Local Time 02:56 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : MMX - one-dimensional quadrature
cdeagle
Posted: 08:30am 31 Mar 2017
This post describes a demo program and support subroutines that can be used to perform one-dimensional quadrature of analytic functions. Given a user-defined subroutine of the form y(x) = f(x), lower and upper limits of integration, and a solution accuracy, this numerical method uses an "adaptive Simpson" technique to compute the "area under the curve".
The following is a typical user interaction with this computer program. It computes the area under the curve defined by y(x) = exp(-x^2) from x = 0 to x = 1.
program demo_quad
this program demonstrates the procedure for calling
asimpson which integrates a user-defined function of
the form y = f(x) using an adaptive simpson method.
subroutine asimpson requires a user-defined function
coded in a second subroutine called userfunc which
evaluates the function for any value of x. the user
must specify the lower and upper limits of integration,
and a desired solution accuracy.
this program demonstrates the use of asimpson to compute
the integral of exp(- x^2) for user-specified lower
and upper integration values for x.
please input the lower integration limit
? 0
please input the upper integration limit
? 1
please input the solution accuracy
(a value of 1e-8 is recommended)
? 1e-8
program demo_quad
<adaptive integration of user-defined functions>
lower integration limit = 0
upper integration limit = 1
solution accuracy = 1.00000e-08
integral value = 0.746824
estimated error = 1.09250e-10
Here's the MMBASIC source code listing for this program.
' program demo_quad.bas March 31, 2017
' this program demonstrates the procedure for calling
' asimpson which integrates a user-defined function of
' the form y = f(x) using an adaptive simpson method.
' subroutine asimpson requires a user-defined function
' coded in a second subroutine called userfunc which
' evaluates the function for any value of x. the user
' must specify the lower and upper limits of integration,
' and a desired solution accuracy.
' this program demonstrates the use of asimpson to compute
' the integral of exp( - x^2 ) for user-specified lower
' and upper integration values for x.
option default float
option base 1
' begin demo
print " "
print "program demo_quad"
print "-----------------"
print " "
print "this program demonstrates the procedure for calling"
print "asimpson which integrates a user-defined function of"
print "the form y = f(x) using an adaptive simpson method."
print " "
print "subroutine asimpson requires a user-defined function"
print "coded in a second subroutine called userfunc which"
print "evaluates the function for any value of x. the user"
print "must specify the lower and upper limits of integration,"
print "and a desired solution accuracy."
print " "
print "this program demonstrates the use of asimpson to compute"
print "the integral of exp(- x^2) for user-specified lower"
print "and upper integration values for x."
print " "
print "please input the lower integration limit"
input xl
print " "
print "please input the upper integration limit"
input xu
do
print " "
print "please input the solution accuracy"
print "(a value of 1e-8 is recommended)"
input acc
loop until (acc > 0.0)
' perform quadrature
asimpson(xl, xu, acc, s, xerror, iflag%)
' print results
print " "
print " "
print "<adaptive integration of user-defined functions>"
print " "
print " "
print "lower integration limit = "; xl
print " "
print "upper integration limit = "; xu
print " "
print " "
print "solution accuracy = "; acc
print " "
if (iflag% > 1) then
print
select case iflag%
case 2
print "<< error: more than 30 levels >>"
case 3
print "<< error: subinterval too small >>"
case 4
print "<< error: more than 2000 function evaluations >>"
end select
print " "
end if
print " "
print "integral value = "; s
print " "
print "estimated error = "; xerror
print " "
end
sub asimpson (a, b, acc, sum, esterr, iflag%)
' adaptive simpson integration subroutine
' input
' a = lower integration limit
' b = upper integration limit
' acc = accuracy
' output
' sum = integral from a to b
' esterr = relative error
' iflag% = error flag
' 1 => no error
' 2 => more than 30 levels
' 3 => subinterval too small
' 4 => more than 2000 function evaluations
' note: requires subroutine userfunc.bas
local lorr(30), f1t(30), f2t(30), f3t(30), dat(30)
local arestt(30), estt(30), epst(30), psum(30)
local u, fouru, eps, xerror, alpha, da, area, arest
local fv1, fv3, fv5, wt, est, dx, arestl, arestr, diff
u = 2.0e-100
' initialize
fouru = 4.0 * u
iflag% = 1
eps = acc
xerror = 0.0
lvl% = 1
lorr(lvl%) = 1
psum(lvl%) = 0.0
alpha = a
da = b - a
area = 0.0
arest = 0.0
userfunc(alpha, fv1)
userfunc(alpha + 0.5 * da, fv3)
userfunc(alpha + da, fv5)
kount% = 3
wt = da / 6.0
est = wt * (fv1 + 4.0 * fv3 + fv5)
' begin adaptive procedure
do
do
dx = 0.5 * da
userfunc(alpha + 0.5 * dx, fv2)
userfunc(alpha + 1.5 * dx, fv4)
kount% = kount% + 2
wt = dx / 6.0
estl = wt * (fv1 + 4.0 * fv2 + fv3)
estr = wt * (fv3 + 4.0 * fv4 + fv5)
sum = estl + estr
arestl = wt * (abs(fv1) + abs(4.0 * fv2) + abs(fv3))
arestr = wt * (abs(fv3) + abs(4.0 * fv4) + abs(fv5))
area = area + arestl + arestr - arest
diff = est - sum
if (abs(diff) <= eps * abs(area)) then
exit do
elseif (abs(dx) <= fouru * abs(alpha)) then
iflag% = 2
exit do
elseif (lvl% >= 30) then
iflag% = 3
exit do
elseif (kount% >= 2000) then
iflag% = 4
exit do
else
lvl% = lvl% + 1
lorr(lvl%) = 0
f1t(lvl%) = fv3
f2t(lvl%) = fv4
f3t(lvl%) = fv5
da = dx
dat(lvl%) = dx
arest = arestl
arestt(lvl%) = arestr
est = estl
estt(lvl%) = estr
eps = eps / 1.4
epst(lvl%) = eps
fv5 = fv3
fv3 = fv2
end if
loop
xerror = xerror + diff / 15.0
do
if (lorr(lvl%) = 0) then
psum(lvl%) = sum
lorr(lvl%) = 1
alpha = alpha + da
da = dat(lvl%)
fv1 = f1t(lvl%)
fv3 = f2t(lvl%)
fv5 = f3t(lvl%)
arest = arestt(lvl%)
est = estt(lvl%)
eps = epst(lvl%)
exit do
else
sum = psum(lvl%) + sum
lvl% = lvl% - 1
if (lvl% = 0) then exit do
end if
loop
loop
esterr = abs(xerror) / abs(sum)
end sub
sub userfunc (x, fval)
' user function subroutine
' f(x) = e^(-x^2)
' input
' x = function argument
' output
' fval = function value = f(x)
fval = exp(-x * x)
end sub
2017-03-31_182417_asimpson_BNALib.pdf
cdeagle
Posted: 12:07am 22 Apr 2017
Here are two more routines for one-dimensional quadrature.
' demo_qk15.bas April 21, 2017
' gk15 which integrates a user-defined function of
' the form y = f(x) using a 15-point gauss-kronrod method.
' subroutine gk15 requires a user-defined function
' coded in a second subroutine called user_func which
' must specify the lower and upper integration limits.
' this program demonstrates the use of gk15 to compute
' the integral of f(x) = 2 / sqrt(pi) * e^(-x^2) for
' user-specified lower and upper integration values for x.
option base 1
dim wg(4), xgk(8), wgk(8)
print " "
print "program demo_qk15 - gauss-kronrod quadrature of user-defined functions"
print "----------------------------------------------------------------------"
print " "
input xlower
print " "
input xupper
qk15(xlower, xupper, result)
print " "
print " "
print "quadrature value = "; result
print " "
end
sub qk15(a, b, result)
' one-dimensional quadrature subroutine
' gauss-kronrod 15 point method
' input
' output
' result = integral
local fv1(50), fv2(50)
local centr, hlgth, dhlgth, fcc
local fval1, fval2, fsum
local resg, resk, resabs, absc
' define gk15 coefficients
wg(1) = 0.1294849661688697
wg(2) = 0.2797053914892767
wg(3) = 0.3818300505051189
wg(4) = 0.4179591836734694
xgk(1) = 0.991455371120813
xgk(2) = 0.949107912342759
xgk(3) = 0.864864423359769
xgk(4) = 0.741531185599394
xgk(5) = 0.586087235467691
xgk(6) = 0.405845151377397
xgk(7) = 0.207784955007898
xgk(8) = 0.000000000000000
wgk(1) = 0.022935322010529
wgk(2) = 0.063092092629979
wgk(3) = 0.104790010322250
wgk(4) = 0.140653259715526
wgk(5) = 0.169004726639268
wgk(6) = 0.190350578064785
wgk(7) = 0.204432940075299
wgk(8) = 0.209482141084728
centr = 0.5 * (a + b)
hlgth = 0.5 * (b - a)
dhlgth = abs(hlgth)
user_func(centr, fcc)
resg = fcc * wg(4)
resk = fcc * wgk(8)
resabs = abs(resk)
for j% = 1 to 3
jtw% = j% * 2
absc = hlgth * xgk(jtw%)
user_func(centr - absc, fval1)
user_func(centr + absc, fval2)
fv1(jtw%) = fval1
fv2(jtw%) = fval2
fsum = fval1 + fval2
resg = resg + wg(j%) * fsum
resk = resk + wgk(jtw%) * fsum
resabs = resabs + wgk(jtw%) * (abs(fval1) + abs(fval2))
next j%
for j% = 1 to 4
jtwm1% = j% * 2 - 1
absc = hlgth * xgk(jtwm1%)
fv1(jtwm1%) = fval1
fv2(jtwm1%) = fval2
resk = resk + wgk(jtwm1%) * fsum
resabs = resabs + wgk(jtwm1%) * (abs(fval1) + abs(fval2))
next j%
reskh = resk * 0.5
resasc = wgk(8) * abs(fcc-reskh)
for j% = 1 to 7
resasc = resasc + wgk(j%) * (abs(fv1(j%) - reskh) + abs(fv2(j%) - reskh))
next j%
result = resk * hlgth
end sub
sub user_func (x, fval)
' user-defined function subroutine
' f(x) = 2 / sqrt(pi) * e^(-x^2)
' input
' output
fval = 2.0 / sqr(pi) * exp(-x * x)
end sub
' demo_gauleg.bas April 21, 2017
' gausleg which integrates a user-defined function of
' the form y = f(x) using a gauss-legendre method.
' subroutine gausleg requires a user-defined function
' must specify the lower and upper integration limits, the
' number of quadrature points, and a convergence criteria.
' this program demonstrates the use of gausleg to compute
' the integral of exp(- x^2) for user-specified lower
print " "
print "program demo_gauleg"
print " "
print "gausleg which integrates a user-defined function of"
print "the form y = f(x) using a gauss-legendre method."
print " "
print "subroutine gausleg requires a user-defined function"
print "must specify the lower and upper integration limits, the"
print "number of quadrature points, and a convergence criteria."
print " "
print "this program demonstrates the use of gausleg to compute"
print "the integral of exp( - x^2 ) for user-specified lower"
print " "
input xlower
print " "
input xupper
do
print " "
print "please enter the number of quadrature points"
input n%
loop until (n% > 0)
do
print " "
print "please enter the convergence criterion"
print "(a value of 1.0e-8 is recommended)"
input eps
loop until (eps > 0.0)
gausleg(xlower, xupper, n%, eps, result)
' print results
print " "
print "program demo_gauleg - gauss-legendre quadrature of user-defined functions"
print "-------------------------------------------------------------------------"
print " "
print "lower integration limit = "; xlower
print " "
print "upper integration limit = "; xupper
print " "
print " "
print "number of quadrature points = "; n%
print " "
print "convergence criterion = "; eps
print " "
print " "
print "integral value = "; result
print " "
end
sub gausleg(xmin, xmax, n%, eps, s)
' gauss-legendre quadrature subroutine
' input
' xmin = lower integration limit
' xmax = upper integration limit
' n% = number of quadrature points
' eps = convergence criteria
' output
' s = integral of f(x)
' note: requires sub user_func
local xm, x1, z, p1, p2, p3
local x(n%), w(n%)
m% = (n% + 1) / 2
xm = 0.5 * (xmax + xmin)
xl = 0.5 * (xmax - xmin)
for i% = 1 to m%
z = cos(pi * (i% - 0.25) / (n% + 0.5))
do
p1 = 1.0
p2 = 0.0
for j% = 1 to n%
p3 = p2
p2 = p1
p1 = ((2 * j% - 1) * z * p2 - (j% - 1) * p3) / j%
next j%
' newton's method
pp = n% * (z * p1 - p2) / (z * z - 1.0)
z1 = z
z = z1 - p1 / pp
' convergence check
if (abs(z - z1) <= eps) then exit do
loop
' abscissas
x(i%) = xm - xl * z
x(n% + 1 - i%) = xm + xl * z
' weights
w(i%) = 2.0 * xl / ((1.0 - z * z) * pp * pp)
w(n% + 1 - i%) = w(i%)
next i%
' evaluate integral
s = 0.0
for i% = 1 to n%
user_func(x(i%), y)
s = s + w(i%) * y
next i%
end sub
' f(x) = e^(-x^2)
' input
' output
fval = exp(-x * x)
end sub
