Local Time 01:09 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Divide by zero when using dir$()
Bizzie
Posted: 10:43pm 24 Apr 2017
Hi all,
Just came across the following:-
? mm.ver
5.0302
> ? mm.device$
Micromite Plus
> list
If files$ = "" Then
Print "No files found"
f$=Dir$("*.*",FILE)
Do While f$ <> ""
Print f$
f$ = Dir$()
> run
No files found
CPU exception #13 (possible divide by zero) at address 0x9D01BBA0
Processor restarted
Obvious I suppose but will really toss many.
Most of the code above is from the DIR$() example on page 46 of the plus manual.
What is the best way to handle this situation? That is a new or blank SD card with no files.
I will test files$ first to see if it is blank (hence my first if statement) and then if not recurs through the files.
I think it really needs pointing out in the manual as divide by zero is not at all obvious to most.
EDIT: Just realised my first if statement seems to work but for the wrong reasons.
Ignore these comments.Edited by Bizzie 2017-04-26
Rob White
Posted: 01:00am 25 Apr 2017
Any CPU exception is not good and should never happen.
I will have a look at it tomorrow and see what is going on.
Bizzie
Posted: 12:21pm 25 Apr 2017
Thanks Geoff,
I have not got much time this morning. I will try another board as I just changed SD cards and got different results! - That is SD card not present.
Rob White
Bizzie
Posted: 10:51pm 25 Apr 2017
Geoff,
Afraid this was yet another case of "finger trouble"!
I disabled the SD card and then did another option sdcard 24 (SD card on display) and all was fine. I can not tell you if option list indicated 24 or not.
Rob White
Posted: 12:37am 26 Apr 2017
Yes, I just tested it and no exception. Phew!!
