Forum Index : Microcontroller and PC projects : LCD Panel in PORTRAIT Mode
Greetings, In preparation for a project, I'm experimenting with an ILI9341 LCD Panel connected to Micromite+ Explore 64. My plan is to use the LCD in portrait mode. So first off was to alter the pump control demo program to suit the vertical screen orientation, as follows: ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' ' Demonstration program for the Micromite+ ' It does not do anything useful except demo the various controls ' ' Geoff Graham, October 2015 ' GUI layout altered to fit 320x240 (ILI9341) LCD panel ' used in PORTRAIT mode by Vegipete, April 2017 ''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''' Option Autorun On Option Explicit Dim ledsX, ledsY Colour RGB(white), RGB(black) ' reference numbers for the controls are defined as constants Const c_head = 1, c_pmp = 2, sw_pmp = 3, c_flow = 4, tb_flow = 5 Const led_run = 6, led_alarm = 7 Const frm_alarm = 20, nbr_hi = 21, nbr_lo = 22, pb_test =23 Const c_hi = 24, c_lo = 25 Const frm_pump = 30, r_econ = 31, r_norm = 32, r_hi = 33 Const frm_log = 40, cb_enabled = 41, c_fname = 42, tb_fname = 43 Const c_log = 44, cb_flow = 45, cb_pwr = 46, cb_warn = 47 Const cb_alarm = 48, c_bright = 49, sb_bright = 50 CLS GUI Interrupt TouchDown, TouchUp ' now draw the "Pump Control" display ' display the heading Font 2 : GUI Caption c_head, "Pump Control", 45, 0 ' now, define and display the controls ' first display the switch Font 2 : GUI Caption c_pmp, "Pump", 30, 19, , RGB(brown) GUI Switch sw_pmp, "OFF|ON ", 10, 40, 100, 30, RGB(white),RGB(brown) CtrlVal(sw_pmp) = 1 ' the flow rate display box Font 2 : GUI Caption c_flow, "Flow Rate", 5, 70,, RGB(brown),0 Font 2 : GUI Displaybox tb_flow, 5, 90, 105, 25 CtrlVal(tb_flow) = "20.1" ' the radio buttons and their frame ledsX = 125 : ledsY = 30 ' define the position Font 2 : GUI Frame frm_pump, "Power", ledsX, ledsY, 105, 90,RGB(200,20,255) Font 1 ledsX = 145 : ledsY = 52 ' define their position GUI Radio r_econ, "Economy", ledsX, ledsY, 12, RGB(230, 230, 255) GUI Radio r_norm, "Normal", ledsX, MM.VPos+32 GUI Radio r_hi, "High", ledsX, MM.VPos+32 CtrlVal(r_norm) = 1 ' start with the "normal" button selected ' the alarm frame with two number boxes and a push button switch Font 2 : GUI Frame frm_alarm, "Alarm", 10, 175, 90, 95,RGB(green) Font 1 GUI Caption c_hi, "Hi:", 15, 195, LT, RGB(yellow) GUI Numberbox nbr_hi, 45,MM.VPos-6,40,MM.FontHeight+6,RGB(yellow),RGB(64,64,64) GUI Caption c_lo, "Lo:", 15, 215, LT, RGB(yellow),0 GUI Numberbox nbr_lo, 45,MM.VPos-6,40,MM.FontHeight+6,RGB(yellow),RGB(64,64,64) GUI Button pb_test, "TEST", 20, 235, 70, 25,RGB(yellow), RGB(red) CtrlVal(nbr_lo) = 15.7 : CtrlVal(nbr_hi) = 35.5 ' draw the two LEDs ledsX = 20 : ledsY = 130 ' define their position GUI LED led_run, "Running", ledsX, ledsY, 10, RGB(green) ledsY = ledsY+25 GUI LED led_alarm, "Alarm", ledsX, ledsY, 10, RGB(red) CtrlVal(led_run) = 1 ' the switch defaults to on so set the LED on ' the logging frame with check boxes and a text box ledsX = 120 : ledsY = 140 ' define their position Colour RGB(cyan), 0 Font 2 GUI Frame frm_log, "Log File", ledsX, ledsY, 115, 160, RGB(green),0 Font 1 GUI Checkbox cb_enabled, "Log On", ledsX+10, ledsY+15, 20, RGB(cyan) GUI Caption c_fname, "File Name", ledsX+5, ledsY+40 GUI Textbox tb_fname, ledsX+5, ledsY+55, 100, 20, RGB(cyan), RGB(64,64,64) GUI Caption c_log, "Record:", ledsX+5, ledsY+80, , RGB(cyan), 0 GUI Checkbox cb_flow, "Flow", ledsX+10, ledsY+95, 20 GUI Checkbox cb_alarm, "Alarms", ledsX+10, ledsY+115, 20 GUI Checkbox cb_warn, "Warnings", ledsX+10, ledsY+135, 20 CtrlVal(cb_enabled) = 1 CtrlVal(tb_fname) = "LOGFILE.TXT" ' define and display the spinbox for controlling the backlight GUI Caption c_bright, "Back Light", 16, 275,,RGB(200,200,255),0 GUI Spinbox sb_bright, 0, 290, 110, 25,,,5, 0, 100 CtrlVal(sb_bright) = 100 ' All the controls have been defined and displayed. At this point ' the program could do some real work but because this is just a ' demo there is nothing to do. So it just sits in a loop. Do : Loop ' the interrupt routine for touch down ' using a select case command it has a different process for each ' control Sub TouchDown Select Case Touch(REF) ' find out the control touched Case cb_enabled ' the enable check box If CtrlVal(cb_enabled) Then GUI Restore c_fname, tb_fname, c_log, cb_flow, cb_alarm, cb_warn Else GUI Disable c_fname, tb_fname, c_log, cb_flow, cb_alarm, cb_warn EndIf Case sb_bright ' the brightness spin box 'BackLight CtrlVal(sb_bright) Case sw_pmp ' the pump on/off switch Print CtrlVal(sw_pmp) CtrlVal(led_run) = CtrlVal(sw_pmp) CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 20.1) CtrlVal(r_norm) = 1 Case pb_test ' the alarm test button 'Open "Test.txt" For Append As #1 'Print "File Opened" 'Print #1, "Hello World", Time$ 'Print "Hello World", Time$ 'Close #1 'Print "File Closed" CtrlVal(led_alarm) = 1 'GUI beep 250 Case r_econ ' the economy radio button CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 18.3) Case r_norm ' the normal radio button CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 20.1) Case r_hi ' the high radio button CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 23.7) End Select End Sub ' interrupt routine when the touch is removed Sub TouchUp Select Case Touch(LASTREF) ' use the last reference Case pb_test ' was it the test button CtrlVal(led_alarm) = 0 ' turn off the LED End Select End Sub This works very nicely. Hats off to Geoff (and community) for such a marvelous and easy to use system to rapidly create such a GUI! Fantastic job! My question pertains to the GUI NUMBERBOX and GUI TEXTBOX controls. I am not completely satisfied with the onscreen results. Note I haven't tried this in landscape mode to compare. The NUMBERBOX fills the entire screen with the 12 position keypad with odd overwriting effects of the display value as you type digits. Is this to be expected? The biggest difficulty is that the original value is not visible. Perhaps the keypad could be shrunk vertically a bit and a number field positioned in the new space above showing either the original value or the ghost text hint? The TEXTBOX works well enough except the keyboard is somewhat small because it has to be squashed into the narrow width of portrait mode. An evil non-qwerty keyboard with strange proportions is not desirable so I guess there's nothing much that can be done about that. I notice that the keyboard reverts to capital letters when returning from the number/symbol keyboard, even if lower case was selected. Is that ideal? Also, the text entry field can appear below the on-screen keyboard, making it difficult to see what you're typing. Would it be difficult or confusing to change this to a dedicated entry line above the keyboard? Finally, editing the existing text value is not possible. Might this ability get created in the future? Especially if the ability to evaluate strings were added to the number entry field? Thanks for the amazing work! Pete Visit Vegipete's *Mite Library for cool programs. |
