Local Time 01:09 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX/RPI - Program NPOE
cdeagle
Posted: 08:21am 24 Apr 2017
Program NPOE (Numerical Prediction of Orbital Events) was originally developed using FORTRAN. During my career I ported NPOE to other computer languages such as MATLAB and QuickBASIC. Now it has been ported to MMBASIC for both the MicroMite eXtreme and the Raspberry Pi.
From the introduction in the user manual;
NPOE is an interactive computer program which can model important orbital events and predict the long term evolution of satellites in Earth orbits. Program NPOE implements a special perturbation solution of orbital motion using a variable step size Runge-Kutta-Fehlberg (RKF78) integration method to numerically integrate Cowell’s form of the system of differential equations. Orbital events are predicted using Brent’s method for finding the root of a nonlinear equation. The user can control both the integration and root-finding criteria.
The computer program can also simply propagate a user-defined orbit with spacecraft mass properties and perturbations provided by the user.
Let's talk about the MMBASIC MicroMite eXtreme/Raspberry Pi version of NPOE. This is a subset of the full up FORTRAN version. This version consists of 4419 lines of comments, source code, data statements and white space. It's quite a number cruncher and I recommend using a Pi whenever possible.
Here's an example of an event output computed by NPOE. This simulation used an 8 by 8 Earth gravity model during the propagation while finding and displaying flight conditions whenever the geodetic sub-point latitude of the spacecraft was 20 degrees north.
program npoe - numerical prediction of orbital events
degree of gravity model 8
order of gravity model 8
integration tolerance 1.00000e-08
root-finding tolerance 0.0001
initial conditions
calendar date April 18 2017
UTC 0 hours 0 minutes 0.00 seconds
position vector x-component 5.506706064204e+03 kilometers
position vector y-component 5.506706064204e+03 kilometers
position vector z-component 0.000000000000e+00 kilometers
position vector magnitude 7.787658400000e+03 kilometers
velocity vector x-component -4.504405239130e+00 kilometers/second
velocity vector y-component 4.504405239130e+00 kilometers/second
velocity vector z-component 3.458731500160e+00 kilometers/second
velocity vector magnitude 7.248596878486e+00 kilometers/second
semimajor axis 8000.0000 kilometers
eccentricity 0.0265427000
orbital inclination 28.5000 degrees
argument of perigee 0.0000 degrees
argument of latitude 0.0000 degrees
RAAN 45.0000 degrees
true anomaly 360.0000 degrees
Keplerian period 118.6847 minutes
nodal period 118.3855 minutes
anomalistic period 118.5519 minutes
geodetic latitude 0.0000 degrees
geodetic altitude 1409.5221 kilometers
flight path angle 0.0000 degrees
right ascension 45.0000 degrees
declination 0.0000 degrees
east longitude 198.7002 degrees
Here's the link to the zipped archive of the MMBASIC source code and a few other text files.
2017-04-24_175154_npoe.zip
Both the FORTRAN and MATLAB user manuals can be downloaded from my Google Drive collection at https://drive.google.com/drive/folders/0Bx2YPzS0EoweUFR6ZHZ0cVpFWjA?usp=sharing
The initial orbit and epoch, and other important information must be defined by the user in an MMBASIC subroutine named "sim_definition". Here are the contents of a typical definition file. Hopefully the annotation in the source code will help.
sub sim_definition(ri(), vi(), target, fxnew, tfinal)
' define simulation inputs subroutine
local sma, ecc, xinc, argper, raan, tanom
local cmonth, cday, cyear, uthr, utmin, utsec
local jdate, oev(32)
' initial classical orbital elements
' semimajor axis (kilometers; semimajor axis > 0)
sma = 8000.0
' orbital eccentricity (non-dimensional); 0 <= eccentricity < 1)
ecc = 0.0265427
' orbital inclination (degrees); 0 <= inclination <= 180)
xinc = 28.5
' argument of perigee (degrees); 0 <= argument of perigee <= 360)
argper = 0.0
' right ascension of the ascending node (degrees); 0 <= RAAN <= 360)
raan = 45.0
' true anomaly (degrees); 0 <= true anomaly <= 360)
tanom = 0.0
oev(1) = sma
oev(2) = ecc
oev(3) = xinc * dtr
oev(4) = argper * dtr
oev(5) = raan * dtr
oev(6) = tanom * dtr
' request initial calendar date and UTC time
cmonth = 4
cday = 18
cyear = 2017
uthr = 0.0
utmin = 0.0
utsec = 0.0
' simulation period (days)
ndays = 0.25
' simulation period (seconds)
tfinal = 86400.0 * ndays
' algorithm control parameters
' integration error tolerance; a value of 1.0e-8 is recommended)
tetol = 1.0e-8
' root-finding error tolerance; a value between 1.0e-4 and 1.0e-6 is recommended)
rtol = 1.0e-4
' request degree and order of gravity model
' degree of the gravity model (zonals); 0 <= zonals <= 8)
lgrav% = 8
' order of the gravity model (tesserals); 0 <= tesserals <= 8)
mgrav% = 8
' orbital perturbations
' include solar perturbation (1 = yes, 0 = no)
isun% = 1
' include lunar perturbation (1 = yes, 0 = no)
imoon% = 1
' include drag perturbation (1 = yes, 0 = no)
idrag% = 1
' include srp perturbation (1 = yes, 0 = no)
isrp% = 1
' drag coefficient (non-dimensional)
cd = 2.2
' cross-sectional area (square meters)
areadrag = 40.0
' spacecraft mass (kilograms)
scmass = 6078.0
' compute ballistic coefficient
bcoeff = 1.0e-6 * areadrag * cd /scmass
' reflectivity constant (non-dimensional)
reflect = 1.5
areasrp = 10.0
scmass = 6078.0
' compute srp coefficient
csrp0 = 0.000001 * reflect * pss * aunit^2 * areasrp / scmass
' determine initial eci state vector
orb2eci(oev(), ri(), vi())
' compute julian date at initial time
julian(cmonth, cday, cyear, jdate)
jdate0 = jdate + uthr / 24.0 + utmin / 1440.0 + utsec / 86400.0
' compute greenwich sidereal time at initial utc (radians)
gast2(jdate0, gst0)
' determine complete set of initial orbital elements
eci2orb2(0, ri(), vi(), oev())
' select the orbital element to predict
' 1 = geodetic altitude
' 2 = geodetic latitude
' 3 = east longitude
' 4 = geocentric declination
' 5 = true anomaly
' 6 = argument of latitude
' 7 = flight path angle
' 8 = orbital speed
' 9 = right ascension
' NOTE: to propagate without searching
' for events, set ittype% = 0
ittype% = 2
' define target value and compute
' initial value of objective function
select case ittype%
case 0
' propagate without searching for events
case 1
' geodetic altitude (kilometers)
talt = 200.0
fxnew = oev(16) - talt
case 2
' geodetic latitude (degrees); -90 <= latitude <= +90)
xlat = 20.0
tlat = xlat * dtr
fxnew = oev(14) - tlat
case 3
' east longitude (degrees); 0 <= longitude <= 360)
elong = 120.0
tlong = elong * dtr
fxnew = oev(15) - tlong
target = tlong
case 4
' geocentric declination (degrees); -90 <= declination <= +90)
dec = 20.0
tdec = dec * dtr
fxnew = oev(13) - tdec
case 5
tanom = 260.0
ttanom = tanom * dtr
fxnew = oev(6) - ttanom
target = ttanom
case 6
' argument of latitude (degrees); 0 <= arglat <= 360)
arglat = 200.0
targlat = arglat * dtr
fxnew = oev(8) - targlat
target = targlat
case 7
' flight path angle (degrees); -90 <= fpa <= +90)
fpa = 1.0
tfpa = fpa * dtr
fxnew = oev(11) - tfpa
case 8
' orbital speed (kilometers/second)
tspeed = 0.0
fxnew = oev(28) - tspeed
case 9
' right ascension (degrees); 0 <= right ascension <= 360)
rasc = 100.0
trasc = rasc * dtr
fxnew = oev(12) - trasc
target = trasc
end select
end sub
