Local Time 02:06 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX144 question
astro1
Posted: 12:18am 06 Apr 2017
With option lcdpanel vga, what is the touch command?
Testing out a ps2 mouse.
Posted: 04:00am 06 Apr 2017
Check page 20 of the manual
astro1
Posted: 07:41pm 07 Apr 2017
Yep, sorry read it the wrong way.
Thanks,
astro1
Posted: 07:25pm 14 Apr 2017
Just trying out the GPS. MMX144 v5.03.16 @ 252MHz, GPS V.KEL TTL.
Latitude always prints Ok, but longitude prints the lat value (-37.7128).
Mostly fails if no pause, intermittent if pause is 100. Working if pause is 1000. Other GPS commands looks ok.
'this works with pause 1000
Open "com1:9600" As GPS,UTC +10
If GPS(valid)=1 Then
Print GPS(latitude)
Pause 1000
Print GPS(longitude)
Else
Print "waiting"
End If
Close GPS
' this prints lats then longs then lats again, looping
'If GPS(valid)=1 Then
'Print GPS(latitude)
'Pause 1000
'Else
'Print "waiting"
'End If
Close GPS
Posted: 09:39pm 14 Apr 2017
Thanks for the report - cut-and-paste typo in the code.
The longitude is derived from either GGA or RMC, it was correct for GGA but not RMC so it depended on timing of the request if you got the right answer.
Please try this - no change in version number
2017-04-15_073519_mmx.zip
I'll update the main thread when there is a more significant changeEdited by matherp 2017-04-16
astro1
Posted: 12:01pm 15 Apr 2017
Thanks, works great.
