Local Time 05:03 30 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Problem with OrangePI+Micromite Plus
sagt3k
Posted: 11:45am 29 Mar 2017
Hi to everybody
I have a strange problem. I have a board OrangePI-Lite with Linux Armbian.
I do not have problems to connect microUSB modules as CP2102, that the system recognizes as ttyUSB0, but when I plug a micromite Plus 64 pin, the system recognizes as ttyACM0 that is normal but with minicom I can't connect.
dmesg return:
[ 2925.677053] ehci_irq: highspeed device connect
[ 2925.820047] ehci_irq: highspeed device disconnect
[ 2925.820077] ohci_irq: fullspeed or lowspeed device connect
[ 2926.240098] usb 7-1: new full-speed USB device number 10 using sunxi-ohci
[ 2926.493293] cdc_acm 7-1:1.0: ttyACM0: USB ACM device
and lsusb return:
Bus 007 Device 010: ID 04d8:fd52 Microchip Technology, Inc.
minicom setting:
| A - Serial Device : /dev/ttyACM0 |
| B - Lockfile Location : /var/lock |
| C - Callin Program : |
| D - Callout Program : |
| E - Bps/Par/Bits : 115200 8N1 |
| F - Hardware Flow Control : No |
| G - Software Flow Control : No
While with my PC + Linux Debian I connect micromite Plus and works all perfectly.
Could anyone give me some useful information to connect micromite plus with orangepi ?
sagt3k
Posted: 12:02pm 29 Mar 2017
What command line & what happens when you try with minicom?
JohnEdited by JohnS 2017-03-30
Posted: 06:53pm 29 Mar 2017
I think that minicom thinks the micromite is a modem and is expecting some modem stye responses.
You might be able to tell minicom that it is a plain serial port or you might be able to create a symbolic link to a tty device to fool minicom.
Please don't ask me how to do any of the above.
sagt3k
Posted: 08:12am 30 Mar 2017
Hi TassyJim
I do not think minicom does not work. In fact I tried on a Raspberry and working properly.
Dmesg on Raspberry:
[ 88.896470] usb 1-1.4: Product: Micromite Plus
[ 88.896476] usb 1-1.4: Manufacturer: Silicon Chip
[ 88.910402] cdc_acm 1-1.4:1.0: ttyACM0: USB ACM device
[ 88.911673] usbcore: registered new interface driver cdc_acm
[ 88.911682] cdc_acm: USB Abstract Control Model driver for USB modems and ISD N adapters
at this point I think that armbian not be completely compatible, maybe the CDC driver on kernel is not optimized.
If someone tests on these boards let me know
sagt3k
Quazee137
Posted: 11:40am 13 Jun 2017
Hope this helps.
minicom --color=on ttyACM0
just to see if you get to ttyACM0
if I try
minicom --color=on ttyACM1 or any thing other than 0
minicom: cannot open /dev/tty8: Permission denied
I get the error because ttyACM1 is not there.
this works too
minicom --color=on -b 38400 ttyACM0
but if I try other bauds it does not open a terminal.
My Mite is set to 38400
sagt3k
Posted: 08:56am 14 Jun 2017
Hi Quazee137
Thanks but but it doesn't work
root@orangepilite:/dev# minicom --color=on -b 38400 /dev/ttyACM0
minicom: cannot open /dev/modem: No such file or directory
root@orangepilite:/dev# minicom --color=on -b 38400 ttyACM0
Sagt3k
Quazee137
Posted: 12:39pm 14 Jun 2017
for testing minicom try
minicom --color=on -b 38400 /dev/ttyUSBx
with USB serial and rx-tx shorted for feed back.
dumb typewriter mode.
here is my little comm's test bash
#!/bin/bash
echo "------- USB's ---------"
ls /dev/ttyUSB*
echo
echo "------- ACM's ---------"
ls /dev/ttyACM*
echo
echo "------- lsusb ---------"
read $key
lsusb
echo "press key to exit"
read $key
exit
and this launches my army of Mites for testing
#!/bin/bash
if [ -e "/dev/ttyUSB0" ] ; then gnome-terminal -t USB0, -e "minicom --color=on ttyUSB0" ;fi
if [ -e "/dev/ttyUSB1" ] ; then gnome-terminal -t USB1, -e "minicom --color=on ttyUSB1" ;fi
if [ -e "/dev/ttyUSB2" ] ; then gnome-terminal -t USB2, -e "minicom --color=on ttyUSB2" ;fi
if [ -e "/dev/ttyUSB3" ] ; then gnome-terminal -t USB3, -e "minicom --color=on ttyUSB3" ;fi
if [ -e "/dev/ttyUSB4" ] ; then gnome-terminal -t USB4, -e "minicom --color=on ttyUSB4" ;fi
if [ -e "/dev/ttyUSB5" ] ; then gnome-terminal -t USB5, -e "minicom --color=on ttyUSB5" ;fi
if [ -e "/dev/ttyACM0" ] ; then gnome-terminal -t ACM0, -e "minicom --color=on ttyACM0" ;fi
if [ -e "/dev/ttyACM1" ] ; then gnome-terminal -t ACM1, -e "minicom --color=on ttyACM1" ;fi
# x-tile g 2 3
#play /home/papa/Sounds/BeatPlucker.ogg
#read $key
# testing code commented out
# ls -la /dev/tty*
Luck Quazee137
Just info
more info
May help looking at this
Edited by Quazee137 2017-06-16
