Forum Index : Microcontroller and PC projects : UMite Escape codes for VT100
| jeffj Regular Member Joined: 04/02/2012 Location: AustraliaPosts: 84 |
Attached are some escape codes I have extracted from various posts for use on a VT100 screen. I was running some of these to try and understand them I was using MMedit and quite a few worked ok but all of the lines borders etc would not work.Then none of them worked and I cannot understand what has happened. I tried them on Teraterm and some of them worked as they did on on MMedit. I put the latest software into the micromite and ran the same programme on another computer also using MMedit same result. I am not using a VT100 screen but using the computer screen. These codes are most confusing . There must be some guides on Syntax somewhere. Your help would be greatly appreciated Jeff x=10 y=20 'EXAMPLE OF ESCAPE CODES Main: LOCATE X,Y print "here"; down_ONE_LINE LARGE'DOES NOT WORK print "here"; BORDER 'DOES NOT WORK DRAW_A_LINE 'DOES NOT WORK DRAW_CIRCLE 'DOES NOT WORK pause 5000 Clear_screen'Clear screen and put cursor @ row3 col 6 end Sub Clear_screen x=0 ' used as a counter value that is displayed on the console window Do Print Chr$(27)+"[2J"+Chr$(27)+"[3;6H"; ' Escape codes to clear screen & move cursor to Row 3; Column 6 Print Str$(x); ' Print value of counter at cursor location (set above) x=x+1 ' inc counter Pause 333 ' delay a bit Loop ' and repeat . . . endsub Sub down_ONE_LINE PRINT CHR$(27)+"[<1>B" ' 10= no lines end sub SUB DRAW_A_LINE 'PRINT CHR$(27)+"[+Z1;<0>;<0>;<10>;<20>Z" END SUB Sub DRAW_CIRCLE PRINT CHR$(27)+ "[Z4;240;144;100;Z"; END SUB 'SUB Clear_screen PRINT CHR$(27)+"[f" : PRINT CHR$(27)+"[2J";'J=clear screen from cursor down f=move cusor to upper left END SUB LOCATE X,Y SUB LOCATE X,Y PRINT CHR$(27)+"["+STR$(X)+";"+STR$(Y)+"f"; END SUB COLOR f,b SUB COLOR f,b PRINT CHR$(27)+"[0;"+STR$(f)+";"+STR$(b)+";1m"; END SUB Sub MENU (T$) WIPE Print Chr$(27)+"[6m"; 'Select Jumbo font Print Chr$(27)+"[7m"; 'Select Inverse Video Print Chr$(27)+"[4m"; 'Select Underline mode Print T$ 'Print menu title STANDARD 'Select standard text mode(turn all text attributes off) Print NL$ 'Blank line for space LARGE 'Select Large font End Sub '------------------------------------------------------------------- Sub WIPE Print Chr$(27)+"c"; 'Reset terminal Print Chr$(27)+"[2J"; 'Clear entire screen Print Chr$(27)+"[H"; 'Cursor to top-left End Sub '------------------------------------------------------------------- Sub BORDER Print Chr$(27)+"[Z2;5;5;10;20Z"; 'Draw border box End Sub '------------------------------------------------------------------- Sub LARGE Print Chr$(27)+"[3m"; 'Large font End Sub '------------------------------------------------------------------- Sub STANDARD Print Chr$(27)+"[0m"; 'Standard font End Sub |
MMEdit only uses a subset of the VT100 controls. It is intended for basic use only. You may get better success from TeraTerm or Putty. Jim VK7JH MMedit |
Thanks Jim sorry for delayed reply Yr mmedit is the bees knees I really like it. As regards the escape codes . the only ones I really wanted was to position the cursor and clear the screen. What I find odd is that if I programme using mmedit then switch to teraterm they work ok. For the benefit of others with this problem I found that if I select "VT" in the chat window they work ok . Maybe that is what I should have been doing all along regards Jeff |
That's it. The VT button puts it into VT-100 mode. the A is ASCII mode which does not recognise the esc codes, but is good to se what's being spat out. The other code I use a lot is clear to end of line; It helps tidy thing up if the buffer over runs. Phil. |
