Forum Index : Microcontroller and PC projects : MMX - cubic spline interpolation
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 269 |
This post describes an MMBASIC program that demonstrates how to perform cubic spline interpolation of one-dimensional tabular data provided by the user. The computational steps performed by the main program are as follow; (1) read data of the form y = f(x) (2) define the total number of x and y data points in this file (3) sample and load data arrays for the spline operations (spdata.bas) (4) generate the spline coefficient arrays (spcoef.bas) (5) perform interpolation for one or more user-defined x data values (spval.bas) The following is the output for this example. 1 1995.08 79.0637 2 1995.33 77.027 3 1995.58 75.097 4 1995.83 73.42 5 1996.08 72.3 6 1996.33 72.1059 7 1996.58 73.0494 8 1996.83 75.1141 9 1997.08 78.0324 10 1997.33 82 11 1997.58 87.3253 12 1997.83 93.5205 13 1998.08 100.477 14 1998.33 108.865 15 1998.58 118 16 1998.83 126.594 17 1999.08 134.627 18 1999.33 142.055 19 1999.58 148.339 20 1999.83 153.4 21 2000.08 157.012 22 2000.33 157.096 23 2000.58 153.207 24 2000.83 148.038 25 2001.08 143.1 26 2001.33 138.762 27 2001.58 134.597 28 2001.83 130.216 29 2002.08 125.583 30 2002.33 120.6 31 2002.58 115.222 32 2002.83 109.838 33 2003.08 104.941 34 2003.33 100.958 35 2003.58 97.6 36 2003.83 94.3199 37 2004.08 91.3883 38 2004.33 88.7572 39 2004.58 85.6656 40 2004.83 82.5 41 2005.08 80.1631 42 2005.33 78.4906 43 2005.58 77.0767 44 2005.83 75.6001 45 2006.08 74.2 46 2006.33 73.1772 47 2006.58 72.3095 48 2006.83 71.6035 49 2007.08 71.5961 50 2007.33 72.5 51 2007.58 74.297 52 2007.83 77.0057 53 2008.08 80.8123 54 2008.33 86.08 55 2008.58 92.4 56 2008.83 98.9 Here's a PDF document from the "Numerical Analysis with Numerit" software suite that helps explain how this technique works. 2017-04-01_141537_demo_sfit.pdf Here's the source code for this MMBASIC computer program. ' demos_sfit.bas April 1, 2017 ' this program demonstrates how to interact ' with the cubic spline subroutines which ' "fit" and interpolate one-dimensional ' tabular data of the form y = f(x) ' MMBASIC eXtreme version ''''''''''''''''''''''''' option default float option base 1 dim x(168), y(168), xk(168), yk(168) dim xfit(168), yfit(168) dim c1(168), c2(168), c3(168) ' read tabular data readdata ' define number of x and y data pairs ndata% = 168 ' sample every fifth data value and load ' "working" data arrays for spline operations nsp% = 5 spdata(x(), y(), ndata%, nsp%, xk(), yk(), npts%) ' generate cubic spline coefficient arrays spcoef(xk(), yk(), npts%, c1(), c2(), c3()) ' evaluate the cubic spline "fit" at every third ' data point and display the interpolated data nspj% = 3 i% = 0 for jj% = 1 to ndata% if ((jj% mod nspj%) <> 0) then ' null else ii% = ii% + 1 xval = x(jj%) spval(xval, xk(), yk(), npts%, c1(), c2(), c3(), sx) xfit(ii%) = xval yfit(ii%) = sx print ii%, xfit(ii%), yfit(ii%) end if next jj% end '''''''''''''''''''''''''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''''''''''''''''''''''''' sub spdata (x(), y(), ndata%, nsp%, xk(), yk(), npts%) ' sample and load data arrays for spline operations subroutine ' input ' x() = x data array ' y() = y data array ' ndata% = number of data points in data arrays ' nsp% = data points sampling interval ' output ' xk() = sampled x data array ' yk() = sampled y data array ' npts% = number of data points in sampled arrays '''''''''''''''''''''''''''''''''''''''''''''''''' xk(1) = x(1) yk(1) = y(1) npts% = 1 for i% = 1 to ndata% if ((i% mod nsp%) <> 0)) then ' null else npts% = npts% + 1 xk(npts%) = x(i%) yk(npts%) = y(i%) j% = i% end if next i% if (j% = ndata%) then ' null else npts% = npts% + 1 xk(npts%) = x(ndata%) yk(npts%) = y(ndata%) end if end sub ''''''''''''''''''''''''''''''''''''''''' ''''''''''''''''''''''''''''''''''''''''' sub spcoef (x(), y(), n%, c1(), c2(), c3()) ' calculate spline coefficients subroutine ' input ' x() = x data array ' y() = y data array ' n% = number of data points in arrays ' output ' c1(), c2(), c3() = array of spline coefficients '''''''''''''''''''''''''''''''''''''''''''''''''' if (n% < 2) then print "not enough data points; n must be >= 2" return end if if (n% = 2) then c1(1) = (y(2) - y(1)) / (x(2) - x(1)) c2(1) = 0.0 c3(1) = 0.0 c1(2) = c1(1) c2(2) = 0.0 c3(2) = 0.0 return end if nm1% = n% - 1 c3(1) = x(2) - x(1) c2(2) = (y(2) - y(1)) / c3(1) for i% = 2 to nm1% c3(i%) = x(i% + 1) - x(i%) c1(i%) = 2 * (c3(i% - 1) + c3(i%)) c2(i% + 1) = (y(i% + 1) - y(i%)) / c3(i%) c2(i%) = c2(i% + 1) - c2(i%) next i% c1(1) = -c3(1) c1(n%) = -c3(n% - 1) if (n% <> 3) then c2(1) = c2(3) / (x(4) - x(2)) - c2(2) / (x(3) - x(1)) c2(n%) = c2(n% - 1) / (x(n%) - x(n% - 2)) - c2(n% - 2) / (x(n% - 1) - x(n% - 3)) c2(1) = c2(1) * c3(1) ^ 2 / (x(4) - x(1)) c2(n%) = -c2(n%) * c3(n% - 1) ^ 2 / (x(n%) - x(n% - 3)) else c2(1) = 0.0 c2(n%) = 0.0 end if for i% = 2 to n% t = c3(i% - 1) / c1(i% - 1) c1(i%) = c1(i%) - t * c3(i% - 1) c2(i%) = c2(i%) - t * c2(i% - 1) next i% c2(n%) = c2(n%) / c1(n%) for j% = 1 to nm1% i% = n% - j% c2(i%) = (c2(i%) - c3(i%) * c2(i% + 1)) / c1(i%) next j% c1(n%) = (y(n%) - y(nm1%)) / c3(nm1%) + c3(nm1%) * (c2(nm1%) + 2 * c2(n%)) for i% = 1 to nm1% c1(i%) = (y(i% + 1) - y(i%)) / c3(i%) - c3(i%) * (c2(i% + 1) + 2 * c2(i%)) c3(i%) = (c2(i% + 1) - c2(i%)) / c3(i%) c2(i%) = 3.0 * c2(i%) next i% c2(n%) = 3.0 * c2(n%) c3(n%) = c3(n% - 1) end sub ''''''''''''''''''''''''''''''''''''''''''''''' ''''''''''''''''''''''''''''''''''''''''''''''' sub spval (u, x(), y(), n%, c1(), c2(), c3(), sx) ' evaluate spline fit subroutine ' input ' u = x value to be "fit" ' x() = x data array ' y() = y data array ' n% = number of data points in arrays ' c1(), c2(), c3() = spline fit coefficient arrays ' output ' sx = spline "fit" at u value ''''''''''''''''''''''''''''''' i% = 1 if ((n% < 2) or (u > x(n%)) or (u < x(1))) then print " " print "not enough data points or x value outside range" return end if if (i% >= n%) then i% = 1 end if if (u <= x(i% + 1)) then ' null else i% = 1 j% = n% + 1 do k% = int((i% + j%) / 2) if (u < x(k%)) then j% = k% end if if (u >= x(k%)) then i% = k% end if if (j% > (i% + 1)) then ' null else exit do end if loop end if dx = u - x(i%) c1i = c1(i%) c2i = c2(i%) c3i = c3(i%) prod = dx * (c1i + dx * (c2i + dx * c3i)) sx = y(i%) + prod end sub '''''''''' '''''''''' sub readdata ' read tabular data subroutine for i% = 1 to 168 read y(i%), x(i%) next i% data 80.4, 1994.9170 data 79.6, 1995.0004 data 78.8, 1995.0836 data 78.2, 1995.1670 data 77.7, 1995.2504 data 77.3, 1995.3336 data 76.7, 1995.4170 data 76.0, 1995.5004 data 75.3, 1995.5836 data 74.5, 1995.6670 data 73.7, 1995.7504 data 73.2, 1995.8336 data 72.9, 1995.9170 data 72.5, 1996.0004 data 72.3, 1996.0836 data 72.2, 1996.1670 data 72.1, 1996.2504 data 72.1, 1996.3336 data 72.3, 1996.4170 data 72.6, 1996.5004 data 72.9, 1996.5836 data 73.5, 1996.6670 data 74.1, 1996.7504 data 75.1, 1996.8336 data 76.0, 1996.9170 data 77.0, 1997.0004 data 78.0, 1997.0836 data 79.3, 1997.1670 data 80.6, 1997.2504 data 82.0, 1997.3336 data 83.7, 1997.4170 data 85.6, 1997.5004 data 87.4, 1997.5836 data 89.3, 1997.6670 data 91.4, 1997.7504 data 93.7, 1997.8336 data 95.9, 1997.9170 data 98.2, 1998.0004 data 100.6, 1998.0836 data 103.1, 1998.1670 data 105.9, 1998.2504 data 108.9, 1998.3336 data 111.8, 1998.4170 data 114.8, 1998.5004 data 118.0, 1998.5836 data 120.9, 1998.6670 data 123.7, 1998.7504 data 126.5, 1998.8336 data 129.2, 1998.9170 data 132.0, 1999.0004 data 134.6, 1999.0836 data 137.2, 1999.1670 data 139.6, 1999.2504 data 142.0, 1999.3336 data 144.3, 1999.4170 data 146.4, 1999.5004 data 148.4, 1999.5836 data 150.2, 1999.6670 data 151.9, 1999.7504 data 153.4, 1999.8336 data 154.7, 1999.9170 data 155.8, 2000.0004 data 156.6, 2000.0836 data 157.3, 2000.1670 data 157.6, 2000.2504 data 157.8, 2000.3336 data 155.9, 2000.4170 data 154.2, 2000.5004 data 152.8, 2000.5836 data 151.5, 2000.6670 data 150.0, 2000.7504 data 148.4, 2000.8336 data 146.4, 2000.9170 data 144.7, 2001.0004 data 143.1, 2001.0836 data 141.4, 2001.1670 data 139.5, 2001.2504 data 137.9, 2001.3336 data 137.0, 2001.4170 data 136.0, 2001.5004 data 134.2, 2001.5836 data 132.5, 2001.6670 data 131.3, 2001.7504 data 130.1, 2001.8336 data 128.7, 2001.9170 data 127.1, 2002.0004 data 125.3, 2002.0836 data 123.5, 2002.1670 data 122.0, 2002.2504 data 120.6, 2002.3336 data 118.7, 2002.4170 data 116.5, 2002.5004 data 114.5, 2002.5836 data 112.9, 2002.6670 data 111.6, 2002.7504 data 110.0, 2002.8336 data 108.1, 2002.9170 data 106.6, 2003.0004 data 105.1, 2003.0836 data 103.5, 2003.1670 data 102.1, 2003.2504 data 100.9, 2003.3336 data 99.7, 2003.4170 data 98.6, 2003.5004 data 97.6, 2003.5836 data 96.7, 2003.6670 data 95.8, 2003.7504 data 94.6, 2003.8336 data 93.5, 2003.9170 data 92.3, 2004.0004 data 91.4, 2004.0836 data 90.6, 2004.1670 data 89.7, 2004.2504 data 88.6, 2004.3336 data 87.8, 2004.4170 data 87.0, 2004.5004 data 86.0, 2004.5836 data 84.8, 2004.6670 data 83.6, 2004.7504 data 82.5, 2004.8336 data 81.9, 2004.9170 data 81.3, 2005.0004 data 80.4, 2005.0836 data 79.6, 2005.1670 data 79.0, 2005.2504 data 78.4, 2005.3336 data 77.8, 2005.4170 data 77.3, 2005.5004 data 77.0, 2005.5836 data 76.6, 2005.6670 data 76.1, 2005.7504 data 75.6, 2005.8336 data 75.1, 2005.9170 data 74.6, 2006.0004 data 74.2, 2006.0836 data 74.0, 2006.1670 data 73.7, 2006.2504 data 73.4, 2006.3336 data 73.1, 2006.4170 data 72.6, 2006.5004 data 72.3, 2006.5836 data 71.9, 2006.6670 data 71.7, 2006.7504 data 71.6, 2006.8336 data 71.5, 2006.9170 data 71.5, 2007.0004 data 71.7, 2007.0836 data 71.8, 2007.1670 data 72.1, 2007.2504 data 72.5, 2007.3336 data 73.0, 2007.4170 data 73.4, 2007.5004 data 74.1, 2007.5836 data 74.9, 2007.6670 data 76.0, 2007.7504 data 77.2, 2007.8336 data 78.3, 2007.9170 data 79.6, 2008.0004 data 80.9, 2008.0836 data 82.4, 2008.1670 data 84.1, 2008.2504 data 86.2, 2008.3336 data 88.2, 2008.4170 data 90.3, 2008.5004 data 92.4, 2008.5836 data 94.5, 2008.6670 data 96.7, 2008.7504 data 98.9, 2008.8336 end sub https://drive.google.com/drive/folders/0Bx2YPzS0EoweUFR6ZHZ0cVpFWjA?usp=sharing |
| Frank N. Furter Guru Joined: 28/05/2012 Location: GermanyPosts: 1162 |
Hi Cdeagle, thanks a lot - that's very useful!!! Frank |
| Tinine Guru Joined: 30/03/2016 Location: United KingdomPosts: 1646 |
+1 |
