Local Time 23:24 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : ESP8266 + HC-12
Phil23
Posted: 02:20pm 08 Apr 2017
Just want to knock a little board to connect to the E-100 and have an ESP-01 for the console & a HC-12 for Com1.
Was just going to use the 40 way header & a fly lead for the console.
The board would only have the 2 modules + a 1000uF & 0.1uF cap for each device.
Just wondering if I'm also better off to add a separate 3.3V reg & one more 0.1uF cap to run the ESP off it's own reg instead of the E-100's 3.3v supply.
Tiny extra effort if it's more stable.
Phil.
PS. Any issues if the two modules are just cm apart?
Posted: 03:05pm 08 Apr 2017
The ESP is power hungry and power sensitive.
I would go with a dedicated reg.
lew247
Posted: 12:27am 09 Apr 2017
  TassyJim said   The ESP is power hungry and power sensitive.
I can confirm that
I had to change the reg on the E100 board for a larger one for it to work properly all the time with the esp on my weather board
