Local Time 00:24 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - Kepler’s equation
cdeagle
Posted: 12:18am 11 Apr 2017
This post describes several MMBASIC subroutines for the MicroMite eXtreme that can be used to solve Kepler's equation for circular, elliptical, parabolic and hyperbolic orbits. A short program demonstrates how to interact with each routine.
The following is a typical user interaction with the Kepler subroutines.
numerical solutions of Kepler's equation
please input the orbital eccentricity (non-dimensional)
(0 <= eccentricity)
? .78359
please input the mean anomaly in degrees
(0 <= mean anomaly <= 360)
? 221.892
kepler1 solution
eccentricity = 0.78359000
mean anomaly = 221.89200000 degrees
eccentric anomaly = 203.78501394 degrees
true anomaly = 188.39107605 degrees
iterations = 3
solution error = 0.0000000000
kepler2 solution
iterations = 2
kepler3 solution
iterations = 2
solution error = -0.0000000000
Here's a PDF document that summarizes the mathematics of each numerical method.
2017-04-11_101031_kepler.pdf
Here's the MMBASIC source code for the demo program and subroutines.
' demo_kepler.bas April 11, 2017
' demonstrates how to interact with several MMBASIC
' subroutines which solve Kepler's equation for
' circular, elliptic, parabolic and hyperbolic orbits
' MicroMite eXtreme version
option default float
option base 1
const pi2 = 2.0 * pi, pidiv2 = 0.5 * pi
const dtr = pi / 180.0, rtd = 180.0 / pi
print " "
print "numerical solutions of Kepler's equation"
print "----------------------------------------"
do
print " "
print "please input the orbital eccentricity (non-dimensional)"
print "(0 <= eccentricity)"
print " "
input ecc
loop until (ecc >= 0.0)
if (ecc <> 1.0) then
do
print " "
print "please input the mean anomaly in degrees"
print "(0 <= mean anomaly <= 360)"
print " "
input manom
loop until (manom >= 0.0 and manom <= 360.0)
manom = dtr * manom
end if
print " "
' circular, elliptic and hyperbolic orbits
print "kepler1 solution"
print "----------------"
print " "
kepler1(manom, ecc, eanom, tanom, niter%)
kprint(ecc, manom, eanom, tanom, niter%)
print "kepler2 solution"
print " "
kepler2 (manom, ecc, eanom, tanom, niter%)
if (ecc < 1.0) then
print "kepler3 solution"
print " "
kepler3 (manom, ecc, eanom, tanom)
kprint(ecc, manom, eanom, tanom, 2)
end if
else
' parabolic orbits
do
print " "
print "please input the time relative to perihelion passage (days)"
print " "
input tpp
loop until (tpp >= 0.0)
do
print " "
print "please input the perihelion radius (AU)"
print " "
input rp
loop until (rp > 0.0)
kepler4(tpp, rp, ecc, rmag, tanom, niter%)
print " "
print "kepler4 solution"
print " "
print "time wrt perihelion ", str$(tpp, 0, 8), " days"
print " "
print "eccentricity ", str$(ecc, 0, 10)
print " "
print "perihelion radius ", str$(rp, 0, 8), " AU"
print " "
print "heliocentric distance ", str$(rmag, 0, 8), " AU"
print " "
print "true anomaly ", str$(rtd * tanom, 0, 8), " degrees"
print " "
print "iterations ", niter%
print " "
end if
end
sub kepler1 (manom, ecc, eanom, tanom, niter%)
' solve Kepler's equation for circular,
' elliptic and hyperbolic orbits
' Danby's method
' input
' manom = mean anomaly (radians)
' ecc = orbital eccentricity (non-dimensional)
' output
' eanom = eccentric anomaly (radians)
' tanom = true anomaly (radians)
' niter% = number of algorithm iterations
local ktol, xma, s, c, f, fp, fpp, fppp
local delta, deltastar, deltak, sta, cta
' define convergence criterion
ktol = 1.0e-10
xma = manom - pi2 * fix(manom/pi2)
' initial guess
if (ecc = 0.0) then
' circular orbit
tanom = xma
eanom = xma
return
elseif (ecc < 1.0) then
' elliptic orbit
eanom = xma + 0.85 * sgn(sin(xma)) * ecc
else
' hyperbolic orbit
eanom = log(2.0 * xma / ecc + 1.8)
end if
' perform iterations
niter% = 0
do
if (ecc < 1.0) then
' elliptic orbit
s = ecc * sin(eanom)
c = ecc * cos(eanom)
f = eanom - s - xma
fp = 1.0 - c
fpp = s
fppp = c
else
' hyperbolic orbit
s = ecc * sinh(eanom)
c = ecc * cosh(eanom)
f = s - eanom - xma
fp = c - 1.0
fpp = s
fppp = c
end if
niter% = niter% + 1
' check for convergence
if (abs(f) <= ktol or niter% > 20) then exit do
' update eccentric anomaly
delta = -f / fp
deltastar = -f / (fp + 0.5 * delta * fpp)
deltak = -f / (fp + 0.5 * deltastar * fpp + deltastar * deltastar * fppp / 6.0)
eanom = eanom + deltak
loop
if (niter% > 20) then
print " "
print "more than 20 iterations in kepler1"
stop
end if
' compute true anomaly
if (ecc < 1.0) then
' elliptic orbit
sta = sqr(1.0 - ecc * ecc) * sin(eanom)
cta = cos(eanom) - ecc
else
' hyperbolic orbit
sta = sqr(ecc * ecc - 1.0) * sinh(eanom)
cta = ecc - cosh(eanom)
end if
tanom = atan3(sta, cta)
end sub
sub kepler2 (manom, ecc, eanom, tanom, niter%)
' Danby's method with Mikkola's initial guess
' input
' output
local ktol, den, xma, alpha, beta, z, s, ds
local f, fp, fpp, fppp
ktol = 1.0e-10
if (ecc = 0.0) then
' circular orbit
tanom = manom
eanom = manom
return
end if
den = 1.0 / (4.0 * ecc + 0.5)
if (ecc < 1.0) then
xma = manom - pi2 * fix(manom / pi2)
alpha = (1.0 - ecc) * den
else
xma = manom
alpha = (ecc - 1.0) * den
end if
beta = 0.5 * xma * den
z = (sqr(alpha * alpha * alpha + beta * beta) + beta) ^ (1.0/3.0)
s = 2 * beta /(z * z + alpha + alpha * alpha / (z * z))
if (ecc > 1.0) then
' hyperbolic orbit
ds = 0.071 * s ^ 5 / (ecc * (1.0 + 0.45 * s ^ 2) * (1.0 + 4.0 * s ^ 2))
else
' elliptic orbit
ds = -0.078 * s * s * s * s * s / (1.0 + ecc)
end if
s = s + ds
' initial guess
if (ecc > 1.0) then
' hyperbolic orbit
eanom = 3 * log(s + sqr(1 + s ^ 2))
else
' elliptic orbit
eanom = xma + ecc * (3.0 * s - 4.0 * s * s * s)
end if
niter% = 0
do
if (ecc < 1.0) then
' elliptic orbit
f = eanom - s - xma
fp = 1.0 - c
fpp = s
fppp = c
else
' hyperbolic orbit
f = s - eanom - xma
fp = c - 1.0
fpp = s
fppp = c
end if
niter% = niter% + 1
if (abs(f) <= ktol) then exit do
delta = -f / fp
loop
print " "
Print "more than 20 iterations in kepler2"
stop
end if
if (ecc < 1.0) then
' elliptic orbit
sta = sqr(1 - ecc * ecc) * sin(eanom)
else
' hyperbolic orbit
sta = sqr(ecc * ecc - 1) * sinh(eanom)
end if
end sub
sub kepler3 (manom, ecc, eanom, tanom)
' solve Kepler's equation for elliptic orbits
' Gooding's two iteration method
' input
' output
local athird, ahalf, e1, emr, e, ee, sta, cta
local w, f, fd, fdd, fddd, dee
athird = 1.0 / 3.0
ahalf = 1.0 / 2.0
' convert to original algorithm argument
e1 = 1.0 - ecc
if (ecc = 0.0) then
' circular orbit
tanom = manom
eanom = manom
return
end if
' mod mean anomaly
emr = manom - pi2 * fix(manom / pi2)
if (emr < -pi) then
emr = emr + pi2
end if
if (emr > pi) then
emr = emr - pi2
end if
ee = emr
if (ee < 0.0) then
ee = -ee
elseif (ee = 0) then
eanom = ee + (manom - emr)
return
end if
e = 1.0 - e1
' solve cubic equation
dcbsol(e, 2.0 * e1, 3.0 * ee, w)
ee = (ee * ee + (pi - ee) * w) / pi
if (emr < 0.0) then
ee = -ee
end if
for i% = 1 to 2
fdd = e * sin(ee)
fddd = e * cos(ee)
if ((e1 + ee * ee / 6.0) >= 0.25) then
f = (ee - fdd) - emr
fd = 1.0 - fddd
else
emkep(e1, ee, etmp)
f = etmp - emr
fd = e1 + 2.0 * e * sin(ahalf * ee) ^ 2
end if
dee = f * fd / (ahalf * f * fdd - fd * fd)
w = fd + ahalf * dee * (fdd + athird * dee * fddd)
fd = fd + dee * (fdd + ahalf * dee * fddd)
ee = ee - (f - dee * (fd - w)) / fd
next i%
end sub
sub dcbsol (a, b, c, y)
' solve cubic equation function
local bsq, d
if (a = 0.0 and b = 0.0 or c = 0) then
y = 0.0
else
bsq = b * b
d = sqr(a) * abs(c)
d = dcubrt(d + sqr(b * bsq + d * d)) ^ 2
y = 2.0 * c / (d + b + bsq / d)
end if
end sub
function dcubrt(x) as float
' cube root function
local athird, yy, tmp
athird = 1.0 / 3.0
yy = abs(x)
if (x = 0.0) then
tmp = 0.0
else
tmp = yy ^ athird
tmp = tmp - athird * (tmp - yy / tmp ^ 2)
tmp = sgn(x) * tmp
end if
dcubrt = tmp
end function
sub emkep(e1, ee, y)
' solves ee - (1 - e1) * sin(ee)
' when (e1, ee) is close to (1, 0)
local ee2, term, d, y0
y = e1 * ee
ee2 = -ee * ee
term = ee * (1.0 - e1)
d = 0.0
do
d = d + 2
term = term * ee2 / (d * (d + 1))
y0 = y
y = y - term
if (y0 = y) then
exit do
end if
loop
end sub
sub kepler4(t, q, ecc, r, tanom, niter%)
' Kepler's equation for heliocentric,
' parabolic and near-parabolic orbits
' input
' t = time relative to perihelion passage (days)
' q = perihelion radius (AU)
' output
' r = heliocentric distance (AU)
local e2, fac, tau, e20, a, b, u, u2
local c1, c2, c3, x, y
const kgauss = 0.01720209895
e2 = 0.0
fac = 0.5 * ecc
niter% = 0
tau = kgauss * t
do
niter% = niter% + 1
e20 = e2
a = 1.5 * sqr(fac / (q * q * q)) * tau
b = (sqr(a * a + 1.0) + a)^(1.0/3.0)
u = b - 1.0 / b
u2 = u * u
e2 = u2 * (1.0 - ecc) / fac
stumpff(e2, c1, c2, c3)
fac = 3.0 * ecc * c3
if (abs(e2 - e20) < 1.0e-9) then exit do
loop
if (niter% > 15) then
print " "
print "more than 15 iterations in kepler4"
stop
end if
' heliocentric distance (AU)
r = q * (1.0 + u2 * c2 * ecc / fac)
' x and y coordinates
x = q * (1.0 - u2 * c2 / fac)
y = q * sqr((1.0 + ecc) / fac) * u * c1
' true anomaly (radians)
tanom = atan3(y, x)
end sub
sub stumpff(e2, c1, c2, c3)
' Stumpff functions for argument E^2
' input
' e2 = eccentric anomaly squared
' output
' c1, c2, c3 = Stumpff functions
local deltac, n%
c1 = 0.0
c2 = 0.0
c3 = 0.0
deltac = 1.0
n% = 1
do
c1 = c1 + deltac
deltac = deltac / (2.0 * n%)
c2 = c2 + deltac
deltac = deltac / (2.0 * n% + 1.0)
c3 = c3 + deltac
deltac = -e2 * deltac
n% = n% + 1
if (abs(deltac) < 1.0e-12) then exit do
loop
end sub
sub kprint(ecc, manom, eanom, tanom, niter%)
' print results subroutine
local kerror
if (ecc < 1.0) then
' circular and elliptic orbits
print "eccentricity = ", str$(ecc, 0, 8)
print " "
print "mean anomaly = ", str$(rtd * manom, 0, 8), " degrees"
print " "
print "eccentric anomaly = ", str$(rtd * eanom, 0, 8), " degrees"
print " "
print "true anomaly = ", str$(rtd * tanom, 0, 8), " degrees"
print " "
print "iterations = ", niter%
print " "
kerror = eanom - ecc * sin(eanom) - manom
print "solution error = ", str$(kerror, 0, 10)
print " "
else
' hyperbolic orbits
print " "
print "hyperbolic anomaly = ", str$(rtd * manom, 0, 8), " degrees"
print " "
print " "
print " "
print " "
kerror = ecc * sinh(eanom) - eanom - manom
print " "
end if
end sub
function cosh(x) as float
' hyperbolic cosine function
cosh = 0.5 * (exp(x) + exp(-x))
end function
function sinh(x) as float
' hyperbolic sine function
sinh = 0.5 * (exp(x) - exp(-x))
end function
function atan3(a, b) as float
' four quadrant inverse tangent function
' input
' a = sine of angle
' b = cosine of angle
' output
' atan3 = angle (0 =< atan3 <= 2 * pi; radians)
local c
if (abs(a) < 1.0e-10) then
atan3 = (1.0 - sgn(b)) * pidiv2
exit function
else
c = (2.0 - sgn(a)) * pidiv2
endif
if (abs(b) < 1.0e-10) then
atan3 = c
exit function
else
atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2)
endif
end function
