Local Time 02:00 02 Nov 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : GUI Demos
retepsnikrep
Posted: 08:42am 21 Apr 2017
Could people kindly add working demo code for GUI controls.
I was sure there was a demo which showed all the controls but i can't find it.
Others showing the latest developments would be a great help to study.
I have snatched a few samples from the forum but it is still a steep learning curve.
I'm running an Extreme 144 with 7" SDD 1963 display if that helps
Thanks..
Gen1 Honda Insights.
Posted: 11:59am 21 Apr 2017
Micromite Plus Manual under Examples
In my copy, it starts on page 39
It may not have all the GUI elements but it's a good start.
panky
Posted: 01:53pm 21 Apr 2017
@retepsnikrep
Peter,
A copy of Geoff's program to save you typing it in - just select the code below and paste into MMEdit for download to your MZ 144.
Note as Geoff says in the manual, it is just a demo of GUI controls. Have fun.
Doug.
' Pump Control program from Micromite Plus Manual
' Geoff Graham 2016
Option Explicit
Dim ledsY
Colour RGB(white), RGB(black)
' reference numbers for the controls are defined as constants
Const c_head = 1, c_pmp = 2, sw_pmp = 3, c_flow = 4, tb_flow = 5
Const led_run = 6, led_alarm = 7
Const frm_alarm = 20, nbr_hi = 21, nbr_lo = 22, pb_test =23
Const c_hi = 24, c_lo = 25
Const frm_pump = 30, r_econ = 31, r_norm = 32, r_hi = 33
Const frm_log = 40, cb_enabled = 41, c_fname = 42, tb_fname = 43
Const c_log = 44, cb_flow = 45, cb_pwr = 46, cb_warn = 47
Const cb_alarm = 48, c_bright = 49, sb_bright = 50
' now draw the "Pump Control" display
CLS
GUI Interrupt TouchDown, TouchUp
' display the heading
Font 2,2 : GUI Caption c_head, "Pump Control", 10, 0
Font 3 : GUI Caption c_pmp, "Pump", 20, 60, , RGB(brown)
' now, define and display the controls
' first display the switch
Font 4
GUI Switch sw_pmp, "ON|OFF", 20, 90, 150, 50, RGB(white),RGB(brown)
CtrlVal(sw_pmp) = 1
' the flow rate display box
Font 3 : GUI Caption c_flow, "Flow Rate", 20, 170,, RGB(brown),0
Font 4 : GUI Displaybox tb_flow, 20, 200, 150, 45
CtrlVal(tb_flow) = "20.1"
' the radio buttons and their frame
Font 3 : GUI Frame frm_pump, "Power", 20, 290, 170, 163,RGB(200,20,255)
GUI Radio r_econ, "Economy", 35, 318, 25, RGB(230, 230, 255)
GUI Radio r_norm, "Normal", 35, 364
GUI Radio r_hi, "High", 35, 408
CtrlVal(r_norm) = 1 ' start with the "normal" button selected
' the alarm frame with two number boxes and a push button switch
Font 3 : GUI Frame frm_alarm, "Alarm", 220, 220, 200, 233,RGB(green)
GUI Caption c_hi, "High:", 232, 260, LT, RGB(yellow)
GUI Numberbox nbr_hi, 318,MM.VPos-6,90,MM.FontHeight+12,RGB(yellow),RGB(64,64,64)
GUI Caption c_lo, "Low:", 232, 325, LT, RGB(yellow),0
GUI Numberbox nbr_lo, 318,MM.VPos-6,90,MM.FontHeight+12,RGB(yellow),RGB(64,64,64)
GUI Button pb_test, "TEST", 257, 383, 130, 40,RGB(yellow), RGB(red)
CtrlVal(nbr_lo) = 15.7 : CtrlVal(nbr_hi) = 35.5
' draw the two LEDs
Const ledsX = 240, coff = 50 ' define their position
ledsY = 90 : GUI LED led_run, "Running", ledsX, ledsY, 30, RGB(green)
ledsY = ledsY+49 : GUI LED led_alarm, "Alarm", ledsX, ledsY, 30, RGB(red)
CtrlVal(led_run) = 1 ' the switch defaults to on so set the LED on
' the logging frame with check boxes and a text box
Colour RGB(cyan), 0
GUI Frame frm_log, "Log File", 450, 20, 330, 355, RGB(green),0
GUI Checkbox cb_enabled, "Logging Enabled", 470, 50, 30, RGB(cyan)
GUI Caption c_fname, "File Name", 470, 105
GUI Textbox tb_fname, 470, 135, 290, 40, RGB(cyan), RGB(64,64,64)
GUI Caption c_log, "Record:", 470, 205, , RGB(cyan), 0
GUI Checkbox cb_flow, "Flow Rate", 500, 245, 25
GUI Checkbox cb_alarm, "Alarms", 500, 285, 25
GUI Checkbox cb_warn, "Warnings", 500, 325, 25
CtrlVal(cb_enabled) = 1
CtrlVal(tb_fname) = "LOGFILE.TXT"
' define and display the spinbox for controlling the backlight
GUI Caption c_bright, "Backlight", 442, 415,,RGB(200,200,255),0
GUI Spinbox sb_bright, MM.HPos + 8, 400, 200, 50,,,10, 10, 100
CtrlVal(sb_bright) = 100
' All the controls have been defined and displayed. At this point
' the program could do some real work but because this is just a
' demo there is nothing to do. So it just sits in a loop.
Do : Loop
' the interrupt routine for touch down
' using a select case command it has a different process for each
' control
Sub TouchDown
Select Case Touch(REF) ' find out the control touched
Case cb_enabled ' the enable check box
If CtrlVal(cb_enabled) Then
GUI Restore c_fname, tb_fname, c_log, cb_flow, cb_alarm, cb_warn
Else
GUI Disable c_fname, tb_fname, c_log, cb_flow, cb_alarm, cb_warn
Case sb_bright ' the brightness spin box
BackLight CtrlVal(sb_bright)
Case sw_pmp ' the pump on/off switch
CtrlVal(led_run) = CtrlVal(sw_pmp)
CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 20.1)
CtrlVal(r_norm) = 1
Case pb_test ' the alarm test button
CtrlVal(led_alarm) = 1
GUI beep 250
Case r_econ ' the economy radio button
CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 18.3)
Case r_norm ' the normal radio button
Case r_hi ' the high radio button
CtrlVal(tb_flow) = Str$(CtrlVal(sw_pmp) * 23.7)
End Select
' interrupt routine when the touch is removed
Sub TouchUp
Select Case Touch(LASTREF) ' use the last reference
Case pb_test ' was it the test button
CtrlVal(led_alarm) = 0 ' turn off the LED
End Select
Edited by panky 2017-04-22
paceman
Posted: 07:08pm 21 Apr 2017
The Manual's p39 pump demo should be allright with @retepsnikrep's 7" display, but it throws some errors with my 4.3" display (SSD1963 480x272 in landscape mode). At a quick look it seems some of the controls are defined outside the range of the 4.3 inch-er.
Guess that should be noted in the Manual.
Greg
Posted: 09:11pm 21 Apr 2017
  paceman said  Guess that should be noted in the Manual.
Good point, I will do that.
Phil23
Posted: 11:26pm 21 Apr 2017
  paceman said  it throws some errors with my 4.3" display (SSD1963 480x272 in landscape mode). At a quick look it seems some of the controls are defined outside the range of the 4.3 inch-er.
Try this Version.
I think it's the one I modified to run on the CGMicro2 with a 320 240 display.
Tiny stuff but it did work.
Phil.
[code]'''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''''
' Demonstration program for the Micromite+
' It does not do anything useful except demo the various controls
' Geoff Graham, October 2015
Option Autorun On
Option Explicit
Dim ledsY
CLS
Font 2 : GUI Caption c_head, "Pump Control", 10, 0
Font 2 : GUI Caption c_pmp, "Pump", 10, 25, , RGB(brown)
Font 2
GUI Switch sw_pmp, "OFF|ON", 10, 45, 70, 30, RGB(white),RGB(brown)
CtrlVal(sw_pmp) = 1
Font 2 : GUI Caption c_flow, "Flow Rate", 5, 75,, RGB(brown),0
Font 2 : GUI Displaybox tb_flow, 5, 100, 105, 25
Font 2 : GUI Frame frm_pump, "Power", 5, 140, 105, 90,RGB(200,20,255)
Font 1
GUI Radio r_econ, "Economy", 10, 150, 25, RGB(230, 230, 255)
GUI Radio r_norm, "Normal", 10, 175
GUI Radio r_hi, "High", 10, 200
Font 2 : GUI Frame frm_alarm, "Alarm", 115, 115, 90, 115,RGB(green)
Font 1
GUI Caption c_hi, "Hi:", 120, 150, LT, RGB(yellow)
GUI Numberbox nbr_hi, 150,MM.VPos-6,40,MM.FontHeight+6,RGB(yellow),RGB(64,64,64)
GUI Caption c_lo, "Lo:", 120, 175, LT, RGB(yellow),0
GUI Numberbox nbr_lo, 150,MM.VPos-6,40,MM.FontHeight+6,RGB(yellow),RGB(64,64,64)
GUI Button pb_test, "TEST", 125, 200, 70, 25,RGB(yellow), RGB(red)
' draw the two LEDs
Const ledsX = 125, coff = 50 ' define their position
ledsY = 50 : GUI LED led_run, "Running", ledsX, ledsY, 16, RGB(green)
ledsY = ledsY+25 : GUI LED led_alarm, "Alarm", ledsX, ledsY, 16, RGB(red)
Colour RGB(cyan), 0
Font 2
GUI Frame frm_log, "Log File", 210, 10, 110, 160, RGB(green),0
Font 1
GUI Checkbox cb_enabled, "Log On", 215, 20, 20, RGB(cyan)
GUI Caption c_fname, "File Name", 215, 45
GUI Textbox tb_fname, 215, 60, 100, 20, RGB(cyan), RGB(64,64,64)
GUI Caption c_log, "Record:", 215, 85, , RGB(cyan), 0
GUI Checkbox cb_flow, "Flow", 220, 100, 20
GUI Checkbox cb_alarm, "Alarms", 220, 120, 20
GUI Checkbox cb_warn, "Warnings", 220, 140, 20
GUI Caption c_bright, "Back Light", 230, 190,,RGB(200,200,255),0
GUI Spinbox sb_bright, 210, 210, 110, 25,,,10, 10, 100
Do : Loop
' control
Sub TouchDown
Else
Print CtrlVal(sw_pmp)
CtrlVal(r_norm) = 1
Open "Test.txt" For Append As #1
Print "File Opened"
Print #1, "Hello World", Time$
Print "Hello World", Time$
Close #1
Print "File Closed"
GUI beep 250
End Select
Sub TouchUp
End Select
[/code]
paceman
Posted: 02:35am 22 Apr 2017
Yes that works OK on the 4.3 inch-er. Leaves some spare room but shows the idea.
As-is there's a double-barreled shotgun down at the 'Power' radio buttons; these few changes on lines 39 to 41 fix that.
Greg
GUI Radio r_econ, "Economy", 20, 160, 10, RGB(230, 230, 255)
GUI Radio r_norm, "Normal", 20, 185
GUI Radio r_hi, "High", 20, 210
Phil23
Posted: 12:58am 12 Feb 2020
Just reloaded this in a new E100 with 5.05.01 & get a error.
  Quote  GUI Frame frm_log, "Log File", 450, 20, 330, 355, RGB(green),0
Line [56]
Error: Argument count
Easily fixed by removing ",0" from the lines end, but may be worth a change in the manual for the new comers @geoffg.
Phil.
Edit:-
Is it just me or do others feel the display behaviour of the switch is back the front?
As in the "On" side is bigger & brighter when the switch is in the off position?
And Vise versa.
Edited 2020-02-12 11:19 by Phil23
mikeb
Posted: 06:49am 12 Feb 2020
@Phil23
I thought the same, on first glance, but then reasoned that the 'brighter' object was the target of my intention. It got me past what I originally thought was odd.
@all you wizards out there.
It would be great to have an application that created a work space, from a drop down menu, with the intended display resolution. It would also have a list of icons representing the available controls which could be placed on the work space giving a 'real' representation of how the display would look at 'runtime'. These controls could be 'rescaled' on the fly. Font size could also be selected. It would also create the 'Page' structure.
In the background, it would create the necessary code to allow pasting into a users 'runtime' environment. It would take so much time out of the 'visualisation' required when writing code.
This is a similar concept to the 4D Systems IDE.
regards, Mike B.
Edited 2020-02-12 16:51 by mikeb
There are 10 kinds of people in the world.
Those that understand binary and those that don't.
