Local Time 01:10 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : 2 X 16 LCD display
envirotronics
Posted: 09:02pm 23 Apr 2017
Is it possible to interface a maximite Explore 64 to a 2 line by 16 char LCD?
If so, where can I get the driver library?
Graham
Posted: 09:17pm 23 Apr 2017
No need for a driver - just use the built in LCD command.
LCD INIT d4, d5, d6, d7, rs, en (to 'define' the pins used). This is a one time set-up (place early in your code)
Then use the following command to display data (as a string):
LCD line, pos, data$
More information in the MicroMite User Manual (Page 27/28 in v5.03)
envirotronics
Posted: 09:32pm 23 Apr 2017
Thank you Whitewizzard
Much appreciated
Grahamjavascript:AddSmileyIcon('')
