Local Time 22:19 29 Oct 2026 Privacy Policy
Forum Index : Microcontroller and PC projects : Maximite with LCD Pack House keeping
heppy36
Posted: 10:25pm 26 Mar 2017
Hi all,I have just built my micromite with LCD backpack,and you have probable had same question before (sorry for this)I have been loading and testing lost of programs,the last one have the auto run option so now it runs all the time,how do I stop it?
From tera term can I see all the bas files and delete them?sort of loaded quite a lot?
I am running the PeterMDemo and its great,has anyone got it realy connected to input pins and working?might be a bit much for me to work out the correct code (Its a realy Great demo)
This is a fantastic good quality project and great fun
Thanks for everyone effort to make is maximite work
Martin heppenstall
Heppy
Posted: 01:56am 27 Mar 2017
To stop the program; use Ctrl-C from a connected Terminal program (i.e. TeraTerm)
Then at the command prompt simply type: OPTION AUTORUN OFF (to stop it outrunning in the future.
NOTE: So programs include the OPTION AUTORUN ON in the actual code which will then switch on the AUTORUNning feature again. Personally I would remove this from code (if it exists) and leave it under the control from the Command Prompt
WWEdited by WhiteWizzard 2017-03-28
