Forum Index : Microcontroller and PC projects : Time
| lew247 Guru Joined: 23/12/2015 Location: United KingdomPosts: 1709 |
Is it possible to convert Unix time to local or GMT or UTC time on the micromite? Has anyone any code for doing it if it is now possible? |
This is the code in C, I'm sure someone can help convert it. It looks a bit complex but it is really quite simple % = MOD && = AND || = OR ! = NOT == means = in an IF statement --y1 = y=y-1 a+=b = a=a+b while { = DO WHILE ... } LOOP use integer divide \ thoughout rather than / all variables are integers enum _WEEK_DAYS_ { 327 SUNDAY, 328 MONDAY, 329 TUESDAY, 330 WEDNESDAY, 331 THURSDAY, 332 FRIDAY, 333 SATURDAY 334 }; 335 336 /** 337 Enumerated labels for the months. 338 */ 339 enum _MONTHS_ { 340 JANUARY, 341 FEBRUARY, 342 MARCH, 343 APRIL, 344 MAY, 345 JUNE, 346 JULY, 347 AUGUST, 348 SEPTEMBER, 349 OCTOBER, 350 NOVEMBER, 351 DECEMBER 352 }; struct tm { 145 int8_t tm_sec; /**< seconds after the minute - [ 0 to 59 ] */ 146 int8_t tm_min; /**< minutes after the hour - [ 0 to 59 ] */ 147 int8_t tm_hour; /**< hours since midnight - [ 0 to 23 ] */ 148 int8_t tm_mday; /**< day of the month - [ 1 to 31 ] */ 149 int8_t tm_wday; /**< days since Sunday - [ 0 to 6 ] */ 150 int8_t tm_mon; /**< months since January - [ 0 to 11 ] */ 151 int16_t tm_year; /**< years since 1900 */ 152 int16_t tm_yday; /**< days since January 1 - [ 0 to 365 ] */ 153 int16_t tm_isdst; /**< Daylight Saving Time flag */ 154 }; #define YEAR0 1900 /* the first year */ #define EPOCH_YR 1970 /* EPOCH = Jan 1 1970 00:00:00 */ #define SECS_DAY (24L * 60L * 60L) #define LEAPYEAR(year) (!((year) % 4) && (((year) % 100) || !((year) % 400))) #define YEARSIZE(year) (LEAPYEAR(year) ? 366 : 365) #define FIRSTSUNDAY(timp) (((timp)->tm_yday - (timp)->tm_wday + 420) % 7) #define FIRSTDAYOF(timp) (((timp)->tm_wday - (timp)->tm_yday + 420) % 7) const int _ytab[2][12] = { { 31, 28, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 }, { 31, 29, 31, 30, 31, 30, 31, 31, 30, 31, 30, 31 } }; /* Number of days per month (except for February in leap years). */ static const int monoff[] = { 0, 31, 59, 90, 120, 151, 181, 212, 243, 273, 304, 334 }; static int is_leap_year(int year) { return year % 4 == 0 && (year % 100 != 0 || year % 400 == 0); } static int leap_days(int y1, int y2) { --y1; --y2; return (y2/4 - y1/4) - (y2/100 - y1/100) + (y2/400 - y1/400); } time_t timegm(const struct tm *tm) { int year; time_t days; time_t hours; time_t minutes; time_t seconds; year = 1900 + tm->tm_year; days = 365 * (year - 1970) + leap_days(1970, year); days += monoff[tm->tm_mon]; if (tm->tm_mon > 1 && is_leap_year(year)) ++days; days += tm->tm_mday - 1; hours = days * 24 + tm->tm_hour; minutes = hours * 60 + tm->tm_min; seconds = minutes * 60 + tm->tm_sec; return seconds; } struct tm * gmtime(const time_t *timer) { static struct tm br_time; register struct tm *timep = &br_time; time_t time = *timer; register unsigned long dayclock, dayno; int year = EPOCH_YR; dayclock = (unsigned long)time % SECS_DAY; dayno = (unsigned long)time / SECS_DAY; timep->tm_sec = dayclock % 60; timep->tm_min = (dayclock % 3600) / 60; timep->tm_hour = dayclock / 3600; timep->tm_wday = (dayno + 4) % 7; /* day 0 was a thursday */ while (dayno >= YEARSIZE(year)) { dayno -= YEARSIZE(year); year++; } timep->tm_year = year - YEAR0; timep->tm_yday = dayno; timep->tm_mon = 0; while (dayno >= _ytab[LEAPYEAR(year)][timep->tm_mon]) { dayno -= _ytab[LEAPYEAR(year)][timep->tm_mon]; timep->tm_mon++; } timep->tm_mday = dayno + 1; timep->tm_isdst = 0; return timep; } |
Sorry for my 'C' ignorance but with something like: timep->tm_sec = dayclock % 60; does the left hand side of the '=' symbol refer to the variable name; OR is there some arithmetic stuff happening with the '->' inclusion of the left hand side? Put another way - what does this translate into in MMBASIC? WW |
jman![]() Guru Joined: 12/06/2011 Location: New ZealandPosts: 711 |
Hi I do it like this the code is a little old but take a look here NTP Clock LB% = LB% - 2208988800 ' - 70 Years start @ 1/1/1970 Epoch time Jan2014 = LB% - 1388534400 'Start at Jan 1/1/2014 TimeZone = (TZ*60*60) 'Set TimeZone Jan2014=Jan2014+TimeZone 'Adjust for Timezone Year=2014 'Set Year to 2014 GetYear: LEAP = Year Mod 4 '0 if leap year If LEAP = 0 Then SecondsInYear = 31622400 '366*60*60**24 Else SecondsInYear = 31536000 '365*60*60*24 EndIf If Jan2014 > SecondsInYear Then Jan2014 = Jan2014 - SecondsInyear Year = Year + 1 GoTo GetYear EndIf Month = 1 ' Start with Month = 1 GetMonth: SecondsInMonth = Months(Month) If Leap = 0 Then If Month = 2 Then SecondsInMonth=LeapMnth EndIf EndIf If Jan2014 >= SecondsInMonth Then Jan2014 = Jan2014 - SecondsInMonth Month = Month+1 GoTo GetMonth EndIf FindDays: Day = Int(Jan2014/86400) Jan2014 = Jan2014 Mod 86400 Hour = Int(Jan2014/3600) Jan2014 = Jan2014 Mod 3600 Min = Int(Jan2014/60) Jan2014 = Jan2014 Mod 60 Sec = Jan2014 Day = Day + 1 If DST = 1 Then GoSub DsTime If CurrDT < DsStop Or CurrDT > DsStart Then Hour = Hour + 1 EndIf EndIf If Hour=24 Then hour=0 Date$=Str$(Day)+"/"+Str$(Month)+"/"+Str$(Year) Time$=Str$(Hour)+":"+Str$(Min)+":"+Str$(Sec) Print Time$ Print Date$ Regards Jman |
