets up an interrupt routine 'Myint' on a high to low pin change, but what do the two peeks and adding 23 do? They look a like pointers to me?
disco4now
Posted: 02:03am 27 Apr 2017
The Peek(byte Peek(word &H9D000090) + 23) is just a sneaky way of reading the interrupt pin assigned to the touch controller when its set up with OPTION TOUCH
so it effectively doing
SETPIN 3,INTL,MyInt
This thread gives details of this PEEK and some others.
Useful MMBasic Peeks
Are you on and MM+ and not an MM ? This would explain the error message.
If so you will need a GUI INTERRUPT command rather than the SETPIN used on the MM
i.e.
GUI INTERRUPT MyInt
Gerry
F4 H7FotSF4xGT
SteveA
Posted: 03:10am 27 Apr 2017
Ah, excellent. Thank you Gerry - bookmarked!
Yes I'm using the Silicon Chip MM+ lcd packback which uses a MX470.
Replacing the entire line with GUI INTERRUPT MyInt worked a treat.
Steve
