Forum Index : Microcontroller and PC projects : MMX - RKF78 numerical method
| cdeagle Senior Member Joined: 22/06/2014 Location: United StatesPosts: 269 |
This post describes an MMBASIC computer program that can be used to solve a system of first-order differential equations using the variable step size Runge-Kutta-Fehlberg 7(8) numerical method. If you understand the first sentence, read on. To illustrate the use of Fehlberg's customization of the classic Runge-Kutta method, I've written a demo program that uses this technique to solve the initial-value-problem (IVP) of Keplerian orbital motion. Given initial orbital conditions and a propagation duration, the software integrates the first-order system of differential that define the Keplerian or unperturbed motion of a body orbiting the Earth. For a body in a closed orbit, its Keplerian orbital period is equal to 2 * pi * sqr(a^3/mu), where a is the semimajor axis of the orbit and mu is the gravitational constant of the Earth. The orbital period is the time needed to travel from some location on the orbit, once around, to the same location on that orbit. We can use this fact to test and "calibrate" a diffeq numerical method. If the technique is working, the components of the position and velocity vectors (also called the state vector) should match "closely" at the beginning and exactly one or more orbital periods later. The calibration involves changing the truncation error value (TE), propagating the object for say ten orbits and looking at the closure of the state vector. We can "tune" the TE value to predict state vector differences we are willing to accept. Here's the program output for this example. It illustrates the initial and and final orbital elements and corresponding position and velocity vectors. The program also displays the difference in the initial and predicted components of the position and velocity vectors, in the units of meters and meters/second. The truncation error for this case is 1.0e-10. initial orbital elements and state vector ----------------------------------------- semimajor axis 26553.1755 kilometers eccentricity 0.7350000007 orbital inclination 63.4350 degrees argument of perigee 270.0000 degrees RAAN 100.0000 degrees true anomaly 45.0000 degrees orbital period 717.6859 minutes position vector x-component 1515.374483 kilometers position vector y-component 6035.274923 kilometers position vector z-component -5080.745408 kilometers position vector magnitude 8033.360263 kilometers velocity vector x-component -3.2103497224 kilometers/second velocity vector y-component 7.8012017187 kilometers/second velocity vector z-component 3.6138337387 kilometers/second velocity vector magnitude 9.1774118291 kilometers/second final orbital elements and state vector --------------------------------------- semimajor axis 26553.1755 kilometers eccentricity 0.7349999997 orbital inclination 63.4350 degrees argument of perigee 270.0000 degrees RAAN 100.0000 degrees true anomaly 45.0000 degrees orbital period 717.6859 minutes position vector x-component 1515.374620 kilometers position vector y-component 6035.274594 kilometers position vector z-component -5080.745565 kilometers position vector magnitude 8033.360142 kilometers velocity vector x-component -3.2103496709 kilometers/second velocity vector y-component 7.8012019147 kilometers/second velocity vector z-component 3.6138335697 kilometers/second velocity vector magnitude 9.1774119109 kilometers/second state vector differences (final - initial) ------------------------------------------ position vector x-component 0.137424 meters position vector y-component -0.328237 meters position vector z-component -0.156677 meters velocity vector x-component 0.0000514728 meters/second velocity vector y-component 0.0001958789 meters/second velocity vector z-component -0.0001694100 meters/second Here are the state vector differences for a truncation error value of 1.0e-12. Better prediction and longer run times. state vector differences (final - initial) ------------------------------------------ position vector x-component 0.004723 meters position vector y-component -0.011434 meters position vector z-component -0.005331 meters velocity vector x-component 0.0000017305 meters/second velocity vector y-component 0.0000068171 meters/second velocity vector z-component -0.0000057761 meters/second Here's the source code for the demo driver, RKF integrator and support functions and subroutines. ' demo_rkf78.bas March 27, 2017 ' this program demonstrates how to interact ' with the rkf78.bas subroutine which ' solves a system of first-order nonlinear ' differential equations ' the system of differential equations is defined ' in a subroutine with the following syntax ' sub diffeq(t, y(), ydot()) ' where t is the current time, y() is the current ' integration vector and ydot() is the system of ' first order differential equations evaluated at ' t and y() ' this example solves the differential equations ' of "Keplerian" (unperturbed) orbital motion ' MicroMite eXtreme version ''''''''''''''''''''''''''' option default float option base 1 dim ch(13), alph(13), beta(13, 12) dim ri(3), vi(3), rf(3), vf(3) dim yold(6), ynew(6), oevi(6), oevf(6) dim neq as integer, ti, tf, h, tetol const dtr = pi / 180.0, rtd = 180.0 / pi, pi2 = 2.0 * pi, pidiv2 = 0.5 * pi ' gravitational constant (kilometer^3/second^2) const mu = 398600.4415 ' define rkf78 integration coefficients ch(6) = 34 / 105 ch(7) = 9 / 35 ch(8) = ch(7) ch(9) = 9 / 280 ch(10) = ch(9) ch(12) = 41 / 840 ch(13) = ch(12) alph(2) = 2 / 27 alph(3) = 1 / 9 alph(4) = 1 / 6 alph(5) = 5 / 12 alph(6) = 0.5 alph(7) = 5 / 6 alph(8) = 1 / 6 alph(9) = 2 / 3 alph(10) = 1 / 3 alph(11) = 1 alph(13) = 1 beta(2, 1) = 2 / 27 beta(3, 1) = 1 / 36 beta(4, 1) = 1 / 24 beta(5, 1) = 5 / 12 beta(6, 1) = 0.05 beta(7, 1) = -25 / 108 beta(8, 1) = 31 / 300 beta(9, 1) = 2 beta(10, 1) = -91 / 108 beta(11, 1) = 2383 / 4100 beta(12, 1) = 3 / 205 beta(13, 1) = -1777 / 4100 beta(3, 2) = 1 / 12 beta(4, 3) = 1 / 8 beta(5, 3) = -25 / 16 beta(5, 4) = -beta(5, 3) beta(6, 4) = 0.25 beta(7, 4) = 125 / 108 beta(9, 4) = -53 / 6 beta(10, 4) = 23 / 108 beta(11, 4) = -341 / 164 beta(13, 4) = beta(11, 4) beta(6, 5) = 0.2 beta(7, 5) = -65 / 27 beta(8, 5) = 61 / 225 beta(9, 5) = 704 / 45 beta(10, 5) = -976 / 135 beta(11, 5) = 4496 / 1025 beta(13, 5) = beta(11, 5) beta(7, 6) = 125 / 54 beta(8, 6) = -2 / 9 beta(9, 6) = -107 / 9 beta(10, 6) = 311 / 54 beta(11, 6) = -301 / 82 beta(12, 6) = -6 / 41 beta(13, 6) = -289 / 82 beta(8, 7) = 13 / 900 beta(9, 7) = 67 / 90 beta(10, 7) = -19 / 60 beta(11, 7) = 2133 / 4100 beta(12, 7) = -3 / 205 beta(13, 7) = 2193 / 4100 beta(9, 8) = 3 beta(10, 8) = 17 / 6 beta(11, 8) = 45 / 82 beta(12, 8) = -3 / 41 beta(13, 8) = 51 / 82 beta(10, 9) = -1 / 12 beta(11, 9) = 45 / 164 beta(12, 9) = 3 / 41 beta(13, 9) = 33 / 164 beta(11, 10) = 18 / 41 beta(12, 10) = 6 / 41 beta(13, 10) = 12 / 41 beta(13, 12) = 1 ' define initial classical orbital elements oevi(1) = 26553.175464 oevi(2) = 0.735 oevi(3) = 63.435 * dtr oevi(4) = 270.0 * dtr oevi(5) = 100.0 * dtr oevi(6) = 45.0 * dtr ' compute initial state vector orb2eci(mu, oevi(), ri(), vi()) print " " print "initial orbital elements and state vector" print "-----------------------------------------" print " " oeprint(mu, oevi()) print " " svprint(ri(), vi()) ' define number of differential equations neq = 6 ' initial step size guess (seconds) h = 1.0 ' truncation error tolerance tetol = 1.0e-10 ' load initial integration vector for i% = 1 to 3 yold(i%) = ri(i%) yold(i% + 3) = vi(i%) next i% ' initial time (seconds) ti = 0.0 ' final time = ten keplerian orbital periods (seconds) tau = pi2 * sqr(oevi(1) * oevi(1) * oevi(1) / mu) tf = 10.0 * tau ' integrate equations of motion rkf78(neq, ti, tf, h, tetol, yold(), ynew()) ' unload final state vector for i% = 1 to 3 rf(i%) = ynew(i%) vf(i%) = ynew(i% + 3) next i% ' compute and print final orbital elements eci2orb(mu, rf(), vf(), oevf()) print " " print " " print "final orbital elements and state vector" print "---------------------------------------" print " " oeprint(mu, oevf()) print " " svprint(rf(), vf()) print " " print " " print "state vector differences (final - initial)" print "------------------------------------------" print " " print "position vector x-component ", str$(1000.0 * (rf(1) - ri(1)), 0, 6), " meters" print "position vector y-component ", str$(1000.0 * (rf(2) - ri(2)), 0, 6), " meters" print "position vector z-component ", str$(1000.0 * (rf(3) - ri(3)), 0, 6), " meters" print " " print "velocity vector x-component ", str$(1000.0 * (vf(1) - vi(1)), 0, 10), " meters/second" print "velocity vector y-component ", str$(1000.0 * (vf(2) - vi(2)), 0, 10), " meters/second" print "velocity vector z-component ", str$(1000.0 * (vf(3) - vi(3)), 0, 10), " meters/second" print " " end ''''''''''''''''''''''''''''''''''''''''''' ''''''''''''''''''''''''''''''''''''''''''' sub rkf78 (neq, ti, tf, h, tetol, xi(), xf()) ' solve first order system of differential equations ' Runge-Kutta-Fehlberg 7(8) method ' input ' neq = number of differential equations ' ti = initial simulation time (seconds) ' tf = final simulation time (seconds) ' h = initial guess for integration step size ' tetol = truncation error tolerance (non-dimensional) ' xi() = integration vector at time = ti ' output ' xf() = integration vector at time = tf ''''''''''''''''''''''''''''''''''''''''' local xdot(neq), xwrk(neq), f(neq, 13) local sdt, dt, temp, twrk ' compute integration "direction" sdt = sgn(tf - ti) dt = abs(h) * sdt do ' load "working" time and integration vector twrk = ti for i% = 1 to neq xwrk(i%) = xi(i%) next i% ' check for last delta-t if (abs(dt) > abs(tf - ti)) then dt = tf - ti ' check for end of integration period if (abs(ti - tf) < 1.0e-12) then for i% = 1 to neq xf(i%) = xi(i%) next i% ' finished - exit do loop exit do end if ' evaluate equations of motion diffeq(ti, xi(), xdot()) for i% = 1 to neq f(i%, 1) = xdot(i%) next i% ' compute solution for k% = 2 to 13 kk% = k% - 1 for i% = 1 to neq temp = 0.0 for j% = 1 to kk% temp = temp + beta(k%, j%) * f(i%, j%) next j% xi(i%) = xwrk(i%) + dt * temp next i% ti = twrk + alph(k%) * dt diffeq(ti, xi(), xdot()) for j% = 1 to neq f(j%, k%) = xdot(j%) next j% next k% for i% = 1 to neq temp = 0.0 for l% = 1 to 13 temp = temp + ch(l%) * f(i%, l%) next l% xi(i%) = xwrk(i%) + dt * temp next i% ' truncation error calculations xerr = tetol for i% = 1 to neq ter = abs((f(i%, 1) + f(i%, 11) - f(i%, 12) - f(i%, 13)) * ch(12) * dt) tol = abs(xi(i%)) * tetol + tetol tconst = ter / tol if (tconst > xerr) then xerr = tconst next i% ' compute new step size dt = 0.8 * dt * (1.0 / xerr) ^ (1.0 / 8.0) if (xerr > 1.0) then ' reject current step and try again ti = twrk for i% = 1 to neq xi(i%) = xwrk(i%) next i% else '''''''''''''''''''''''''''''''''''' ' accept current step ' '''''''''''''''''''''''''''''''''''' ' perform graphics, additional ' ' calculations, etc. at this point ' '''''''''''''''''''''''''''''''''''' end if loop end sub ''''''''''''''''''''''''' ''''''''''''''''''''''''' sub diffeq (t, y(), ydot()) ' first order equations of orbital motion ' Keplerian motion - no perturbations ' input ' t = simulation time (seconds) ' y() = state vector ' output ' ydot() = integration vector '''''''''''''''''''''''''''''' local rmag, rcubed rmag = sqr(y(1) * y(1) + y(2) * y(2) + y(3) * y(3)) rcubed = rmag * rmag * rmag ' integration vector ydot(1) = y(4) ydot(2) = y(5) ydot(3) = y(6) ydot(4) = -mu * y(1) / rcubed ydot(5) = -mu * y(2) / rcubed ydot(6) = -mu * y(3) / rcubed end sub ''''''''''''''''''''''''''''''' ''''''''''''''''''''''''''''''' sub eci2orb (mu, r(), v(), oev()) ' convert eci state vector to six classical orbital ' elements via equinoctial elements ' input ' mu = central body gravitational constant (km**3/sec**2) ' r() = eci position vector (kilometers) ' v() = eci velocity vector (kilometers/second) ' output ' oev(1) = semimajor axis (kilometers) ' oev(2) = orbital eccentricity (non-dimensional) ' (0 <= eccentricity < 1) ' oev(3) = orbital inclination (radians) ' (0 <= inclination <= pi) ' oev(4) = argument of perigee (radians) ' (0 <= argument of perigee <= 2 pi) ' oev(5) = right ascension of ascending node (radians) ' (0 <= raan <= 2 pi) ' oev(6) = true anomaly (radians) ' (0 <= true anomaly <= 2 pi) ''''''''''''''''''''''''''''''''''''''' local rmag, vmag, sma, p, q, const1 local h, xk, x1, y1, eccm, inc, xlambdat local raan, argper, tanom local rhat(3), hhat(3), vtmp(3), ecc(3) local hv(3), fhat(3), ghat(3) ' position and velocity magnitude rmag = vecmag(r()) vmag = vecmag(v()) ' position unit vector uvector(r(), rhat()) ' angular momentum vectors vcross(r(), v(), hv()) uvector(hv(), hhat()) ' eccentricity vector for i% = 1 to 3 vtmp(i%) = v(i%) / mu next i% vcross(vtmp(), hv(), ecc()) for i% = 1 to 3 ecc(i%) = ecc(i%) - rhat(i%) next i% ' semimajor axis sma = 1.0 / (2.0 / rmag - vmag * vmag / mu) p = hhat(1) / (1.0 + hhat(3)) q = -hhat(2) / (1.0 + hhat(3)) const1 = 1.0 / (1.0 + p * p + q * q) fhat(1) = const1 * (1.0 - p * p + q * q) fhat(2) = const1 * 2.0 * p * q fhat(3) = -const1 * 2.0 * p ghat(1) = const1 * 2.0 * p * q ghat(2) = const1 * (1.0 + p * p - q * q) ghat(3) = const1 * 2.0 * q h = vdot(ecc(), ghat()) xk = vdot(ecc(), fhat()) x1 = vdot(r(), fhat()) y1 = vdot(r(), ghat()) ' orbital eccentricity eccm = sqr(h * h + xk * xk) ' orbital inclination inc = 2.0 * atn(sqr(p * p + q * q)) ' true longitude xlambdat = atan3(y1, x1) ' check for equatorial orbit if (inc > 1.0e-8) then raan = atan3(p, q) else raan = 0.0 end if ' check for circular orbit if (eccm > 1.0e-8) then argper = modulo(atan3(h, xk) - raan) else argper = 0.0 end if ' true anomaly (radians) tanom = modulo(xlambdat - raan - argper) ' load orbital element vector oev(1) = sma oev(2) = eccm oev(3) = inc oev(4) = argper oev(5) = raan oev(6) = tanom end sub '''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''' sub orb2eci(mu, oev(), r(), v()) ' convert classical orbital elements to state vector ' input ' mu = gravitational constant (km**3/sec**2) ' oev(1) = semimajor axis (kilometers) ' oev(2) = orbital eccentricity (non-dimensional) ' (0 <= eccentricity < 1) ' oev(3) = orbital inclination (radians) ' (0 <= inclination <= pi) ' oev(4) = argument of perigee (radians) ' (0 <= argument of perigee <= 2 pi) ' oev(5) = right ascension of ascending node (radians) ' (0 <= raan <= 2 pi) ' oev(6) = true anomaly (radians) ' (0 <= true anomaly <= 2 pi) ' output ' r() = position vector (kilometers) ' v() = velocity vector (kilometers/second) '''''''''''''''''''''''''''''''''''''''''''' local sma, ecc, inc, argper, raan, tanom local slr, rm, arglat, sarglat, carglat local c4, c5, c6, sinc, cinc, sraan, craan ' unload orbital elements array sma = oev(1) ecc = oev(2) inc = oev(3) argper = oev(4) raan = oev(5) tanom = oev(6) slr = sma * (1.0 - ecc * ecc) rm = slr / (1.0 + ecc * cos(tanom)) arglat = argper + tanom sarglat = sin(arglat) carglat = cos(arglat) c4 = sqr(mu / slr) c5 = ecc * cos(argper) + carglat c6 = ecc * sin(argper) + sarglat sinc = sin(inc) cinc = cos(inc) sraan = sin(raan) craan = cos(raan) ' position vector r(1) = rm * (craan * carglat - sraan * cinc * sarglat) r(2) = rm * (sraan * carglat + cinc * sarglat * craan) r(3) = rm * sinc * sarglat ' velocity vector v(1) = -c4 * (craan * c6 + sraan * cinc * c5) v(2) = -c4 * (sraan * c6 - craan * cinc * c5) v(3) = c4 * c5 * sinc end sub '''''''''''''''''''' '''''''''''''''''''' sub oeprint(mu, oev()) ' print classical orbital elements subroutine if (oev(1) > 0.0) then tau = pi2 * sqr(oev(1) * oev(1) * oev(1) / mu) else tau = 0.0 end if print "semimajor axis ", str$(oev(1), 0, 4), " kilometers" print "eccentricity ", str$(oev(2), 0, 10) print "orbital inclination ", str$(rtd * oev(3), 0, 4), " degrees" print "argument of perigee ", str$(rtd * oev(4), 0, 4), " degrees" print "RAAN ", str$(rtd * oev(5), 0, 4), " degrees" print "true anomaly ", str$(rtd * oev(6), 0, 4), " degrees" print " " print "orbital period ", str$(tau / 60.0, 0, 4), " minutes" end sub ''''''''''''''''''' ''''''''''''''''''' sub svprint(r(), v()) ' print position and velocity vectors subroutine local rmag, vmag print "position vector x-component ", str$(r(1), 0, 6), " kilometers" print "position vector y-component ", str$(r(2), 0, 6), " kilometers" print "position vector z-component ", str$(r(3), 0, 6), " kilometers" rmag = vecmag(r()) print " " print "position vector magnitude ", str$(rmag, 0, 6), " kilometers" print " " print "velocity vector x-component ", str$(v(1), 0, 10), " kilometers/second" print "velocity vector y-component ", str$(v(2), 0, 10), " kilometers/second" print "velocity vector z-component ", str$(v(3), 0, 10), " kilometers/second" vmag = vecmag(v()) print " " print "velocity vector magnitude ", str$(vmag, 0, 10), " kilometers/second" end sub ''''''''''''''''''''''''' ''''''''''''''''''''''''' function modulo(x) as float ' modulo 2 pi function '''''''''''''''''''''' local a a = x - pi2 * fix(x / pi2) if (a < 0.0) then a = a + pi2 end if modulo = a end function ''''''''''''''''''''''''''' ''''''''''''''''''''''''''' function atan3(a, b) as float ' four quadrant inverse tangent function ' input ' a = sine of angle ' b = cosine of angle ' output ' atan3 = angle (0 =< atan3 <= 2 * pi; radians) '''''''''''''''''''''''''''''''''''''''''''''''' local c if (abs(a) < 1.0e-10) then atan3 = (1.0 - sgn(b)) * pidiv2 exit function else c = (2.0 - sgn(a)) * pidiv2 endif if (abs(b) < 1.0e-10) then atan3 = c exit function else atan3 = c + sgn(a) * sgn(b) * (abs(atn(a / b)) - pidiv2) endif end function ''''''''''''''''''''''''''' ''''''''''''''''''''''''''' function vecmag(a()) as float ' vector magnitude function ' input ' { a } = column vector ( 3 rows by 1 column ) ' output ' vecmag = scalar magnitude of vector { a } vecmag = sqr(a(1) * a(1) + a(2) * a(2) + a(3) * a(3)) end function '''''''''''''''''''' '''''''''''''''''''' sub uvector (a(), b()) ' unit vector subroutine ' input ' a = column vector (3 rows by 1 column) ' output ' b = unit vector (3 rows by 1 column) ''''''''''''''''''''''''''''''''''''''' local amag amag = vecmag(a()) for i% = 1 to 3 if (amag <> 0.0) then b(i%) = a(i%) / amag else b(i%) = 0.0 end if next i% end sub '''''''''''''''''''''''''''''' '''''''''''''''''''''''''''''' function vdot(a(), b()) as float ' vector dot product function ' c = { a } dot { b } ' input ' n% = number of rows ' { a } = column vector with n rows ' { b } = column vector with n rows ' output ' vdot = dot product of { a } and { b } '''''''''''''''''''''''''''''''''''''''' local c = 0.0 for i% = 1 to 3 c = c + a(i%) * b(i%) next i% vdot = c end function ''''''''''''''''''''''' ''''''''''''''''''''''' sub vcross(a(), b(), c()) ' vector cross product subroutine ' { c } = { a } x { b } ' input ' { a } = vector a ( 3 rows by 1 column ) ' { b } = vector b ( 3 rows by 1 column ) ' output ' { c } = { a } x { b } ( 3 rows by 1 column ) c(1) = a(2) * b(3) - a(3) * b(2) c(2) = a(3) * b(1) - a(1) * b(3) c(3) = a(1) * b(2) - a(2) * b(1) end sub Here's a PDF note that helps illustrate the geometry of orbital elements. 2017-03-27_180113_orbital_elements.pdf Other MMBASIC programs and documents can be found at my Google Drive site https://drive.google.com/drive/folders/0Bx2YPzS0EoweUFR6ZHZ0cVpFWjA?usp=sharing |
I had a programmable calculator that had a program for the Runge-Kutta method. I still have the manuals with the program 'somewhere' I also converted it to an early version of Basic (not MMBasic) many moons ago. All your submissions are siring many memories. Thanks Jim VK7JH MMedit |
| crez Senior Member Joined: 24/10/2012 Location: AustraliaPosts: 157 |
I thought this sounded familiar, so dug out my copy of Applied Numerical Analysis by Gerald and Wheatley. It doesn't get opened that often these days. |
